Engine rebuild - Honda Accord Forum : V6 Performance Accord Forums
Old November 2nd, 2016, 01:25 AM   #1
Engine rebuild
What does everyone recommend for break in procedure on a freshly built J Series?
gnxpro24 is offline   Reply With Quote Quick reply to this message
Old November 2nd, 2016, 12:00 PM   #2
07J30's Avatar
everyone has a different procedure. my plan is to start the engine and vary the rpm (in neutral) till it gets to operating temp while checking for leaks, then shut it down and do an oil and filter change. inspect old oil and filter for metal. go out for a drive with a lot of high rpm vacuum decel in gear to seat the rings, then change the oil again to check for more shavings, then drive city only for the next 500-1000 miles. change/check oil, then drive normal (city/highway) till 2500 miles, switch to synthetic.
just use dino oil for first 2500 miles, vary the rpm, use high rpm vac decel, and change oil often and you should be set.
Old November 2nd, 2016, 06:43 PM   #3
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
I used(still do) conventional 10w30 after my break in. 01 Accord w/ J35A3 w/ 2005 Acura RL pistons/ring set. New factory block.
I just drove normal, like it was my daily.
Would like to add:
Do NOT go into V-tec (high cam) for at least 5,000 miles. Let everything get "settled in".
Old November 4th, 2016, 11:56 PM   #4
5k til vtec? Thats like half a years worth of driving
JSeriesFanatic is offline   Reply With Quote Quick reply to this message
Old November 6th, 2016, 05:36 PM   #5
07J30's Avatar
If u drive 5000mi in 6mo then yes...indeed it would b
Old February 21st, 2018, 03:54 PM   #6
Good question didn't think about the fact I'd have to break in a new engine
athorn720 is offline   Reply With Quote Quick reply to this message
