My j32 build - Honda Accord Forum : V6 Performance Accord Forums
Like Tree31Likes
Old September 4th, 2017, 09:44 AM   #1
Keltalon's Avatar
My j32 build
Bc custom cams, ported everything, supertech valve spring kit.
Sent from my SM-G930V using Tapatalk
Michaelmike likes this.
Keltalon is offline   Reply With Quote Quick reply to this message
Old September 4th, 2017, 10:25 AM   #2
Keltalon's Avatar
Ported head
Scottwax and 0VM66T like this.
Old September 4th, 2017, 02:43 PM   #3
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
Cool. Flowbench test.
Red/Green = Stock
Blues = Porting
Have you done a flowbench on a ported J32A3 I/M versus a non-ported J37A4 I/M?
NightCruiser likes this.
Old September 4th, 2017, 03:00 PM   #4
Keltalon's Avatar
Na did not do that test.
Old September 4th, 2017, 04:11 PM   #5
are the scaling correct?
i have a flow bench from kingsmotorsport and they don't flow that much at that low of a lift.
Old September 4th, 2017, 04:22 PM   #6
Keltalon's Avatar
I don't debate that stuff waste of time I just build and post results.
Old September 4th, 2017, 05:09 PM   #7
Keltalon's Avatar
Block under construction
Old September 4th, 2017, 05:24 PM   #8
Keltalon's Avatar
The candidate!
Old September 4th, 2017, 07:01 PM   #9
have fun with that ;p
was going to pick your brain, but fk it. you do you.
Old September 4th, 2017, 08:15 PM   #10
Keltalon's Avatar
Lol. Will do. Stay tuned.
Old September 4th, 2017, 09:27 PM   #11
Keltalon's Avatar
Head flow number sheet.
Sent from my SM-T580 using Tapatalk
thisaznboi88 likes this.
Old September 4th, 2017, 11:50 PM   #12
^ thanks for sharing. Number makes way better sense on this post now.
So I am assuming you are going to hit big number on boost since you also have JE piston and rods.
what compression ratio did you go with? I'll share my piston specs if you share yours
Keltalon likes this.
Old September 5th, 2017, 04:41 AM   #13
Keltalon's Avatar
11.5:1. This is the same compression ratio I built the 4g63 motor in which I run 40psi on the eclipse Hugh front mount and E85 I was able to hit 809whp. Goal for the accord is around 500whp. When I hit this goal it will be more logical to share all my specs. I found when I was building the eclipse that when I mention my plans the forum attacked and mocked the approach. But when I got the end results, broke the cyclone dyno record and took fastest fwd at the ga wanna go fast half mile event the ridicule stopped. That's why I mentioned earlier what I did about no debating and posting results. Type keltalon in Google and you will find a lot of my dsmtuners posts and you tube videos. I have three projects going on at the same time all with slightly different hp goal. Accord 500whp G35 700whp Del Solution 600whp.
I am glad to be part of the boards here and will contribute the best way I can.
Old September 5th, 2017, 04:44 AM   #14
Keltalon's Avatar
On this pull I was running 32psi putting out around 700whp the eclipse
https://youtu.be/HtRNWAozEcY
Old September 5th, 2017, 04:50 AM   #15
Keltalon's Avatar
Here is the accord with j30 and J2 Engineering exhaust selling wolf tickets before being pulled lol.
https://youtu.be/35SqrgN5MPI
Old September 5th, 2017, 06:38 AM   #16
Keltalon's Avatar
Here's the baseline run on the accord J30 engine with exhaust and cold air a/f still being managed by the stock ecu. I think this is good to post early in the thread.
https://www.youtube.com/watch?v=GWKH-AKDWDE
Scottwax likes this.
Old September 5th, 2017, 10:07 AM   #17
The accord goal should be easy to reach 500whp. I was around 425 whp (dynapak) at 9psi on stock internals with a type s port and polished head swap. Eventually Cylinder 5 ring land cracked. I believe my compression ratio was around 9.5-9.7 since the type s head has a larger cc than the j30a5.
My buddy has a turbo accord putting down 700+whp and his latest 1/4 mile was running 10.6 sec.
accord325 likes this.
Old September 5th, 2017, 12:17 PM   #18
Keltalon's Avatar
Nice! Thanks for the encouragement. I will be crossing my T, s and dotting I, s for sure.
I perform better under pressure.
" Forced Induction! "
Old September 5th, 2017, 07:11 PM   #19
Nice up and coming. Did a similar build in my 6th gen recently. All forged and sleeved j35a4 block with 32a2 heads
J35_cg2 is offline   Reply With Quote Quick reply to this message
Old September 5th, 2017, 08:11 PM   #20
Keltalon's Avatar
That's clean!!
Old September 5th, 2017, 10:14 PM   #21
I recommend these spark plugs
Old September 11th, 2017, 06:04 PM   #22
right on! how is it like to hook up from a dig?
Celeias is offline   Reply With Quote Quick reply to this message
Old September 11th, 2017, 07:08 PM   #23
@op anymore updates? Sub'ing to this thread
Old September 30th, 2017, 11:27 AM   #24
Any updates on the build/project? I know I am late but I am following closely now.
NightCruiser is offline   Reply With Quote Quick reply to this message
Old October 1st, 2017, 08:04 AM   #25
Keltalon's Avatar
I am almost finished with the engine. I have three projects going on at the same time lol. This one, delsol turbo and infiniti g35 twin turbo I am building all three engines myself. I had to recently tear into the eclipse awd transmission and replace first gear it ripped the teeth right off, it's fixed. I'll be back on the accord engine soon.
Old October 10th, 2017, 03:03 PM   #26
very nice and very clean
Gunnyboy is offline   Reply With Quote Quick reply to this message
Old January 4th, 2018, 05:26 PM   #27
Red/Green = Stock
Blues = Porting
The answer to the intake manifold question is j35a3/j35a3/j32a2 intake manifolds make more power than a stock shawd manifold. Iím not sure about the j32a3 but itís really not an upgrade from anything but the j30 so Iíd ditch it
Old January 5th, 2018, 10:11 AM   #28
J Series Intake Manifold Shoot Out Results!!!
Ok, so the numbers are in for the Intake Manifold Shootout. Current engine setup
J35A4 Block
J32A2 Heads
P2R DNJ High Compression Pistons
All pulls were done on a stock Automatic Acura TL ecu. We did 3 pulls with each intake manifold and displayed the best pull for each one. If we noticed the power kept going up between pulls, we did additional pulls until the power stopped going up. So each manifold had a fair shot to get its best dyno pull.
YELLOW Holley
BLUE J32A2 Stock
PINK J32A2 SBS P2R Spec Ported
GREEN J37
RED J32A2 SBS P2R Spec Ported with P2R Plenum Spacer
Here are a few clear-cut things.
1. The stock J32A2 intake manifold made the least amount of HP at 294hp.
2. The J37 made the most low end to mid-range power but didnít as much peak power as the Ported J32A2 or the Holley intake manifold.
3. The SBS Performance ported J32A2 manifold with the P2R Plenum Spacer made the most HP of all the different intake manifolds.
4. The Holley made the least TQ but beat out all of the stock manifolds for HP up top.
After we finished doing all the manifold test. I went back to the J32A2 SBS P2R Spec Ported with P2R Plenum Spacer manifold. Rotated my intake tube towards the fan, and put in some VP MS109 fuel to mix with the 93 octane that was in the car. And we dynode 311 HP & 284 TQ to cap off the day.
accord325, 0VM66T and Keltalon like this.
Old January 28th, 2018, 11:02 AM   #29
05accord6spd's Avatar
:O j37 killing it at 3.5k-5k rpms :OOOO? oh and did they sat what tb was used per mannifold? id assume j37 on all.
Old January 29th, 2018, 02:17 PM   #30
A dbc 76mm tb on all test.
530av6 is offline   Reply With Quote Quick reply to this message
