J35a8 crankshaft - Honda Accord Forum : V6 Performance Accord Forums
Old May 14th, 2018, 02:04 PM   #1
J35a8 crankshaft
I was wonderingif has anyone knifeedged or lightened the jís crankshaft n balanced before.
I have a j35a8 RL motor sitting in my garage. I plan on having the crank knifeedged. Any opinions or cons. Its for NA build only no boosted.
530av6 is offline   Reply With Quote Quick reply to this message
Old May 15th, 2018, 04:57 PM   #2
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
1 guy on here did - Knighthawk04V6??/BobbyLaneRacing. But his J35A8 N/A build was for Track/Road Course, so knife edging the crank would be a good benefit for his application - high RPMs.
If you are just going to do a mild N/A build and just cruise around with an occasional run, I would not knife edge the crank.
If it is an All out N/A build and you plan to beat up on it frequently, ie: High Compression, Fresh Ground Big Cams, Indexed Piston Rods, Big a$$ throttle Body, etc. then Yes, knife edge the crank.
