Accord v6 dyno comparison - Honda Accord Forum : V6 Performance Accord Forums
Like Tree10Likes
  • 1 Post By Sonnick
  • 2 Post By accord325
  • 1 Post By thisaznboi88
  • 1 Post By CBUS-AV6MT
  • 1 Post By Sonnick
  • 2 Post By ikethegreat
  • 1 Post By accord325
Old May 9th, 2015, 10:35 PM   #1
&mpt=[CACHEBUSTER]">
[/URL][/URL]
&mpt=[CACHEBUSTER]">&mpt=[CACHEBUSTER]">
TL-S with bolt on made 281whp. I end up making 253whp
I will try to upload better videos later. Resting before I make the long drive home
VIDEO https://youtu.be/qft1jwqH8uc<---
Link to my build thread
http://www.v6performance.net/forums/...ld-thread.html
Old May 10th, 2015, 04:57 PM   #2
accord325's Avatar
What is your Vtec set at? You should be able to smooth the band out some more.
Old May 10th, 2015, 05:08 PM   #3
5k
Old May 10th, 2015, 05:25 PM   #4
hmm... Did you try to hit my friend up in York that tuned my car?
Old May 11th, 2015, 08:02 AM   #5
Sonnick's Avatar
The numbers themselves are low, especially for a Dynapack. BUT...I was thinking that unless we know what mods the Type S has or another car on that dyno, there is no real comparison. You've never been on a dyno before, so we have no real way of comparing your numbers yet.
Perhaps you are losing compression with the Type S heads? On a Dynojet, I'd expect you to be in the neighborhood of low to mid 280s. But again, every dyno is different and there are still unknown variables. A full bolt on/Tuned Type S made 287 on Jeff Evans dyno IIRC, so don't jump to conclusions yet.
thisaznboi88 likes this.
Instagram = j30_allmotor
Old May 11th, 2015, 08:29 AM   #6
I am going to email Derek and see if he remember what that car had.
Dom going to work with me and see what happens when we raise vtec up to 5500rpm. Maybe that will make the power keep climbing instead of doing a drop from 5000-5250rpm.
Old May 11th, 2015, 08:57 AM   #7
Sonnick's Avatar
Really? I think the higher you go, the more you will dip. Mine is set at 4650 and it's a smooth transition. Obviously every car is different, but I don't think there will be such a huge variation in a similar bolt on car. Did you try lowering it from 5000 to 4900 to 4800 to 4700, etc?
Old May 11th, 2015, 10:08 AM   #8
Dom map was set At 4800-
4850. We tried 460-5200 range. While on the Dyno. The car lost power. My car has mdx camshafts. So that could be why ?? Who knows what going on.
Old May 11th, 2015, 01:17 PM   #9
accord325's Avatar
I set mine higher (5200) due to dip at 4800. Even that high there is still like a 5hp dip
Old May 11th, 2015, 02:58 PM   #10
I think you and me share a similar problem. We are using different heads with larger combustion chambers. So it doesn't act like a normal j30,32, or j35.
For now I think I am done. Just don't feel like adding more parts to it. I will be working with Dom since he wants to tweak the car a bit. But I am going to start saving up for an nsx for my graduation present
Old May 11th, 2015, 06:06 PM   #11
accord325's Avatar
I'll have to check you build thread for all your mods. I made 268/225, with a 90mm CC and overhang. If my heads were milled, then they still have a hell of a lot of room to go. As yourself, I'm happy. Car feels good and is quick (I do spray . Still have my J32 sitting in the wings.
Sonnick and Atlas.46 like this.
Point A to B
NA.... Till I Spray
Old May 12th, 2015, 04:57 PM   #12
Did you look to see what the factory vtec setting is on the mdx. Maybe that could be where the cams like it.
Also Sonnick I think you benefit the most with the lower vtec engagement because of your final drive. You never drop out of vtec
Old May 12th, 2015, 05:17 PM   #13
Per acura
The MDX's VTEC® (Variable Valve Timing and Lift Electronic Control) operates the 12 intake valves in two distinct modes. Operation of the intake valves changes to optimize both volumetric efficiency and combustion of the fuel-air mixture. At low engine speeds, the intake valves have low lift and are open a comparatively short period of time during cylinder filling. At high engine speeds where breathing is critical, the valves switch to high-lift, long duration mode to deliver the best volumetric efficiency. The VTEC® changeover point is virtually undetectable to the driver and occurs at approximately 4500 rpm
Old May 12th, 2015, 06:26 PM   #14
Sonnick's Avatar
I've never dropped out of VTEC on any shift since I've had the car. The stock ratios and VTEC point were adjusted spot on in this regard.
Any more info for the mods on the Type S?
Old May 12th, 2015, 06:40 PM   #15
The OP never replied. I know his on acurazine since someone recalled his name and said his car had the yellow tinted fogs. I have no idea what his fully bolt on was
Also at the moment I don't really care. Getting married so play time going to be over pretty soon.
Sonnick likes this.
Old May 12th, 2015, 07:16 PM   #16
Oh **** congrats man.
Like I said before don't sweat the numbers. You got great gains from the dyno time and are only a little bit off of a J35A8. I'd be happy in your shoes.
Let me know when the misses forces you to part out that car :P
Old May 12th, 2015, 07:49 PM   #17
Yeah we are going to try to get the marriage license and then just do a simple ceremony right now. Real wedding is next year.
Also looking at cars for her too. So no more modding and probably shift the time table for that nsx.
Old May 13th, 2015, 08:25 AM   #18
Sonnick's Avatar
Congrats Ken!
Old May 13th, 2015, 12:21 PM   #19
Carpe Diem
ikethegreat's Avatar
As a married man, my advice would be:
NSX > Marriage
accord325 and Grand_hustle17 like this.
Old May 13th, 2015, 12:43 PM   #20
accord325's Avatar
My personal situation is heading the other way, but congrats Ken! I got a beautiful little girl out of the relationship and wouldn't change a thing.
Old May 13th, 2015, 05:28 PM   #21
Sorry still new to understanding our accords, but why does a TL-S have so much more power than our V6? I thought its the same car with just stiffer suspension and luxury interior. From reading I understand it has different heads, but how does that make that significant of a HP increase?
zeus159 is offline   Reply With Quote Quick reply to this message
Old May 13th, 2015, 06:50 PM   #22
Sonnick's Avatar
The TL-s has a 3.5L compared to our 3.0L, among other things like higher compression and slightly better cams.
Old May 13th, 2015, 07:29 PM   #23
accord325's Avatar
TL's also have a weight issue, they need to be on diets, thus needing more powerl. No replacement for Displacement. Don't worry, these J30's hold their own
Old May 14th, 2015, 09:40 AM   #24
Sonnick's Avatar
They do, but I really wish they came with the J32. Man, these cars would've been on another level.
Old May 14th, 2015, 11:01 AM   #25
accord325's Avatar
El- swapp'ee
Atlas.46 likes this.
