I want to add LSD to my Accord V6 MT sedan - Honda Accord Forum : V6 Performance Accord Forums
Old September 23rd, 2018, 11:08 PM   #1
6 Speed-O
e713's Avatar
Hello,
Like the post says, I found a CL Type S 6MT LSD and I'm want to retrofit an LSD to my accord since my clutch went out. Does anyone know what spacer I need to fit my transmission? Thanks. (Diagram #5 Shim)
https://www.hondapartsnow.com/parts-...ential-v6.html
2007 Accord Sedan i4 & 2007 6 Speed Sedan
Enrique
e713 is offline   Reply With Quote Quick reply to this message
Old September 24th, 2018, 02:06 AM   #2
You have to measure it there is 20 different one
Old September 26th, 2018, 12:59 PM   #3
get the 06 CL type s 6 speed, it has lsd. then you can upgrade the mounts and clutch
04accordv8killa is offline   Reply With Quote Quick reply to this message
Old September 26th, 2018, 02:56 PM   #4
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
? what.
He found one and wants to pull the LSD out of it so he can use it is his Accord 6-speed tranny because he is replacing the clutch in it. He doesn't want to swap manual trannys.
