J32a3 Swap - Honda Accord Forum : V6 Performance Accord Forums
Like Tree138Likes
Old August 31st, 2014, 07:08 AM   #1
pa1nt13aller's Avatar
J32a3 Swap
Well this build will be continuing from my flashpro dyno thread which I never finished. I had the chance to get hold of a 85k 2006 3.2 Tl motor(for only $595) anndddd so I did!
I will complete the dyno after I clean, build and swap this motor in, probably in 3 weeks or so. Trying to get a hold of Type S heads or MDX heads but can only find the front bank, otherwise I'll just get type s cams. So if anyone has any cylinder heads of this sort, lemme know!
I'm stuck right now on getting the crank pulley bolt out so I can get the timing cover off. Impact isn't doing it, I'll try heat and later the 50mm crank pulley socket if heat doesn't work.
Mmmm so clean
jiga21 likes this.
Old August 31st, 2014, 07:53 AM   #2
SFL AV6
jiga21's Avatar
I hope the transition goes smoothly. So convenient we can get a J series so cheap man
pa1nt13aller likes this.
Old August 31st, 2014, 09:15 AM   #3
Sonnick's Avatar
Mmmm so clean
I have 2010 MDX heads and ported 8G runners. Thinking about selling.
Instagram = j30_allmotor
Old August 31st, 2014, 09:45 AM   #4
there a set of TL-S heads without camshaft on acurazine.
To get that stupid crank bold off they had to use a 3/4in Impacted. Took 5 sec. lol 1/2 wasn't cutting it
Old August 31st, 2014, 10:03 AM   #5
accord325's Avatar
Porting some stock J30A5 heads with TL-S valve springs (Intake and Exhaust side). Also have a set of ported runners to go with them.
You have some options now, LOL . Honestly my pic would be Sonnicks offer, if he sells (which he shouldn't !!). You get the heads from him, dont work them. You can deck them for compression if you want but you will be 12:1 compression.
Great find on that engine BTW, looks really clean, lower miles and great price !
Old August 31st, 2014, 12:38 PM   #6
Yeah I'd be interested in the MDX heads. I heard if we deck the heads it will screw up timing on SOHC engines? I can tune of course, but I would be re tunning on an E-Tune so my car would be running like crap until it gets sorted out a couple days later.
Old August 31st, 2014, 12:42 PM   #7
You should be fine with a 1pt deck. Even though ideally you want to do piston to upgrade cr. My head is deck for .4 cr. And a lot of other are a full 1 CR
found a complete head for 600
http://acurazine.com/forums/showthread.php?t=915644
Old September 1st, 2014, 09:50 AM   #8
FS: Forgestar wheels, j35a8 heads, engine, atlp, rv6 and more. - AcuraZine Community
oh dang $600. I'm hopping on that thanks! Will these heads work with all my 3.2 stuff? Runners, coolant passages etc.?
Old September 1st, 2014, 09:52 AM   #9
^ yes I have a j35a8 head on my j30a5 block. Use the j35a8 headgasket. or look at my build thread
Old September 1st, 2014, 10:42 PM   #10
The Jester
And the lowest I can find a block for around here is 900.
Will be following project
Old September 2nd, 2014, 05:58 AM   #11
Go on ebay then. There are a couple for around $500 and even with the shipping cost/delivery it could be less than $900. Look for the ones that ship freight. Then its just a delivery fee. So you could get one for around $600
Sonnick likes this.
Old September 2nd, 2014, 12:52 PM   #12
The Jester
Might have to or use that for haggling room. Unless this guys is super low on mile
Old September 2nd, 2014, 03:39 PM   #13
Sorry but this is completely necessary, this goes to all honda crank pulley bolts.
Had to use a 50mm crank socket for the middle of the crank pulley on a breaker bar attached to a cheater bar which was braced on the bottom of the engine stand.
Then had to use another breaker bar with a cheater bar attached to the crank bolt and almost snapped the damn engine off its stand...so ridiculous.
Anyway, I got both complete TL-S heads for only $450!!! So ill clean them up when they get here, new timing belt and water pump, then time to swap!
Sonnick likes this.
Old September 2nd, 2014, 03:50 PM   #14
hahah I know your feeling bro. 3/4in impact gun works best if the motor is off the car. If its on the car start blimp ftw
Old September 2nd, 2014, 05:44 PM   #15
UPDATE
Here is the tool I used:
Now the wait on the J35a8 Heads
Old September 2nd, 2014, 05:51 PM   #16
Old September 2nd, 2014, 06:32 PM   #17
accord325's Avatar
^ how do your pistons look ? You can clean them with some light abrasive scotch bright if they have some build up.
Old September 2nd, 2014, 06:54 PM   #18
But that will microscopically lower compression! How dare you.
I actually do have some scotchbrite pad, but it wouldn't really do anything but look pretty =/ lol
Old September 2nd, 2014, 07:02 PM   #19
Soak the piston in ATF. It will help remove some of the deposit and keep the cylinder oiled
Old September 2nd, 2014, 07:36 PM   #20
I just used throttle body cleaner, scotchbrite and then lubed up the cylinders with royal purple. Worked very well, specially the throttle body cleaner.
Old September 3rd, 2014, 12:03 AM   #21
DAT Dewd from Dallas MANG
Are the piston rings still good?
How about crank bearings?
Old September 3rd, 2014, 05:58 AM   #22
I was thinking about doing the piston rings...they very well should be good...
Old September 3rd, 2014, 06:54 PM   #23
Vtec_Sheikhani's Avatar
subscribed. I might possibly be doing a j32 swap depends what honda says about my engine.
bdbconcepts likes this.
Vtec_Sheikhani is offline   Reply With Quote Quick reply to this message
Old September 3rd, 2014, 07:38 PM   #24
I've seen quiet a few cheap longblocks. I'd probably want to rebuild one if I did it so that would drive the price up but it is definitely a great option.
Old September 3rd, 2014, 07:47 PM   #25
Any updates?
Old September 4th, 2014, 12:17 AM   #26
Bobby Lane Racing
nighthawk04v6's Avatar
the crank pulley isn't bad. you should have done that from the beginning. a 1/2 impact will work as long as you have sufficient PSI going to the impact.
You think that Honda crank pulley is bad, Try 2JZ crank pulleys.
bdbconcepts and Atlas.46 like this.
Old September 4th, 2014, 06:01 AM   #27
Any updates?
Ya I am going to do the piston rings this weekend, and I'm waiting on the j35a8 heads to arrive, they were shipped yesterday so it might be a little bit =/
Old September 4th, 2014, 11:35 AM   #28
Sonnick's Avatar
So are you gonna do a before/after dyno of the J30 & J32? Please do.
Old September 4th, 2014, 11:55 AM   #29
I suppose I could. I need to find another dyno though, my local one is booked for 2 months lol. So i'll have to call around.
Old September 5th, 2014, 06:52 AM   #30
question...
are you going to port the exhaust ports on the cylinder heads?
I think you should have that done if you can afford it...
