AEM FIC tuning, what is the trick? - Honda Accord Forum : V6 Performance Accord Forums
Old August 27th, 2016, 08:58 PM   #1
I have an AEM FIC that I used for my Dodge Neon and plan to use it to tune my Honda with. What is the trick everyone is using to make sure the car doesn't re-tune the AEM?
Note: NVA-AV6 Seems to be away and have messaged him, but seeing if anyone else knows what to do.
Thanks
nick650 is offline   Reply With Quote Quick reply to this message
Old August 30th, 2016, 02:45 PM   #2
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
use o2 Skewed mode.
Might be more to it, but that is the mode you need to use.
Old August 30th, 2016, 10:39 PM   #3
Is that the only thing that I need to do to make this work? I would like to order the plug and play harness but, its so expensive and want to make sure that is how I go about making this work. Any one make a cheaper plug and play harness?
Old August 31st, 2016, 03:21 PM   #4
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
Don't know. that is why I said "Might be more to it"
Old August 31st, 2016, 11:33 PM   #5
The Jester
thisaznboi would be the one to talk to about making a harness, he should still have all the resources on pinouts and what you need and everything. A custom harness can set you up with better quality wires, better placement, and better leads for your need (log switch, program switch, 12v on off switch).
O2 skew is the right track. Just start googling the living crap out of it and you should come up on a site called like banzai or kamikazi or something. A couple of other sites have pretty good info on how to get it set up correctly as well. I know you want the map to be load based, and o2 skew is a big part. other than that I just let Dom from Vittuning take care of my fic6
Old September 1st, 2016, 12:55 PM   #6
I don't I don't know how to do the aem fig harness. Only the hondata one. Don't message me message Paul
Also Dom doesn't work for Vits... I have no idea where you are getting the info from....
Old September 1st, 2016, 08:48 PM   #7
Paul has bin MIA, I've tried :/
Old September 3rd, 2016, 01:45 PM   #8
Anyone have info to call Paul up?
Nick
Old September 26th, 2016, 07:53 AM   #9
I thought I read AEM 02 skewing acted up with the Honda ecu ?
Im going to be tunning my acura RL via FIC in the next few weeks via timing and fuel only no 02 skewing
JDMCRX is offline   Reply With Quote Quick reply to this message
