Bad purchase j32 heads ruff - Honda Accord Forum : V6 Performance Accord Forums
Like Tree3Likes
  • 1 Post By Tony0891
  • 1 Post By 6speedo
Old October 7th, 2014, 08:52 PM   #1
Banned
Pulled the heads off of a motor I bought and pulled the valves and it doesn't look good . I don't believe this is salvageable ! motor was left in the rain this is the aftermath .
6speedo is offline   Reply With Quote Quick reply to this message
Old October 7th, 2014, 10:08 PM   #2
accord325's Avatar
I can't see the pics, maybe its my phone
Old October 7th, 2014, 10:49 PM   #3
head can be machined buy the valve and springs need to go in the trash
Old October 7th, 2014, 11:57 PM   #4
Banned
Cleaned it up and it's not as bad as I thought. Got some mdx valves from a the guy I bought it from .
Old October 7th, 2014, 11:59 PM   #5
Banned
The springs are in good condition . The valves were not but I'm and looking into some super tech springs
Old October 8th, 2014, 05:59 AM   #6
pa1nt13aller's Avatar
Hey I have some j32a3 heads that are in very good condition. 85k miles. Have been sitting out of the car from salvage for about a month. Let me know if your interested I'll sell very VERY cheap.
Old October 8th, 2014, 02:53 PM   #7
Banned
I cleaned mine up and they weren't really as bad as I thought . But how much were you thinking
Old October 8th, 2014, 11:10 PM   #8
The Jester
Aye those actually aren't bad. I would grab these heads if you wanted to buy his^^^
Old October 13th, 2014, 02:50 PM   #9
Tony0891's Avatar
I actually started porting and polishing mine this weekend
accord325 likes this.
Tony0891 is offline   Reply With Quote Quick reply to this message
Old October 13th, 2014, 03:41 PM   #10
accord325's Avatar
Make sure to finish with at least a 600 grit wet sand on combustion chamber. Each chamber took me approximately 2 hours
Old October 13th, 2014, 04:59 PM   #11
Banned
For the combustion chamber I used a Dremel with a steel wire wheel then 120 grit flap wheel then I sanded it with 320 ,400 ,600 grit sand paper all wet and polished it with a buffing wheel and black Emory rouge
Old October 22nd, 2014, 05:53 PM   #12
Banned
build so far . What the head looked like before I started the second one . Finishing it up and sending both out to get decked next week
pa1nt13aller likes this.
Old November 6th, 2014, 12:00 PM   #13
Banned
Buttoned up the bottom of the motor last night
Old January 27th, 2015, 05:53 PM   #14
Tony0891's Avatar
W. Got busy with work but this is how it's sitting right now . But I lost my timing key so I have to order another one
Old January 28th, 2015, 12:47 AM   #15
The Jester
What the heck is a timing key
Old January 28th, 2015, 06:20 AM   #16
its that little square that goes on the crank to lock the pulley
Old January 28th, 2015, 08:45 AM   #17
Tony0891's Avatar
What's he said . It sits inside of the crank pulley . It's only ten bucks but it's M.I.A
Old February 17th, 2015, 09:37 AM   #18
Tony0891's Avatar
Just have a ton of wires to connect
Old February 18th, 2015, 07:06 AM   #19
Tony0891's Avatar
I started the car last night but I had a surging idle . Not sure what exactly is causing it .
I'm pretty sure my exhaust is leaking because it was pretty loud. Did any of you guys have gaskets on your jpipe ? Also do have any idea what may be causing this issue.
Old February 18th, 2015, 07:21 AM   #20
used RTV copper on the j-pipe as a gasket
Old February 18th, 2015, 10:40 AM   #21
Tony0891's Avatar
I'll have to check that out
Old February 19th, 2015, 09:34 PM   #22
Tony0891's Avatar
. Found my vacuum leak will be fixing it Monday
