Questions about block swap. - Honda Accord Forum : V6 Performance Accord Forums
Old April 8th, 2016, 07:49 AM   #1
Ok my j30a4 just spun a bearing and im having a hard time finding a replacement for a decent price but I did come across a j35a4 and a5 for a good price but my question is will the j30 heads fit the j35 blocks and is the j35 a direct fit for my transmission I have the automatic H5 trans.
bjamin is offline   Reply With Quote Quick reply to this message
Old April 8th, 2016, 08:07 AM   #2
from what I remember, j35 will no fit our transmission because of the bell housing. In order for the J35 to work, need to swap in a 8th gen M/T trans.
Also, the stock ecu won't be able to sufficiently run the j35 injectors.
2006 accord v6 6mt
one of the best sleepers on the road
j32a3
accordlyfe is offline   Reply With Quote Quick reply to this message
Old April 8th, 2016, 08:09 AM   #3
Ok so do i have any options other than the j32?
Old April 8th, 2016, 08:10 AM   #4
Im really not looking for performance or anything of that nature just want to get my car back on the road
Old April 8th, 2016, 08:23 AM   #5
And like i said in my original post i want to keep my j30 heads so it would be the same injectors I know the j35 has a different bore and stroke but i believe from what I've read the valves will clear i just didn't know if they would match up
Old April 8th, 2016, 09:47 AM   #6
There is a stick in this sub forum that details all of your options.
Old April 8th, 2016, 10:17 AM   #7
Ive seen that before but never seen any mention of the j30 j35 combo
Old April 8th, 2016, 11:33 AM   #8
J30s have a 86mmm bore, J32s and J35s have 89mm. This makes the heads largely incompatible from a compression and combustion chamber standpoint.
J30A4s and J30A5s are a dime a dozen on car-part.com. Check there or LKQ you'll find one. Buy the entire short block, swap over the extras, and drop it in. No reason to do a head swap.
You can swap in a J32A3 for not much more. The J30A4 stock ECU will run it fine but not the best. Anything J35X will require tuning which adds a tremendous amount of cost.
Old April 8th, 2016, 11:43 AM   #9
I would personally go for the j32, your already swapping motors, and it's not that much more.
Being your an auto I don't know how that would line up..
I swapped a j32a3 into my 6-6 coupe back in October, and it's been running great. Stock ecu will work fine after the swap as well.
I am still running stock accord ecu. Took it on the dyno, and it was not running lean what so ever. Motor runs strong.
However, Hondata is always a good aftermarket option. I don't think it's worth the hassle switching to stock 04-06 TL ecu if you swap.
2006 accord v6 6mt
j32a3
Old April 8th, 2016, 01:20 PM   #10
Buy my hondata in the fs. It's complete with ecu
Old April 8th, 2016, 06:23 PM   #11
See I'd love to do the j32 but where im I'm at on the east cost the j35 have been a dime a dozen but thanks guys for all the replys guess I'll check the sites you mentioned. But what is the honda data?
Old April 8th, 2016, 06:39 PM   #12
Hondata = honda tunable ecu. If you are planning a swap you might as well have a way to tune the car properly. All of the heavy hitters on here all run this
http://www.v6performance.net/forums/...s-harness.html
Old April 8th, 2016, 06:45 PM   #13
Sweet thanks azn!
Old April 8th, 2016, 06:46 PM   #14
Can you use the hondadata with the A/T?
Old April 8th, 2016, 06:50 PM   #15
aww your AT.... Sorry
Old April 9th, 2016, 12:36 AM   #16
Buy my piggyback
04 Accord 6-6 Coupe
13s no matter what hp I have
Just an All Motor J30...
Zach @ YCU Dyno Tuning
Old April 15th, 2016, 12:14 PM   #17
Ok guys I found a j32a3 with 69k miles for $825 does that seem reasonable? And will I run into any issues having the A/T?
Old April 16th, 2016, 08:37 AM   #18
Never mind I looked over azn's thread but anyway thanks for the help guys and I'll be back if I happen to encounter anything questionable along the way!
