Sunny's Twin Turbo kit Revamped - Honda Accord Forum : V6 Performance Accord Forums
Like Tree25Likes
Old July 18th, 2016, 08:11 PM   #1
quzyq06's Avatar
I purchased the twin turbo kit from Sunny in March. He threw in a lot of extras in with the kit. He's a stand up guy. i opted for this kit over the after cooled m90 kit because i would have some extra cash left to upgrade my suspension and buy other parts that were needed to handle the new power. My cousin has been doing the install and labor cost was fairly cheap. Car will be dynoed sometime next week after the fuel system upgrades are completed this week. Here's full list of all my mods to date.
Engine Mods:
2 Garrett GT25 turbos
stock j32a3 motor(57K)
4"CAI
LSD tranny
Spec stage 3+ clutch
xlr8 75A mounts
tls camshafts
3.7l manifold & throttle body
custom jpipe
custom 3" exhaust
Ik22 spark plugs
deatschwerks 800cc injectors
deatschwerks 300lph fuel pump
Aem fuel regulator
P2r fuel rails
Turbo Xs bov
Optima yellow top battery
Battery Relocation to trunk
Cooling:
Stock radiator using 2 10" pull/push fans due to tight fitment
1 "12 fan wired on a toggle switch to prevent car running hot at idle
Aem meth injection kit
Dirt port injection kit
Yonaka Intercooler
Suspension/ wheels:
Tein basic coilovers- looking to upgrade soon
New control lower control arms
Skunk2 upper control arms
ingalls rear camber kit
Tl-s front sway and Rear with endlinks
New rack and pinion
new tie rod ends
Insane shafts(500hp)
Stoptech brakes and rotors
Enkei Rpf1 17x9
Nitto Motivo all season tires 245/40/17
Interior:
Dual Gauge Pod fabricated by Nexson
Aem UEGO Gauge
Aem boost gauge
Greddy Profec B Spec II Boost Controller
CTE engineering short shifter
Exterior:
Aero full underbody spoiler kit
Tuners depot led tailight
Black/clear headlights-ebay
Rear window roof spoiler
&mpt=[CACHEBUSTER]">
quzyq06 is offline   Reply With Quote Quick reply to this message
Old July 18th, 2016, 08:51 PM   #2
So that was where the turbo kit went!! LEGIT!
Old July 19th, 2016, 07:33 PM   #3
How much boost are you planning on running?
Did you purchase a new transmission or just have yours sandblasted? It looks spotless.
Can't wait to see the numbers!
screaminz28 is offline   Reply With Quote Quick reply to this message
Old July 20th, 2016, 09:32 PM   #4
quzyq06's Avatar
Well i have to run atleast 9psi because thats what the wastegate springs are set at. I'm also going to run e85 gas due to high compression. My end goal is 400whp.
Ive had the transmission for 2 years. We just used a dremel to clean up the trannny and used a can of rustoleum paint from Lowes.
Old July 21st, 2016, 02:03 AM   #5
What will be used for tuning?
DomGSR-T is offline   Reply With Quote Quick reply to this message
Old July 21st, 2016, 07:04 AM   #6
quzyq06's Avatar
I already have hondata Flashpro. I will be using that.
thisaznboi88 likes this.
Old July 21st, 2016, 07:15 AM   #7
I hope you make more than 400whp especially if you are running e85 and 9psi on twins. My single turbo currently makes 350whp on 93 AT 7-8psi.
Good luck!
Old July 21st, 2016, 09:14 PM   #8
hum, will this be a race car only or it will be used daily? You know that you can only tune the flashpro for 14.7 AFR?
Old July 21st, 2016, 09:23 PM   #9
Old July 22nd, 2016, 06:19 AM   #10
Dom, what do you mean you can only tune the flashpro for 14.7 AFR? Is that cautionary on using E85? My understanding is that an o2 sensor is measuring lambda, in which stoich is always 1.0 and it just spits out a gas number, so you can use E85 with the same gas afrs.
Old July 22nd, 2016, 07:20 AM   #11
i think he was talking about openloop?
Old July 22nd, 2016, 12:39 PM   #12
You are right about the stoich afr, it will read 14.7 afr even though it's actually something like 9.765 afr on E85... What I meant is that we cannot rescale settings in the close loop/lambda of the flashpro for the stock O2 to match whatever gas we want to use... those options looks like we can change them but it does not do anything on the Jseries but it must work on the Kseries. Yes it would work to use e85 for sure but for me I would prefer to be able to rescale afr to match the e85. With all that said, I would be curious to tune a Jseries on e85! Bt I don't have access to e85 here I would have used it in my boosted integra for sure!
Old July 22nd, 2016, 02:52 PM   #13
Why would you want to change it though? Isn't it enough to leave it to what it's set at? Do you want to run at something other than stoich with E85 during open loop?
Old July 22nd, 2016, 03:47 PM   #14
It would work for sure but since i'm a "weird guy" I would want to read the real e85 AFR readings like those used on the AEM wideband O2 voltage table...
http://i933.photobucket.com/albums/a...ps6cc561f4.jpg
As for the stoich AFR during open loop, yes I would like to run it at something else than stoich... with good injectors you can run a car leaner then 14.7 to save gas... like on my integra, i'm at 15.5-15.8 depending on load/rpm... with the flashpro on the kseries they can change that open loop value but we cannot on the jseries...
Old July 22nd, 2016, 06:03 PM   #15
I'm with you on the lean burn, but I'd probably a bit apprehensive doing it in a turbo setup just because of the potential for it to be too lean on tip in. I'm sure a good tuner could devote the time, but how many people pay for that much tuning.
I know what you mean on seeing the gas AFR rather than the E one, but that's just semantics. I'm fine with seeing and using the gas afr.
Old July 22nd, 2016, 07:28 PM   #16
quzyq06's Avatar
No i did not know that. But i do know 14.7 is even lean for a na setup. I have an 06 Tl as my daily but i do want to be able to daily drive my accord also. My original plan was to only run water/meth. i just wanted to run e-85 for the added safety it can provide. I will run through so much water/meth because these baby turbos hit max boost around ~3000 rpms. i will just have to make my own mixture to save some $$$ vs buying boost juice.
Old July 22nd, 2016, 07:42 PM   #17
You are right, this takes time to tune correctly but quite easy on a full stand alone ecu...
Old July 27th, 2016, 04:44 PM   #18
nice
Scutti is offline   Reply With Quote Quick reply to this message
Old July 28th, 2016, 05:59 AM   #19
Any dyno numbers yet?
Old July 28th, 2016, 05:07 PM   #20
quzyq06's Avatar
Everything has been push backed a week. Hopefully we will be finishing up the car this weekend and dyno next week. I scratched the idea of running E85. I will stick with pump gas. I will post a dyno graph once the car is tuned.
Old July 28th, 2016, 06:16 PM   #21
Wow I been MIA, nice to see Sunny kit put to use. last time I saw it was at the dyno 3-4 years ago.
Atlas.46 likes this.
bobbylaneracing is offline   Reply With Quote Quick reply to this message
Old August 6th, 2016, 03:00 AM   #22
In for updates.
Old August 9th, 2016, 06:18 PM   #23
quzyq06's Avatar
Originally Posted by Atlas.46 View Post
In for updates.
I towed the car to the dyno this afternoon. if everything goes well should have some numbers for you guys tomorrow.
Old August 9th, 2016, 06:28 PM   #24
quzyq06's Avatar
Old August 9th, 2016, 06:35 PM   #25
quzyq06's Avatar
Old August 9th, 2016, 06:48 PM   #26
YAY race cAR!!
Old August 11th, 2016, 08:32 PM   #27
soo dyno!!!!
Old August 13th, 2016, 06:34 PM   #28
Show me the power!!! I'll post my 390whp dyno tomorrow if you post your dyno sheet
Old August 13th, 2016, 07:19 PM   #29
quzyq06's Avatar
lol I've seen your dyno sheet. i must say thats impressive for 7.5lbs of boost . My car still hasn't been tuned yet. i been texting the tuner last 3 days but apparently they are a week behind in tuning. Hopefully i hear something Monday.
Old August 13th, 2016, 07:26 PM   #30
Haha yeah I love to see how much your turbo build makes. I want to see the response of your twin turbo. Should make a really good power band
