need help asap clutch issues - Honda Accord Forum : V6 Performance Accord Forums
Old May 30th, 2015, 06:26 AM   #1
Hey guys i have a issue, i recently changed my clutch to a clutchmasters fx250 and aasco lightweight flywheel and now the car has engagement issues. It would go into gear sometimes but mostly wouldnt, ive changed the master cylinder and slave cylinder since and still the same issue and me and my mechanic r stumped as to whats wrong, when i would try to put it in gear the car would kinda creep foward and i would get stuck in gear if I started the car in gear, any help on what i should do because i got the job done upstate and i live in NYC so its a few hrs away from where i live
Fresh4957 is offline   Reply With Quote Quick reply to this message
Old May 30th, 2015, 10:31 AM   #2
Bleed the line or adjust the clutch pedal
Old May 30th, 2015, 02:03 PM   #3
accord325's Avatar
^ This.
Simione posted a diagram of how to adjust the clutch pedal engagement. A lot of people think the issue is the clutch most of the time, but if your clutch pedal doesn't engage or disengage properly, obviously getting in and out of gears will be difficult.
Best of luck!
