Swap a 6sp tsx tranny? - Honda Accord Forum : V6 Performance Accord Forums
Old June 20th, 2019, 01:06 PM   #1
06ac0rd's Avatar
Is the tsx 6sp tranny a direct fit to a 06 accord coupe v6?
06ac0rd is offline   Reply With Quote Quick reply to this message
Old June 27th, 2019, 05:42 PM   #2
TSX is a I4 motor unless you are getting the 2010+ TSX V6 or TL V6 (same drivetrain). To see if they are similar (the way that I do it) is to go on RockAuto and compare axles and transmission mounts. If they are the same then you should be mechanically good. Wiring will be a little different probably.
Riley is offline   Reply With Quote Quick reply to this message
Old June 27th, 2019, 07:08 PM   #3
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
Bad info sir.
Acura changed the transmission bellhousing in 2007, so a 2010 TL manual transmission will NOT bolt up to a 7th Gen J30A4/A5, unless you fabricate an adapter plate.
Comparing axle and transmission mounts to determine if it will bolt up does not work for this specific application.
06ac0rd: The above info is all I can provide.. I don't know the answer to your question. Try searching DriveAccord for your question. I can't guarantee the answer is over there.
Old July 5th, 2019, 10:46 AM   #4
The Jester
alright, from what I can collect the transmission will not work. It would work if you swapped in a j35a8 or newer engine with the updated bellhousing, however the TSX transmission is based on the newer transmission bellhousing, not the one in our accords.
