J32a3 swap question - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By 7thgen66
Old June 7th, 2018, 02:43 PM   #1
J32a3 swap question
Ok i searched and searched and never could find a straight answer i have a 03 accord coupe 6 speed manual and the j30 in it bent a valve but im swapping a j32a3 and have the 6 speed tl ecu does it matter if the j32 comes from an automatic trans car?
Dustin95 is offline   Reply With Quote Quick reply to this message
Old June 7th, 2018, 03:19 PM   #2
You'll be fine. What year is ecu ?
accordlyfe is offline   Reply With Quote Quick reply to this message
Old June 7th, 2018, 03:26 PM   #3
Its from a 04 tl 6 speed so it doesnt matter that the motor is from an auto? Nothing needs to be changed on the motor for the swap
Old June 7th, 2018, 10:16 PM   #4
you will have to double check the coolant cross over line. I believe the AT and MT are different
Old June 8th, 2018, 07:09 AM   #5
steve4748's Avatar
No, nothing major needs to be changed when using auto motor into manual car.i did this when i swapped an mt into my auto accord. Only difference i seen was coolant lines on the auto tranny that the manual didn't use. I just plugged them. Going on 5k miles since swap no issues..
steve4748 is offline   Reply With Quote Quick reply to this message
Old June 10th, 2018, 06:49 PM   #6
7thgen66's Avatar
yeah theres one coolant hose off of the stock MT j30 block you need to reuse, it literally loops the coolant right back into the block, located under the TB, about the same thickness as the heater core hoses. its on the same coolant pipe as the radiator hoses.
i did the swap, j32a3 from automatic in my accord 6MT, there was ONE sensor on the intake manifold that had a different sized plug, its located behind the TB bolted onto the intake manifold with a vacuum hose keep it from your original block and slap it on the j32 intake. it won't bolt on directly but take the whole bracket from your original intake manifold, you can make it work to stay on with one bolt. if for whatever reason you want it to be bolted securely you can just swap over the whole intake manifold from your j30, as far as i know its the exact same thing.
ill upload pics later.
first picture shows me pointed at that sensor i grabbed from the J30 before i tossed it you can see it goes to that "EVAP SERVICE POINT" thing with the green cap in the second photo, then the second photo is hard to see my finger but im pointing at the hose that loops out and right back in to the block, the inlet and outlet are right next to each other just slightly parallel.
yes i know i left that clamp loose on the sensor lol, i noticed AFTER taking the photo.
imnotmatt1189 likes this.
7thgen66 is offline   Reply With Quote Quick reply to this message
