J32a3 swap ecu - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By myAV6
Old October 11th, 2016, 08:49 AM   #1
J32a3 swap ecu
My av6 is in process of being swapped with a j32a3 I read on here that my j30 mt ecu will work but it will run lean, how lean? Where can I find the 04 Tl ecu or other compatible ecu? Can I make an auto Tl ecu work? I've used search engine, car will be done in a couple days so I need to know asap so I can get parts
Lostinthamusic is offline   Reply With Quote Quick reply to this message
Old October 11th, 2016, 09:32 AM   #2
I swapped my old j32a3 into a buddies car two years ago, and he has been running the j30 ecu the whole time with no issues. the stock ecu does a great job of keeping things under control. Obviously, it would be optimal for you to use the correct ecu, but he never had time to do all the necessary adjustments to run the ecu. you have to repin plug A of the ecu and then have a dealer reprogram your immobilizer so that the veicle will start with the new ecu. here is a link to the what wires need repinned
http://www.v6performance.net/forums/...ecu-guide.html
I posted a few ebay links where you can buy the ecu you need on you wtb thread in the classifieds
Old October 11th, 2016, 08:04 PM   #3
I run a j32a3 in my av6 with the stock j30 ecu. Does not run lean, confirmed on dyno. Runs great, no issues.
If you want to switch out ecu, I suggest switching to the 07-08 ecu, for the hassle, its not worth going with a 04-06 TL ecu.
2006 accord v6 6mt
one of the best sleepers on the road
j32a3
accordlyfe is offline   Reply With Quote Quick reply to this message
Old October 12th, 2016, 11:41 AM   #4
Domi_no's Avatar
What are the benefits of the 07-08 over the 04-06?
Old October 12th, 2016, 02:21 PM   #5
From researching this swap before. I saw the biggest advantage with people going with the 07-08 TL ECU was the fact that if you ever need to tune it, Hondata's Flashpro is readily available for it.
With a 04-06 ECU, not only do you have to get the 07-08 Flashpro but you also need to factor in the adapter.
Hope this helps, I can't post links because my post count is low.
Domi_no likes this.
myAV6 is offline   Reply With Quote Quick reply to this message
Old October 13th, 2016, 09:36 AM   #6
^^ exactly. able to use Hondata.
2006 accord v6 6mt
j32a3
Old November 4th, 2016, 11:50 PM   #7
I would not use the J30 ecu. Either use a J32a3 ecu or 07-08 and get it tuned
JSeriesFanatic is offline   Reply With Quote Quick reply to this message
Old November 5th, 2016, 02:53 PM   #8
why do you say that
2006 accord v6 6mt
j32a3
