Onto the next one /request/ FIC to Auto - Honda Accord Forum : V6 Performance Accord Forums
Old February 14th, 2015, 12:36 AM   #1
The Jester
Finally decided to take this rotting AEMFIC unit sitting in the corner and put it to the 2003 in the corner.
Any collective information on ports, connctors, pins, depinner, etc that I will need would be appreaciated to collected here.
As well as information on wiring diagrams or if anyone has a more simplified guide of the rewiring.
I have decided I can not go MT, and I can not go acura trans for this reason. Thus I am stuck with the aem and AT options to smooth out some of my power and see what is going on. Any and All help is to die for.
Old February 14th, 2015, 06:06 AM   #2
M90SC Boosting 13PSI
NVA-AV6's Avatar
The FIC connections have nothing to do with AT or MT, as long as the existing harness is wired right it will work with either.
Old February 14th, 2015, 07:48 AM   #3
The Jester
I was planning to build one from scratch, however I do have a manual boomslang harness laying around somewhere. Do you mean that I could use that direct plug and play?
Old February 14th, 2015, 08:23 AM   #4
You can use the MT one and just use connector C from your stock wiring. Its going to be a ***** to feed in but it will still work correctly. good luck
Old February 15th, 2015, 10:20 AM   #5
Sonnick's Avatar
Oracle, is this the one you bought from me? If so, I'm pretty sure it's Paul's harness and will work fine. I initially thought the AT harness was different but I am glad you can use it!
Instagram = j30_allmotor
Old February 15th, 2015, 12:01 PM   #6
The Jester
... Been holding this for way over a year because I thought I had to repin C or something to that effect.
You guys are telling me I can use this harness and just run connector C direct to ecu?
Old February 15th, 2015, 01:21 PM   #7
Sonnick's Avatar
^ I honestly thought you did too...
Old February 15th, 2015, 02:21 PM   #8
The Jester
well, plugged her all in, all that's left is a white wire, and two wires that say they're 02 bank modifiers that look like they've never been touched. White is switched 12vdc output...?
Looks like that's just an auxilary replacement for the stock yellow alt wire.
Does anyone have a basemap? Or is this too old, trying to search + contacting aem
Old February 15th, 2015, 02:28 PM   #9
i think those are for aftermarket wideband
AEM will be of no help. I think Paul is the only one that knows how to tune it correctly. So why don't you give him a holla.
Old February 15th, 2015, 06:29 PM   #10
NVA-AV6's Avatar
Correct
How's that hope and change working for you???
Old February 15th, 2015, 06:33 PM   #11
NVA-AV6's Avatar
White wire is used to either turn on logging internally (worthless) or switch between two different maps.
Old February 15th, 2015, 06:45 PM   #12
See pages 12-14 of closed loop tuning solution with FIC on this website
Old February 15th, 2015, 06:49 PM   #13
Closed loop AFR with fic solution
