Pa1nt13aller Dyno (finally) - Honda Accord Forum : V6 Performance Accord Forums
Like Tree23Likes
Old July 20th, 2015, 05:07 PM   #1
pa1nt13aller's Avatar
Long overdue....Finally getting dyno'd tomorrow morning and I will post the results up as well as a video then. Here are my current engine mods:
-J32a3 block
-J35a8 heads decked n valve ported
-J37 intake manifold & throttle body, port matched
- V2 intake
-RV6 J pipe
-Borla exhaust
-Unorthodox underdrive pulley
-Hondata tuned
I'm guessing around 312whp :P
Here is a pic :P
757shonuff likes this.
Old July 20th, 2015, 05:32 PM   #2
05accord6spd's Avatar
283
Old July 20th, 2015, 06:11 PM   #3
270
Old July 20th, 2015, 06:37 PM   #4
275
Old July 20th, 2015, 07:18 PM   #5
467
Old July 20th, 2015, 07:39 PM   #6
The Jester
293
Old July 20th, 2015, 09:06 PM   #7
accord325's Avatar
Seriously, I'm guessing 285whp/248wtq
Old July 20th, 2015, 09:23 PM   #8
The Jester
280/240
Thats a big bottom end, with some very free flowing heads, and ported. ported will put it above 270, but drop the torque a bit. Borla constrictions might raise the torque some. Supporting mods from higher compression up to support the high hp, didnt notice PCD but I assume its there, RV6 plus hondata, allows for higher than 230 tq, +1 from the UR pulley taking some of the drag off the engine. Hope there are some cams in there
Old July 20th, 2015, 10:43 PM   #9
Just the j35a8 cams. I just hope I get above 300 at this point...
Old July 21st, 2015, 06:59 AM   #10
275
screaminz28 is offline   Reply With Quote Quick reply to this message
Old July 21st, 2015, 07:54 AM   #11
Where in Minneapolis are you getting dynoed? At map?
Old July 21st, 2015, 10:08 AM   #12
Nope at rsmotors. And of course right as I'm filling out vehicle info they tell me their rollers locked up and the dyno is not functioning....awesome.
Old July 21st, 2015, 10:13 AM   #13
accord325's Avatar
Who tuned you? Do you know how much timing you have in the car?
Old July 21st, 2015, 10:16 AM   #14
Dom tuned me. I personally don't know the advance....but we messed with it quite a bit. Dyno might be later today if it's fixed, tomorrow, or who knows when....
Old July 21st, 2015, 10:18 AM   #15
accord325's Avatar
You going to test multiple maps (lean, rich, less time, more time, etc) ?
Old July 21st, 2015, 11:33 AM   #16
Once Dom gets back to me, awaiting his email for the other calibrations. I was just going to go dyno it with my current tune but now that im delayed I can do mulitple maps. The motor on the dyno seized up they just updated me...so idk when dyno day is going to be now...hopefully soon...
Old July 22nd, 2015, 04:59 PM   #17
its blocked at work. what numbers did it make?
spectre86 is offline   Reply With Quote Quick reply to this message
Old July 22nd, 2015, 05:44 PM   #18
Reading is fundamental...
Just for clarity - I'm pretty sure paintballer means the brake on the dyno or the dyno's motor - not HIS motor.
Old July 23rd, 2015, 08:15 AM   #19
Yes thank you :P. They said they would call me when they get everything taken care of...but its been 2 days so...Ill call em later today if they dont call me back. Im sure they got backed up with all their projects since the dyno broke down....meh
Old August 2nd, 2015, 05:02 PM   #20
Sonnick's Avatar
I bumped this thread with the hope of numbers Any updates?
accord325 likes this.
Instagram = j30_allmotor
Old August 3rd, 2015, 11:52 AM   #21
Yessir just called this morning and stopping in around 11:30am tomorrow
Sonnick and 757shonuff like this.
Old August 3rd, 2015, 01:16 PM   #22
accord325's Avatar
I'm on the edge of my seat. I think the Borla is holding you back (I know) but I can pin down a number.
WHAT TYPE OF DYNO IS IT??
Atlas.46 likes this.
Old August 3rd, 2015, 01:33 PM   #23
Well I modified my borla a little bit but the exit is still the same...sadly its a mustang dyno...
Old August 3rd, 2015, 02:04 PM   #24
Where are the numbers??? Ha hah don't worry I have a magnaflow cat back that I need to modify the flange. The flange is 2.25in and I want it to be 2.5 so that it's straight 2.5 through
Old August 3rd, 2015, 02:19 PM   #25
Sonnick's Avatar
Did you dyno prior to your J32? If not, the numbers themselves will just be numbers. Regardless of dyno, as long as you go back to the same one each time, the GAINS are what matter - whether the dyno reads 280 or 230 means nothing. I will say this over and over...I made 235/194 on the Mainline and 274/238 on a Dynojet. I ran 13.28 @107 regardless of what the dyno read. Dynos are strictly tools for gauging gains from modifications and tuning. It's rewarding to know that your money was well spent.
Rich01 likes this.
Old August 3rd, 2015, 02:45 PM   #26
Nope but I will be running a baseline for one of the runs to see how much the tune gave me...I just want to see what I'm at
Sonnick likes this.
Old August 3rd, 2015, 03:27 PM   #27
Sonnick's Avatar
Good luck! Definitely interested in your tuning gains.
Old August 3rd, 2015, 10:13 PM   #28
...and...? Interested in base vs tuned.
Old August 4th, 2015, 11:07 AM   #29
Well turns out it was 2 runs for $80 not 3....so I did my current tune vs another random one with a lower vtec engagement point.
This was done on a MUSTANG DYNO, not a dynojet. Apparently mustang dyno's read lower is what I hear...
RESULTS:
304whp
250wtq
GRAPH:
Here are the 2 videos:
https://youtu.be/7y-3hbeiRGs
https://youtu.be/CDtbbnJrYyU
Old August 4th, 2015, 11:29 AM   #30
wtf 304whp on a mustang dyno? That stupid high
