J33 question - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By thisaznboi88
Old August 17th, 2016, 04:10 AM   #1
J33 question
Hi to all.
Can you say me what crank and rods for j33.
j35a3 from 2001 MDX it's ok?
My engine is j30a4
sasa is offline   Reply With Quote Quick reply to this message
Old August 17th, 2016, 06:58 AM   #2
07J30's Avatar
I really don't wanna be this guy but...You can find this info with a quick search. If you are asking for advice on a matter like this you are not prepared to do the research for a complete build. I search for threads everyday to answer the questions I have for my build....and it still mite get effed up. This is rudimentary info. It's out there man just gotta find it
J33= j30 block+pistons w/ j35 crank+rods+bearings. As far as which j35 to use I'm not sure but I am sure the info is out there.
Old August 17th, 2016, 07:53 AM   #3
I read for about a year =)
I try =) but there is different information.
I buy j37 crank from ZDX but it dont match to my j30a4
And now i should decide what to do next, build j33 or stay with j30 with RL cams and 3.7 intake
in this http://www.v6performance.net/forums/...trokn-j33.html
NVA-AV6 use j35a3 crank, in another he said that should use j35a5 crank.
Old August 17th, 2016, 07:55 AM   #4
Old August 17th, 2016, 07:55 AM   #5
or you can just go turbo and make a bunch more HP.
was the crank shaft that you got part number 13310-RK2-A01 ? because it is the same for zdx and mdx 3.7L. not sure why it is not fitting in your engine since 07j30 and simione both used the same one to build their j36.
https://en.wikipedia.org/wiki/Honda_J_engine#J37
http://elitecm.net/forums/index.php?topic=40.0
Old August 17th, 2016, 08:19 AM   #6
The J3X guide. Block, crank, rod, piston combinations.
This is my ZDX crank in j30a4 =)
May be i should use 2007 3.7 crank, not 2012?
Where on the crank i cant find information about part number?
And what about turbo? If i use RL cams and 3.7 intake, can i boost about 8 psi?
Old August 17th, 2016, 08:25 AM   #7
2007 is a 3.5L part number 13310-RYE-A00.
not sure why your crank doesn't fit. it looks very close.
Old August 17th, 2016, 02:41 PM   #8
07J30's Avatar
I'm not sure when the change occurred...but I believe it was 11-12 for the mdx crank. I used an 09 and had no problems
Old August 18th, 2016, 02:43 AM   #9
Originally Posted by simione View Post
In this post he use j35a3 in another hi said that should use j35a5, what is true?
Old August 18th, 2016, 02:46 AM   #10
I bought only ZDX crank, and don't know which year.
So, 2012 3.7 crank does not fit =)
What do you think, stay with j30 crank and RL cams, 3.7 intake, or find 3.7 crank to j34 (j33 its right).
I think j34 not very quick as j30. And j30 have more fuel economy, right?
Old August 18th, 2016, 10:34 AM   #11
Benefit of a j33/34 is the increase in tq. Go gain is 20 maybe 30. Go with a turbo I made 390whp and still get good gas millage
Old August 18th, 2016, 11:03 AM   #12
And you use stock pistons?
Old August 18th, 2016, 12:28 PM   #13
http://www.v6performance.net/#/forum.../226913?page=1
Old August 18th, 2016, 12:51 PM   #14
Link not correct, please resent
Old August 18th, 2016, 12:58 PM   #15
Stop being lazy and go to the end of the thread
sasa likes this.
Old August 18th, 2016, 01:28 PM   #16
My mistake
Old August 18th, 2016, 01:39 PM   #17
All good buddy
Old August 28th, 2016, 09:56 AM   #18
Always wish I did this swap
Infatuated is offline   Reply With Quote Quick reply to this message
