J Series Upgraded Piston Rings - Honda Accord Forum : V6 Performance Accord Forums
Like Tree8Likes
  • 1 Post By qaz393
  • 1 Post By qaz393
  • 1 Post By accord325
  • 1 Post By vang1320
  • 3 Post By NVA-AV6
  • 1 Post By thisaznboi88
Old November 7th, 2014, 08:22 PM   #1
accord325's Avatar
Sorry if you were expecting to find me posting upgraded piston rings. This is more of a question.
I found JE pistons that have performance ring, but do any of these fit ?
JE Pro Seal Ring Search - JE Pistons
Point A to B
NA.... Till I Spray
Old November 7th, 2014, 10:42 PM   #2
j30 or j32/j35?
Old November 7th, 2014, 10:45 PM   #3
honda gives the spec for the top two rings which are 1.2mm thick for both
Old November 8th, 2014, 01:45 PM   #4
accord325's Avatar
J35. I dont care about my J30 much anymore lol
I'll be pushing a 100shot through the J35 and would prefer stronger rings
Old November 8th, 2014, 02:03 PM   #5
Get k20 piston.
bigballer8526 likes this.
Old November 8th, 2014, 05:46 PM   #6
accord325's Avatar
This is specifically to piston rings and not the actual pistons.
Old November 8th, 2014, 07:26 PM   #7
do it right and throw 30psi at it in the future
Old November 8th, 2014, 07:43 PM   #8
^ going to need to resleeve the block if you are dreaming about 30psi.
Old November 8th, 2014, 07:46 PM   #9
yup. sleeves, piston and con rods. how much hp can the stock crank handle???
i think theres a guy pushing 22psi 730whp on race gas on a j35 with piston and conrods. gonna ask the tuner if the sleeves and crank were stock.
dynamotorsports acura tl
thisaznboi88 likes this.
Old November 8th, 2014, 07:47 PM   #10
do share if you find out
Old November 8th, 2014, 07:47 PM   #11
accord325's Avatar
This is how I translated your comment
" Spend another $6k, blow your tires off and go nowhere"
$6k doesn't account for suspension or trans work"
Point A to B
NA.... Till I Spray
Old November 8th, 2014, 08:45 PM   #12
LSThatch did that on a completely stock J32A2 longblock. Took out one motor with a rod thru the block when it overboosted I think. Second one had damage because of a 7600rpm burnout (stock valvesprings).
Now, unless he has made some other changes, (thread hasn't been updated in a while)I think he is still running a stock longblock with upgraded valvesprings.
screaminz28 is offline   Reply With Quote Quick reply to this message
Old November 11th, 2014, 03:38 PM   #13
accord325's Avatar
Anyone know where to find, or have exact specs. for our piston rings?
I am trying to get slightly larger gaped rings from "Total Seal" to build a high nitrous motor.
Old November 11th, 2014, 08:44 PM   #14
The Jester
Do you mean over gap as in technically too large for the bore or a larger gap between ring and bore?
I had a link about two years ago when i was thinking boost... may try to find it again. You intending to still keep all three rings?
Old November 11th, 2014, 08:46 PM   #15
thicker gap?
Old November 11th, 2014, 09:37 PM   #16
accord325's Avatar
Piston ring end gap, as rings "end to end". Essentially allowing more gases to escape. It does lower compression a hair but is said to help with nitrous engines.
Total seal has "gapless" compression rings that have shown to raise HP on V8's by 28whp. I believe they are harder on the cylinder walls. I'm not too versed on this topic though.
Piston Ring End Gap Recommendations
Old January 14th, 2015, 10:36 AM   #17
total seal rings are junk. As least form my experience. If you want to run larger end gaps, just get some OEM or hastings and set the ring end gaps yourself.
accord325 likes this.
vang1320 is offline   Reply With Quote Quick reply to this message
Old January 14th, 2015, 10:57 AM   #18
M90SC Boosting 13PSI
NVA-AV6's Avatar
I just saw this so sorry if late to the party. I built 3 engines with Total Seal rings, none of the three seated and burned oil badly even after following Total Seals instructions and using their "special" cylinder lube. Ended up replacing with stock after a quick rehone and no more issues with any of the engines.
Old January 14th, 2015, 11:34 AM   #19
they should be called total steal. Jack your time and money.
Good looking out Paul!
vang1320 likes this.
