What are the parts for a 3.7l manifold for an auto? - Honda Accord Forum : V6 Performance Accord Forums
Old March 1st, 2015, 10:50 PM   #1
Note: I have searched but couldn't find answers to my specific question
1. Is there a 3.7l intake manifold WITHOUT the butterfly valve (just bolts up like the 3.0 with no slot for one)?
2. If not, would I have to buy the 3.7l intake manifold, top plate and then use a Butterfly Delete from ebay?
Manifold part # 17160-RK2-A00 (sonnick suggested) 17160-R70-A01 (what I'm looking for as the part for the electronic valve is closed and would this one work)?
manifold plate #: 17140-RK1-A11 (is there a cheaper one)?
nick650 is offline   Reply With Quote Quick reply to this message
Old March 1st, 2015, 11:09 PM   #2
just buy the plate without the buttlerfly. Not sure why you need to get the delete from. You don't have a plug for it since your AT!! You will also need a New throttle body. So factor that into your cost also
Old March 1st, 2015, 11:21 PM   #3
What is the part number for the plate if you could?
How will I cover the hole (where the actuator sits) if I don't plug it up? Is there a 3.7l intake manifold that is already without the spot for a actuator?
I bought the new throttle body for 110$ already ^_^
Thanks
Old March 1st, 2015, 11:40 PM   #4
Look up the 08+ accord AT. it has a plug for the hole on the manifold itself. Go to hondapartcheap.com . I'm teaching u how to look up parts so u can do yourself next time. Good luck
Old March 2nd, 2015, 12:19 AM   #5
So that means I don't need a new top plate and I can use my old top plate?
Thank you for your help ^_^
Note: I have found the manifold: http://www.hondapartscheap.com/honda...me=manifold-in
If i could re-use my top plate, I can do this mod for under 300 bucks
Last question: I know that the manuals use the butterfly for better engine performance, but does this need to be on an automatic car?
Old March 2nd, 2015, 07:03 AM   #6
no you still need a top plate.
You need to pick coupe, part # 3
INTAKE MANIFOLD (V6) for 2010 Honda ACCORD COUPE
Old March 2nd, 2015, 10:31 AM   #7
17116-R70-A00 (top plate) http://www.hondapartscheap.com/honda...manifold-upper
17160-R70-A01 (manifold) http://www.hondapartscheap.com/honda...me=manifold-in
Thank you very much for your help Aznboi ^_^.
