J35Z engine build - Honda Accord Forum : V6 Performance Accord Forums
Like Tree8Likes
  • 4 Post By yungone501
  • 2 Post By yungone501
  • 1 Post By accord325
  • 1 Post By yungone501
Old February 18th, 2015, 10:17 PM   #1
yungone501's Avatar
J35Z engine build
PARTS:
New Honda J35Z3 short block with 10.0:1 compression
J37A2 cams and dual VTEC heads
Custom CNC'd intake manifold
ID1000 fuel injectors
J37A2 ignition coils
J37A4 oil pump conversion
Two range cooler Autolite copper plugs
J35A8 ECM and harness
J37A4 throttle body
EGR block off
J37A2 lower runners
J35Z3 stock head gaskets
ARP head studs
Oil cooler and thermostat w/remote filter
2008 TL-S auto trans
J35Z cats w/custom heat shields (temporary)
J37A4 stock j-pipe w/DEI Titanium wrap (temporary)
J35A8 AC compressor (YUP!)
TWEAKS:
Piston ring gaps opened up for safety
Ceramic coated pistons, chambers and valves
Tuned with FlashPro
Tuned by Myself
It will be broken in before the turbo setup goes on. Just got the engine in last weekend and hopefully get her fired up soon. I'll keep things updated for everyone.
Ceramic coating
Sonnick, simione, jiga21 and 1 others like this.
Automotive Electrical Specialist
yungone501 is offline   Reply With Quote Quick reply to this message
Old February 18th, 2015, 10:43 PM   #2
accord325's Avatar
Good lord, should be nice. How much boost u going to run and how much gap did you file into the rings?
Old February 19th, 2015, 12:50 AM   #3
yungone501's Avatar
No more than 12lbs on her. I was at a wall when I ran the stock j35a8 at 15lbs. That's when knock counts got too difficult to control. I put the top ring at .017" and the middle at .025". Better too much than not enough when dealing with forced induction.
Old February 19th, 2015, 07:55 AM   #4
Sonnick's Avatar
Sweet build! Definitely will be an interesting setup and I am excited to see the results. Now...are the J37a2 heads really that much of an improvement over the J37a1? I know Dual VTEC is a great option for us J series guys, I'm just wondering really.
Also, any pics of the intake manifold?
Instagram = j30_allmotor
Old February 19th, 2015, 08:19 AM   #5
05accord6spd's Avatar
Your build thread over at acurazine is crazy are you still putting this in a 6th gen ?
Old February 19th, 2015, 10:32 AM   #6
accord325's Avatar
What rings you using?
Point A to B
NA.... Till I Spray
Old February 19th, 2015, 12:36 PM   #7
yungone501's Avatar
Thanks man. This will be my first time dealing with the dual VTEC heads so its unknown territory as far as advantages go. Comparatively speaking, all the later model 3.7's (10 MDX, 09 RL and 09 TL) are all producing nearly the same amount of horsepower and torque but the 10 MDX doesn't even have dual VTEC heads...and makes max torque 500 RPM's sooner than the other two models!? But, I'm convinced that there may be some good to find in these heads especially for those running any form of boost or nitrous where exhaust gases need to have maximum flow and/or minimum restriction. Forced induction (as you may or may not know) is greatly affected by any hinderance in exhaust gas evacuation and the higher lift profiles of the j37a2/a4 heads during VTEC engagement should compliment this perfectly. Just to give you an idea between the 10 MDX (intake VTEC only) and the 09 TL (intake and exhaust VTEC) 3.7's, the exhaust lobe measures 36.760mm and 37.370mm respectively. And both cams use the same base circle diameter if my memory serves me correctly.
The intake was CNC machined and hand welded by Matt Hickam of Hickam Series Fab in Ft Worth, Tx. Here's a few pics:
And in raw finish
Smoothed Venturi style runners.
Lol, yeah. That old 300k+ mile POS!
Oem. If you can avoid heavy knock, stock rings can actually endure moderate boost levels very well. It's when you don't open up the gaps things turn to **** real quick! Just ask this j37a4 here who was subjected to some very serious heat from detonation:
Sonnick and Kschwiggy like this.
Old February 19th, 2015, 01:25 PM   #8
accord325's Avatar
What would u gap the rings at for 150shot direct port nitrous J32 12:1 compression?
Old February 19th, 2015, 02:04 PM   #9
Sonnick's Avatar
For you? Baby Gap
Old February 19th, 2015, 05:41 PM   #10
accord325's Avatar
^ love the baby gap, that's where I buy all my cloths.
I was told (TB Motorworx) 100shot on stock rings is safe. So I guess an exacting amount per cylinder with direct port is safe also. Who know how much nitrous one cylinder is getting over another on a single nozzle set up.
Back to the topic, great build !!
Will that IM fit under the hood???
Sonnick likes this.
Old February 21st, 2015, 02:11 AM   #11
yungone501's Avatar
Maybe .01-.02" tighter than my specs given above per ring? There's really no telling since the name of the game is simply not too much that blow by happens and not too little that ring contact occurs. It really has more to do with how much power will be added by forced induction (or spray) than any other factor. With higher power comes more heat and with more heat comes a heightened chance of ring to cylinder contact during moments of increased power output. For any mild amount of boost or spray, I've stuck with the bore x .005" formula for the top ring and then bore x .007" for the second. Bore being measure in inches. Always keep oil rings at their oem specs in regards to gap.
For you? Baby Gap
Good to see Bryan is still bustin' people's chops over here.
I consider their recommendation to be a very loose statement. As in a good standard by most whom of which have no, little or "know it all" amounts of knowledge to running nitrous. That's because (as you say) most people run the single nozzle setups and have much higher potential of leaning out a close or over feed cylinder when spraying. I've personally ran 200hp+ shots through a single nozzle using OVER 54 bottles of nitrous on a 130k mile motor before finally blowing guts and nuts out the bottom...due to running cylinder 2 too lean. Hahaha
Direct port is supreme. Equal distribution of air, fuel and nitrous into each cylinder will definitely bring longevity to the motor. Well, so to speak.
Modestly speaking, hell no that intake doesn't fit under the hood!!! I'm going to have to have a custom hood made for the damn thing. That's actually my biggest tragedy with the car right now. But hey, if that's my biggest than I guess I'm fortunate.
Old March 5th, 2015, 10:15 PM   #12
yungone501's Avatar
Should be on the road soon...
http://youtu.be/_rKlOGIJ8HM
accord325 likes this.
Old March 5th, 2015, 10:40 PM   #13
accord325's Avatar
It's alive !!!!
