Oooo South Bend Clutch v6? - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By screaminz28
Old March 15th, 2015, 11:17 PM   #1
Found these new toys of the accord. Anyone want to give it a shot? Stage 1 looks like it hold 295tq
South Bend Clutch Kit - Stage 1 - Excelerate Performance - Japanese and European Performance Specialists!!
South Bend Clutch Kit - Stage 2 - Excelerate Performance - Japanese and European Performance Specialists!!
Old March 16th, 2015, 10:17 AM   #2
accord325's Avatar
^ I think Bozo has one of these for sale on the cheap
Old March 16th, 2015, 10:37 AM   #3
Any reason to go with stage 2 on an na motor no spray? Ill need a clutch soon and I'd like something OEM+.
Old March 16th, 2015, 10:54 AM   #4
I think stage 2 need a a lwfw. Stage one does not need an upgraded flywheel.
Cost is for clutch only no flywheel
Old March 16th, 2015, 11:20 AM   #5
accord325's Avatar
^ In case you end up making more power. I went OEM and literally a few months later was spraying 100 at it, and wouldnt hold...
Old March 16th, 2015, 11:33 AM   #6
I think regular stage 2 would be good if you just want to do a 75-100 shot. Anything larger would require the endurance or high stuff.
I wonder if you mix and match a DMF with a sprung clutch. Extra dampening and less driveline shock?
Old March 16th, 2015, 08:28 PM   #7
Not a fan of Excellerate showing a flywheel in the pic. I know it's a stock photo but it's not even noted that the flywheel is not included (at least not obviously.)
accord325 likes this.
screaminz28 is offline   Reply With Quote Quick reply to this message
Old March 18th, 2015, 09:58 AM   #8
bozos_si's Avatar
I contacted XLR8 and they have a new clutch out. Right now they have a deal for $1100 shipped.
It will hold 340 tq. It will include a conversion pressure plate and Organic friction disc meant for street driving. The flywheel is made by AASCO.
AASCO Motorsports Flywheels - Excelerate Performance - Japanese and European Performance Specialists!!
Also the warranty is 12 mos/12k on manufacturer defect.
Our kit is superior. It uses better products, holds more torque, and will last longer.
Old March 18th, 2015, 11:16 AM   #9
Sonnick's Avatar
Least they're honest about AASCO making the Flywheel. CM tried to tell me they made it, yet I had the AASCO one and theirs next to each other and the only difference was the "AASCO" sticker was scraped off. That's none of my business though (insert Kermit the Frog photo)
Instagram = j30_allmotor
Old March 18th, 2015, 11:27 AM   #10
Organic is the way to go. I hate kelavr since it is unforgiving, and it all so burns out faster.
Old March 18th, 2015, 12:56 PM   #11
accord325's Avatar
Which stage hold 340tq? Thats at the Fly im guessing. I payed $1100 shipped for a Spec 3+ (Holds 690tq) and spec LWFW. The clucth also eliminate the stock PP
Point A to B
NA.... Till I Spray
Old March 18th, 2015, 01:05 PM   #12
and chatter with the spec clutch?
Old March 18th, 2015, 01:15 PM   #13
accord325's Avatar
Not sure,not installed yet
Old March 18th, 2015, 02:21 PM   #14
bozos_si's Avatar
I believe stage 1 cause when I was talking to him that was what I was looking for. They may have others. They also told me that the reason it is $1100 is a special deal right now because it hasnt hit the public yet. They plan on hitting the public with it in the next couple days. When that happens price will go up.
Old March 24th, 2015, 10:58 AM   #15
bozos_si's Avatar
Received it today. The clutch says Exedy on it. I emailed them to see if that is who they had make the clutch for them.
Old March 24th, 2015, 11:24 AM   #16
shouldn't say exedy. It should say southbend they make there own clutch
Old March 24th, 2015, 11:49 AM   #17
bozos_si's Avatar
I didn't get south Bend. I bought one that excelerate made themselves. They did only a couple companies make some clutch components and that is why it says exedy on part of the clutch.
Old March 24th, 2015, 11:59 AM   #18
ugh... southbend makes excelerate clutch. they are the only one with the red pressure plate.
http://acurazine.com/forums/performa...review-926577/
Old March 24th, 2015, 12:13 PM   #19
bozos_si's Avatar
Got ya. Then that is what I got. Wasn't very happy with the packaging though.
Old March 24th, 2015, 12:17 PM   #20
okay just making sure.
Old March 24th, 2015, 01:35 PM   #21
bozos_si's Avatar
Still had me worried when it said Exedy right on the clutch. Getting super pissed my car isnt back so I can get the swap in and this clutch kit.
Old March 24th, 2015, 01:36 PM   #22
take pix. also do you have the tool to align the spines?
Old March 24th, 2015, 01:48 PM   #23
bozos_si's Avatar
Yes they sent that. I don't have a way to post pictures.
Old March 24th, 2015, 02:08 PM   #24
post for ya and added you on fb
Old March 24th, 2015, 02:21 PM   #25
bozos_si's Avatar
Approved.
As you see it says exedy on it. But as I said they told me that "only some manufacturers make clutch components but exedy did not make their clutch".
Old March 24th, 2015, 02:25 PM   #26
they probably use the spring disk and south bend just stuck their clutch material on it.
Old March 24th, 2015, 03:19 PM   #27
Mmmm
Grand_hustle17 is offline   Reply With Quote Quick reply to this message
Old March 26th, 2015, 04:15 PM   #28
How different is that pressure plate from a exedy one that isn't red?
Old March 26th, 2015, 04:17 PM   #29
the one that isn't red has the self adjusting springs on it. Its why our stock pressure plate sucks so much.
Old March 28th, 2016, 01:17 PM   #30
Approved.
Any reviews of the clutch a year later?
06V66SPD is offline   Reply With Quote Quick reply to this message
