Spec Stg 2 or 3 with oem replacement Flywheel - Honda Accord Forum : V6 Performance Accord Forums
Old July 22nd, 2014, 08:29 PM   #1
I have a 2006 Accord Coupe 6-6 with 3" CAI, 2.5" custom cat back and 75 shot of nitrous and other misc. small things. I tried a 100shot and the clutch just can't handle that.
Does anyone on here have a Spec Stage 2 or Stage 3 clutch paired with a replacement OEM style flywheel? Is it worth using or not? Is the flywheel lasting? Do you get positive identical clutch grabs every time?
I really don't want to spring for one of the solid aluminum flywheels because they're lightweight and this car already doesn't have any real torque to speak of. I can't see reducing flywheel weight working out all that well for drag racing like I do.
I want to put in a better clutch but they flywheel options for this car are lame! I wish someone offered a solid flywheel in steel for us as that would be my first choice.
sscavy is offline   Reply With Quote Quick reply to this message
Old July 23rd, 2014, 10:05 AM   #2
ER MER GERD!!!!
DMunny's Avatar
just be sure to double check the part number with spec before you order. I got slightly screwed by Andysautosport. The had the wrong part number listed for our cars.
DMunny is offline   Reply With Quote Quick reply to this message
Old July 24th, 2014, 05:30 PM   #3
Do you have a spec stage 2 or 3 clutch on an oem style dual mass flywheel? Are the grabbing point consistent? Do you like it?
Old July 24th, 2014, 09:14 PM   #4
Sonnick's Avatar
I have a Clutchmasters FX250 with the AASCO Flywheel and it's a GREAT combo. I highly recommend it. Clutch pedal is like stock or even a bit softer and it grabs. I heard the pedal is really stiff with the Spec Stage 2+. You can run the stock Flywheel with Spec.
I've yet to go to the track with this setup though.
Old July 25th, 2014, 10:03 PM   #5
How sure are you about this?
Is the aasco flywheel still a dual mass correct?
04 Accord 6-6 Coupe
13s no matter what hp I have
Just an All Motor J30...
Zach @ YCU Dyno Tuning
Old July 26th, 2014, 05:56 PM   #6
Sonnick's Avatar
I'm almost positive. Email Spec to confirm it but I'm almost 100%.
AASCO is single mass but works flawlessly.
Instagram = j30_allmotor
Old August 21st, 2014, 01:15 AM   #7
Banned
i have a SPEC 3+ clucth and the ASSCO flywheel
Accord_J30A5 is offline   Reply With Quote Quick reply to this message
