Help - Honda Accord Forum : V6 Performance Accord Forums
Old November 1st, 2014, 04:01 PM   #1
Banned
Help
So today was torquing down the scrawl hearing cap bolt and one broke off . this was on my j32. Would the same part from a j30 possibly fit ? Or does anyone possibly have one ?
6speedo is offline   Reply With Quote Quick reply to this message
Old November 1st, 2014, 05:28 PM   #2
So, a bolt broke?
Old November 2nd, 2014, 11:43 AM   #3
Banned
Yeah
Old November 2nd, 2014, 11:44 AM   #4
Banned
Originally Posted by simione View Post
So, a bolt broke?
Yeah it snapped off in the side
Old November 2nd, 2014, 11:57 AM   #5
The 3.0 part numbers for those bolts are the same
Old November 4th, 2014, 04:10 PM   #6
Banned
Yea I was thinking I needed to get the bearing cap which they don't sell
Old November 4th, 2014, 04:28 PM   #7
accord325's Avatar
I'm not following. Tap the bolt out an get a new one
Old November 4th, 2014, 04:51 PM   #8
Tap it out and get all new bolts and check your clearance
Old January 28th, 2015, 08:51 AM   #9
Tony0891's Avatar
I had to get it retreaded . The end was pretty destroyed . Be cause the tapping tool was having an issue gripping the slanted end of the bolt . But all is well no besides the fact I have lost the timing key .
Tony0891 is offline   Reply With Quote Quick reply to this message
Old January 28th, 2015, 11:17 AM   #10
M90SC Boosting 13PSI
NVA-AV6's Avatar
The bearing caps are machined to the individual block and ARE NOT REPLACEABLE. Both the block and caps are assembled then the block is "Align Bored" to get all 4 main bearing journals in perfect alignment. You need to remove the broken bolt from the cap or trash the block.
BTW, spec is only 36ftlbs of tourqe, HTF did you snap off a M10 bolt......
Old January 28th, 2015, 11:25 AM   #11
accord325's Avatar
Does Tony0891= 6speedo ??? I'm a little confused here
Old January 28th, 2015, 06:02 PM   #12
NVA-AV6's Avatar
Eaither way based on the pics he took of the block after reinstalling the pistons this engine is toast, pitted cylinder walls is no bueno and I dont know what was used to rehone the cylinders but it was far from correct.
Old January 30th, 2015, 09:44 AM   #13
Tony0891's Avatar
After those pictures the motor was completely take. Apart again and take to a local machine all the cylinders were rehoned and the motor was hot tanked. Along with the bearing cap being retreaded . Hey man I was trying to get in touch with you a while back . You worked on my cousin David's car av6speed I just got your mdxspacer from him the other day .
Yes
Old January 30th, 2015, 09:46 AM   #14
Tony0891's Avatar
Help
And as for the bolt braking I had a faulty torque wrench from harbor freight and I had a friend torquing down the bolt and he just kept going til it broke
Old January 30th, 2015, 12:28 PM   #15
Carpe Diem
ikethegreat's Avatar
PM me which account you would like to keep. Having multiple accounts is against the rules. If I don't hear from you soon, I'll make the pick myself.
Old January 30th, 2015, 06:08 PM   #16
Tony0891's Avatar
I got locked out of the other account so I guess I'm gonna keep this one
