A'pexi V-TEC Controller II - Honda Accord Forum : V6 Performance Accord Forums
Old March 26th, 2004, 06:03 AM   #1
Has anyone here manged to get the Contoller to work on their 6speed accord or CL-S???? If so can you point me in the right direction as how to get it to work?
'03 CL-S w/ 6 speed & nav
CT exhaust
CT sway bars
CT springs
Neuspeed short shifter
Neuspeed front strut brace
AEM underdrive pulleys
AEM cold air intake
Debadged rear
Momo racing pedals
18'' Motegi wheels w/ 235/ 40 ev100 yokes
35% tint
2 10'' punch subwoofers & RF amp w/ custom box in the trunk
http://www.cardomain.com/id/jruss9819
jruss9819 is offline   Reply With Quote Quick reply to this message
Old March 26th, 2004, 06:48 AM   #2
HONDA_99's Avatar
you might wanna talk to RussianRSX-S, he has VAFC II on his 03 AV6 6sp.
and another thing, there is wiring harness from Frog Engine controls that alows to plug in VAFC I harness into wiring harness of car without cutting, splicing, soldering or cramping, just plug-n-play. but that harness for VAFC I and i don't know if it'll work for VAFC II and i don't know wiring harness same on your car and 6 gen AV6.
you can see picture of Frog wiring harness here -> http://www.v6performance.net/forums/...highlight=frog
there is also another company that makes similar harness, here is info on that -> http://www.v6performance.net/forums/...highlight=frog
Old March 26th, 2004, 10:10 AM   #3
Northcoast Tuner
I was under the impression that the VAFC would be better suited for the V6 since it is VTEC and that the VAFC-II would be better for the I4 since it is iVTEC, unless the VAFC-II is backwards compatible, but then why pay the extra money for iVTEC compatibility if you can't use it?
http://members.cardomain.com/josephip
Old March 27th, 2004, 05:15 AM   #4
Looks like VTECFROG.COM just came out with a new harness adaptor for the AFC II for the CL-S. I'm going to order one and give it another shot. Hopefully the AFC and the car will play nice this time. The down side is that the harness is $150....that kind of sucks.
Old March 29th, 2004, 10:19 AM   #5
not to put the harness down, but why do you need it. it would take you about 15-20 mins longer to just hook it up yourself if you know the right wires. i personally wouldn't pay 150 just to be lazy. IMO
speeedfrk is offline   Reply With Quote Quick reply to this message
Old March 30th, 2004, 06:47 AM   #6
J32A2 + SC + Meth AV6
BlackV62K2's Avatar
The harness is good way to keep your stock wires in tack. That itself is the reason I got a Frog harness for my Apexi V-AFC. Also it takes no longer than 10mins to have it install, though it's pain to get the connectors off the ECU.
