HFPC Causing Heat Shield Rattle? - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By jjhuffyo
Old August 11th, 2015, 03:03 PM   #1
jjhuffyo's Avatar
Hello Community
I recently installed some RV6 Performance High Flow Pre Cats (HFPCs) on my car and ever since then I have heard a rattle noise from underneath the car in certain driving conditions.
I'm almost positive that the noise is coming from the heat shield which protects the drive axle mid-shaft which is very close to the rear pre-cat. I'll post a picture later today.
Has anyone experienced similar issue after installing the HFPC? I'm guessing most of you went with PCD instead, which may be completely different shape and size than the HFPC.
thank you,
J
jjhuffyo is offline   Reply With Quote Quick reply to this message
Old August 11th, 2015, 03:46 PM   #2
I have HFPC I don't have any noise. Check around the J-pipe and make sure nothing is busted
Old August 11th, 2015, 06:39 PM   #3
07J30's Avatar
I too have hfpc with no issues...must b something simple...have a friend rev while you check
Old August 11th, 2015, 07:53 PM   #4
Did you support the j-pipe when replacing the Pre cats? May have bent the heats shields or something. I had rattle from the shield over the steering rack on the sub frame, so I bent it a little in the opposite direction to keep a little tension on it, noise went away.
Old August 17th, 2015, 06:45 PM   #5
jjhuffyo's Avatar
Thanks guys, I will get under there and take a look this weekend when I have time.
Old August 17th, 2015, 09:33 PM   #6
does yours only rattle after the car warms up?
i also have the major rattle but only after the car heats up pretty good. i haven't had a chance to get under there yet, but i can hear it when letting off the gas and also if i'm idling i can hear it. when i shut any doors, it rattles also.
interested to see what you find
2008 Acura TL Type S - 6MT
sockr1 is offline   Reply With Quote Quick reply to this message
Old August 18th, 2015, 12:59 AM   #7
The Jester
I had issues after some time, it happens, it's a heatshield. Modify it as needed, I only had 2 screws in which was my problem. You might just have a screw loose!
Old August 18th, 2015, 01:53 AM   #8
did you just tighten or did you push the shield towards the driver then tighen?
i checked about 6 months ago when i switched my xlr8 v1 for an atlp v2 jpipe, but no screws were loose
Old August 24th, 2015, 06:26 PM   #9
jjhuffyo's Avatar
Ok so interestingly enough, there was a bolt loose - the one for the J-pipe exhaust mount. Apparently I left it loose after installing the HFPCs.
After tightening that up the rattle went away.
sockr1 to answer your question no it was all the time for me, but could be different for your situation.
oraclem19 likes this.
