J32A3 ECU Guide - Honda Accord Forum : V6 Performance Accord Forums
Like Tree3Likes
  • 2 Post By nighthawk04v6
  • 1 Post By qaz393
Old September 29th, 2014, 07:20 PM   #1
J32A3 ECU Guide
So i recently installed the J32A3 ecu onto my car.
First, Obtain a J32A3 ECU
Removing the ECU is an easy task under the radio unit of the car
Everything was plug and play minus 3 wires that needs to move around.
Wires that need to move around are all in the Grey plug which is "A".
J30 J32
A13 A30 (Cruise control wire from clutch)
A28 A1 (SG4)
A31 A12 (VCC4)
The ECU programmed fine using the Maxidas DS708. Use the honda menu of this machine and not acura. I have not been able to change the VIN on the ECU and its still the TL's
Review of the ECU vs stock. Smoother drive experience in first gear in traffic. More torque and less lugging when in high gear low rev.
Negative: I am sort of getting a minor rev hang when shifting. Not sure if its the 3.7 TB affecting it but my old ecu never did.
Currently after a couple day driving, my long term fuel trim is at around -03.9% which i have no idea how to interpret it.
Old September 29th, 2014, 08:48 PM   #2
Shaynk253's Avatar
What was your original goal in installing this? Is it required for other mods you've done or is it a stand alone upgrade?
Shaynk253 is offline   Reply With Quote Quick reply to this message
Old September 29th, 2014, 11:46 PM   #3
My original plan was to do a j32a3 swap as my engine wasn't running before but now it's fine. I just had this laying around so I might as well try it out. In process of building a j35 which I'll drop in next year
Old October 5th, 2014, 05:01 PM   #4
Banned
Are you just running the ecu with your j30?
6speedo is offline   Reply With Quote Quick reply to this message
Old October 5th, 2014, 05:10 PM   #5
I do notice that I have less power at 1000-2500. Above that I think I pull harder than the j30 ecu.
I'm running with the j30 modded
Old October 5th, 2014, 10:56 PM   #6
Banned
Sweet . I'm building a j32 right now . And my ecu comes in this week sometime
Old October 7th, 2014, 11:22 AM   #7
Banned
So what exactly do I need to install my tl ecu ? I need to move the wires around then have it programmed and that's it ?
Old October 7th, 2014, 11:44 AM   #8
immobilizer program will let it run.
moving the wires around allow for cruise control to work and no check engine light
Old December 3rd, 2014, 10:19 AM   #9
Mikemasta's Avatar
Sorry to bump an old thread, but would anyone know what wires I would need to swap if I'm running an auto J32a3? PRNDL on my cluster isn't illuminated anymore (doesn't show what position trans is in), I get harsh up/downshifts and it's not picking up transmission speed.
Mikemasta is offline   Reply With Quote Quick reply to this message
Old December 3rd, 2014, 10:27 AM   #10
Same wire for sure but there is the automatic transmission plug in the middle. Look at the pin out diagram. Also the tl uses sport shift so u might be better off with a stock ecu with a piggy back.
Old December 3rd, 2014, 10:29 AM   #11
Actually some of those wires. U need to refer to both diagrams to do have it work with the j32 ecu.
Old December 3rd, 2014, 05:09 PM   #12
Bobby Lane Racing
nighthawk04v6's Avatar
there are two types of J32a3 ECU. 04-05 is Motorola, 06-08 is Kehnin. completely different wiring schematics.
thisaznboi88 and NightCruiser like this.
Old December 3rd, 2014, 08:12 PM   #13
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
Originally Posted by qaz393 View Post
......Negative: I am sort of getting a minor rev hang when shifting. Not sure if its the 3.7 TB affecting it but my old ecu never did.
I think I have heard of this issue before on Acurazine.com; among 1 mod to the persons car was this same 3.7 manifold and T/B. However, this was on a 03 CL-s w/ J32A2
Old December 4th, 2014, 01:43 PM   #14
Mikemasta's Avatar
In my case I have the Motorola ECU then since mine is an 05.
Old December 8th, 2014, 07:31 PM   #15
Mikemasta's Avatar
I just repinned the grey connector A, what else am I missing out? I am using the Alldata pinouts for both ECUs as reference if that helps. I'm a total noob at this and kinda stuck at the moment...
Old December 8th, 2014, 07:39 PM   #16
Auto is different due to sport shift. Its gonna be a bit more work than manual
Old December 8th, 2014, 07:39 PM   #17
Where u located?
Old December 8th, 2014, 07:57 PM   #18
Mikemasta's Avatar
I'm in Scarborough (Ontario). I'm looking at connector C now and it's racking my brain!
Old December 8th, 2014, 08:13 PM   #19
The Jester
... Would sportshift be available to wire in on say paddle shifters or something like it if an AAV6 put in a 05 ecu from a donor car with sport shift?
Old December 15th, 2014, 10:22 AM   #20
so little update. p r n d works. sport shift will require the shifter box to move it into m mode and then paddles added if wanted.
thisaznboi88 likes this.
Old March 4th, 2015, 12:59 PM   #21
J30 J32
A28 A1 (SG4)
A31 A12 (VCC4)
Awesome read. My 03 is down getting a j32a3 swap right now. Trying to find the 04-05 TL 6 speed ecu.
Did you have to do anything with the immobilizer ?
spectre86 is offline   Reply With Quote Quick reply to this message
Old March 5th, 2015, 11:18 PM   #22
u have to get it programmed with a computer. a keysmith for car should be able to.
Old March 6th, 2015, 07:12 AM   #23
Or get a Fly100 off ebay for 140 bucks and do it yourself. You can then program keys too.
screaminz28 is offline   Reply With Quote Quick reply to this message
Old June 3rd, 2015, 10:38 AM   #24
does is matter if its Honda or acura? the Honda dealership is telling me that their scan tool cant work with an acura ecu and I need to go to a acura dealership.
everything iv read on this site about this swap, nothing said anything about that. been running the j32a3 with the j30 ecu for about 2 months now and want to get it switched.
Old June 3rd, 2015, 11:37 AM   #25
accord325's Avatar
^ There full of crap. I had my J32 ECU flashed at Brandon Honda.
Old June 3rd, 2015, 11:56 AM   #26
so their can tool plugs/play identical as if the stock j30 ecu was in there? nothing different? or a different menu?
