3.2 vs 3.5 6MT TL ECU - Honda Accord Forum : V6 Performance Accord Forums
Like Tree3Likes
Old April 9th, 2015, 02:56 PM   #1
O.k you guys im sure im super annoying by now but i think im going to mod my TL as much as i can this year and maybe go for the highest NA numbers in a base 3G TL... Whatever that is (non built)... However i have a random question for you tuning gurus... I will be doing hondata and ordered a 3.5 MT type S ECU today.. Now random quesrion... Before tuning is there any difference in the 3.2 6MT base ecu map vs 3.5 type S?... Main thing i want is bumped revs to 7000 maybe 7100 and removed limiter and of coarse the tuning lol. But is it worth it performance wise to drive around with 3.5 ecu vs 3.2 for a while?.. Im now broke lmao
04 RRP 6MT TL- 273/223
Grand_hustle17 is offline   Reply With Quote Quick reply to this message
Old April 9th, 2015, 03:37 PM   #2
accord325's Avatar
^ You can change your redline with Hondata. The main thing you should be looking out for if you dont want to solder is a MT ECU. AT you will have solder a bridge for cruise control.
Simi has a TL-S Ecu for sale. Great price too!
Old April 9th, 2015, 03:44 PM   #3
I just bought a 6mt ecu for $165 shipped. Its getting sent to me tomorrow... May just buy hondata at the end of the month...
Old April 9th, 2015, 03:47 PM   #4
accord325's Avatar
Well there you go. You should be set
Old April 9th, 2015, 03:57 PM   #5
Hahahhaaa i think you guys miss my question lmao...
Old April 9th, 2015, 04:22 PM   #6
Well yeah.. The 3.5L ECU will run richer on a 3.2L. So don't install it until you get that flashpro.
. Hondata will flash the ecu with new software and wipe the OEM base map. So it doesn't really matter afterwards. Just make sure you get the one that hondata recommend in terms of part number ranges.
Grand_hustle17 likes this.
Old April 9th, 2015, 05:12 PM   #7
It can be install... since the O2 will correct things out but it will be pig rich at wot for sure
DomGSR-T is offline   Reply With Quote Quick reply to this message
Old April 9th, 2015, 05:33 PM   #8
Speaking spanglish now man lmao.. Idk anything about hondata.. Until today hondata wasnt even going to be a thought until next year.. A thought lol
Gotcha... Cool
Old April 9th, 2015, 05:37 PM   #9
I can't!! I am da azn boi bemember.
Old April 9th, 2015, 05:48 PM   #10
he will also throw codes for the ftp sensor. probably wont affect how the car runs, but it will throw the code. I think there was one other sensor, but I can't remember
Old April 9th, 2015, 05:58 PM   #11
Even on the TL? I know a lot of sensors needs to be disable on the Accord...
Old April 9th, 2015, 06:05 PM   #12
Ahh, maybe so. I thought only the type s had the ftp sensor
Old April 9th, 2015, 07:08 PM   #13
Well ill obviously have the patch harness
Old April 9th, 2015, 09:44 PM   #14
The Jester
What you mean you can have AT work with hondata
Old April 9th, 2015, 09:48 PM   #15
he means you can use an automatic Ecu
FlashPro 07-08 Acura TL
Old April 9th, 2015, 10:32 PM   #16
The Jester
Okay so in theory a 07 AT dropped into an 03 AV6 would allow for hondata tuning given the right ecu.
Old April 9th, 2015, 11:04 PM   #17
No, hondata made it so you can use an AT ECU for a manual application. MT tls ecus are rare and limited.
So the software itself will alter AT ecus to work with manual transmissions to give users more options as far as ecus to buy for the conversion. However as far as I understand hondata does not support the use of an automatic transmission (regardless of ecu) with they're software.
PS: I don't know if "software" is the right term for what hondata is. Also correct me if I'm wrong but the tls 07-08 ecus for automatics control the transmission's sh-awd system and thus cannot be used. The 07-08 base AT ecus can be used because they don't control the transmission.
Old April 10th, 2015, 02:53 AM   #18
The Jester
I was hoping this answer wouldn't come up again and that I had missed something somewhere that had simply been excluded due to need for an 07 trans, maybe with different sensors or something.
In theory the AWD system would be indeed controlled by the ecu but if they were controlled through any part of the ecu that is easily manipulatable it may be supported. however flashing an AWD ecu to use on MT shouldn't be an issue as hondata would simply ignore this extra part of the ecu.
Old April 10th, 2015, 06:36 AM   #19
Hey go make your own threads lmao
Old April 10th, 2015, 08:07 AM   #20
07-08 never came with SHWAD, You must be thinking about the RL. I believe you can still use the AT TLs ecu. the oem map just get overwritten.
and the reason that you can't use hondata on the accord AT is the transmission has 4 sensor on the accord. There are 5 sensor on the TL transmission 07-08. This is also why 04-06 TL AT cannot use hondata. I think hondata website also explains that.
Old April 10th, 2015, 09:52 AM   #21
accord325's Avatar
and the reason that you can't use hondata on the accord AT is the transmission has 4 sensor on the accord. There are 5 sensor on the TL transmission 07-08. This is also why 04-06 TL cannot use hondata. I think hondata website also explains that.
^ You mean 04-06' TL AT cannot use Flashpro
Vehicle ECU Part Number FlashPro Part Number
2007-08 Acura TL Base
RDA-A82 through RDA-A84 FP-TL-US
2007-08 Acura TL Type-S (automatic and manual)
RDB-A02 through RDB-A63 FP-TL-US
2004-06 Acura TL MT
See adapter kit info FP-TL-US
Point A to B
NA.... Till I Spray
Old April 10th, 2015, 10:05 AM   #22
^ damn it you got me. But people should just go on hondata website to read if they want more info. They have a whole section of Q&A
Old April 10th, 2015, 10:13 AM   #23
accord325's Avatar
Point A to B
NA.... Till I Spray
Old April 10th, 2015, 03:00 PM   #24
The Jester
Hey I just asked if AT could work with hondata, then even ammended it to 07-08.
I'm pretty sure asking about using a modified chip and it's limitiations in a thread about using a modified chip and it's limitations is pretty par for the course.
At least I have a j pipe...
Old April 10th, 2015, 03:58 PM   #25
^ we had this conversation before. You should know better ;p
Old April 10th, 2015, 06:10 PM   #26
it wont run too rich. will be pretty much spot on. remember the j32a3 has a 270cc injector
Old April 10th, 2015, 06:20 PM   #27
^^^ that means?
Old April 10th, 2015, 06:22 PM   #28
no point of running j35 ecu unless u have a 3.5 or hondata
Old April 10th, 2015, 06:29 PM   #29
FYI 3.2L 04-06 has 270cc
3.2L and 3.5L 07-08 has 310cc
it actually might run lean which is worst then rich
Old April 10th, 2015, 10:41 PM   #30
Holy ****.. Really.. So wait.. Is 07-08 TL injectors direct swap over?.. I think i want that
