Magnesium IM port measurement - Honda Accord Forum : V6 Performance Accord Forums
Old July 24th, 2014, 08:08 PM   #1
42.3-42.7mm for the TL-S IM. Looks like I need to get this baby ported out.
&mpt=[CACHEBUSTER]">
I suggest you all measure out your IM also. Since my ported runners were 44mm. My extra large ported runners are 45mm-46mm
You guys know what to do next
Old July 24th, 2014, 08:18 PM   #2
Did you port all the runners you did to 44mm? Besides the larger ones?
Old July 24th, 2014, 08:21 PM   #3
yeah. they all should be ~44mm standard for all the one that I did. I think these were the very first few that I did and put on my car.
the extra large one I had a shop do it for me since they were doing my head anyways
Old July 24th, 2014, 10:09 PM   #4
I need to measure.
How do you port the 3.7 TL manifold? Never done anything like that but I would like it matched.
Old July 24th, 2014, 10:15 PM   #5
Sonnick's Avatar
How big is the manifold inlet?
Old July 25th, 2014, 12:21 AM   #6
3.7 tls or 3.5??
I have a j35a8 manifold right now
Old July 25th, 2014, 12:27 AM   #7
Whats the difference for the rcj(3.7tl) and the rca(av6/tl/rl) intake manifold gasket
Old July 25th, 2014, 01:32 AM   #8
The Jester
the 3.7 is smaller than the stock j30 diameter.
However porting magnesium is highly advised against. Unless you like explosions, have a shop do it.
Though I've gotta say, 44mm or even 45mm runners aren't going to hurt anything. a .05mm gap on each side isn't going to hurt velocity or create any turbulence. Getting everything torqued to spec might give you more hp than a perfect port vs oversized entrance.
Old July 25th, 2014, 06:44 AM   #9
Take it to a shop to port mag. Even though its a alloy it still wants to blow up
Old July 25th, 2014, 03:36 PM   #10
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
Has anyone even Flowbenched the Magnesium intake to see if it really does have better flow/volume than say...... a ported J32A2/J35A3 intake manifold & runner set up?
Old July 26th, 2014, 01:23 AM   #11
The Jester
No.
I suppose there's no ghetto way to configure a flow bench is there.
Old August 1st, 2014, 04:51 PM   #12
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
Originally Posted by oraclem19 View Post
No.
Ghetto? WTF, really?
There are FlowBench packages you can buy for a home set up. Runs about $1500 though. They are suppose to be pretty accurate, but... would be alot cheaper to just have a manifold FlowBenched at a shop.
Old August 1st, 2014, 05:32 PM   #13
Don't mind him his cheap lol
Old August 1st, 2014, 05:51 PM   #14
The Jester
We're measuring how fast air moves from one place to another right?
There's gotta be a semi-accurate way to measure how much water goes from one bucket to another in 5s through a glorified funnel. Other than a $2000 machine. Or a test that costs $200.
Unless the difference between semi-accurate and accurate is more than 5hp. When you're just looking for is one better than another as long as the accuracy is consistent, the numbers are completely irrelevant other than in relation to each other.
You could always go plop down a few hundred to answer an internet question though. Guess I get down differently.
