middle drive shaft bearing on the passanger side - Honda Accord Forum : V6 Performance Accord Forums
Old August 1st, 2014, 02:46 AM   #1
I want to know if someone had to change the middle drive shaft bearing on the right side? I want to know how hard is it to change it and if that happen often? I believe it's the parts number 26. JOINT, INBOARD/DRIVESHAFT (V6) for 2004 Honda ACCORD COUPE Thank you much.
Alex
parts number
alexis444 is offline   Reply With Quote Quick reply to this message
Old August 1st, 2014, 10:19 AM   #2
Doesn't look that hard but there isn't lots of stress like wheel bearing
Old August 2nd, 2014, 08:26 AM   #3
DAT Dewd from Dallas MANG
yo...
if your heat shield was ever removed for a long time then the bearing is now trash....
I learned about this the hard way...
Old August 3rd, 2014, 04:13 PM   #4
It can be pretty hard if you don't have the proper tools just because of that heat shield. You don't have a lot of room to play.
Beefcake17 is offline   Reply With Quote Quick reply to this message
Old August 3rd, 2014, 07:51 PM   #5
Removing isn't that bad
The hear shield needs to be removed temporarily for the cat removal
The whole bracket comes out and u can use a press on it for the bearing
