Dyno tomorow.... - Honda Accord Forum : V6 Performance Accord Forums
Old March 28th, 2004, 09:33 AM   #1
Dyno tomorow....
Tomorow I'm going to get my car dyno'ed just to see what it puts to the wheels stock, before I start modifieing it with intak, exaust,etc..
I will have 92oct in the tank and it will be corrected hp. I will post the results tomorow.
S.A.M6 is offline   Reply With Quote Quick reply to this message
Old March 28th, 2004, 01:41 PM   #2
Nothing special
blu6speed's Avatar
Ok lets see the stock numbers, but I cant wait to see what kind of numbers are pulled after mods. Keep us up to date!
Old March 28th, 2004, 03:33 PM   #3
I think it takes at least a full tank of gas before the ECU advances timing and takes full advantage of the premium fuel.
leo leo is offline   Reply With Quote Quick reply to this message
Old March 28th, 2004, 05:34 PM   #4
I've been running premium feul since i bought the car 9000kl/m ago
Old March 28th, 2004, 07:22 PM   #5
Roadmaster's Avatar
I am planning a dyno session this coming weekend, April 3rd. I'm an automatic with an Injen cold air. So I too will have to see what the car can put down.
Let us know what your 6spd puts down
Dustin
Roadmaster is offline   Reply With Quote Quick reply to this message
Old March 28th, 2004, 10:08 PM   #6
Re: Dyno tomorow....
two things to remember:
1. dyno in 4th gear!!!!!!!!
2. Make sure they give you your SAE corrected numbers, not std!
modfreak1 is offline   Reply With Quote Quick reply to this message
Old March 29th, 2004, 11:34 AM   #7
Thank you for putting out the bucks for that all important pre-mod dyno. It will be nice to get a real measure of the gains, not just a post-mod dyno and a guess.
Good job!
sami is offline   Reply With Quote Quick reply to this message
Old March 29th, 2004, 03:26 PM   #8
Stoner Boner
Yeah, I didn't get to dyno mine before I put my intake on it. I'm going to dyno it later before I do exhaust or anything else. I just have done the AEM v2 CAI.
stoner is offline   Reply With Quote Quick reply to this message
Old March 29th, 2004, 04:24 PM   #9
Results?!?!
AccordEXGirl is offline   Reply With Quote Quick reply to this message
Old March 29th, 2004, 05:01 PM   #10
import tuner and rn
eolife22's Avatar
nice avatar AccordEXGirl
eolife22 is offline   Reply With Quote Quick reply to this message
Old March 29th, 2004, 07:00 PM   #11
Roadmaster's Avatar
Yeah post up those results
Old March 30th, 2004, 10:26 AM   #12
shouldnt you dyno in 3rd gear? on my TL... they dynoed it in 4th gear at first but they hit the speed limiter or maybe it was the rev limiter. i dunno.
str8acura is offline   Reply With Quote Quick reply to this message
Old March 30th, 2004, 10:36 AM   #13
"Certified Hybrid Killer"
SteVTEC's Avatar
it's considered "good practice" to dyno in the gear ratio closest to 1.00:1. For AV6 autos that's 3rd, but on 6spds it's 4th. In the end it shouldn't make much difference anyways because the dyno adjusts for the overall ratio, and as long as you compare baseline vs modded dynos done in the same gear it's all good.
Some cars run a straight 1.00:1 "overdrive" gear but just run a very tall 2.xx:1 final drive vs a more common 3.xx:1 on a lot of cars, or 4.xx:1 on a lot of Hondas. For those cars you do need to dyno in one of the lower gears anyways. You'll either be hitting the speed limit of the dyno, or straining the engine and getting it extremely heat soaked and losing power by the time it manages to pull up to that high of a speed.
Old March 30th, 2004, 06:32 PM   #14
Time to post my results...just a recap I have a 2004 V6 6-speed.STOCK! I use 91 octane fuel The tem was prob 12C sunny. Done on a rolling dyno with SAE corrected hp and torque.
I did three runs. The first two were the same, the third was removing the intake flex tube that attaches to the air cleaner. I wanted to see if not having the restirctive filter and everything would give more power. My computer is F%ckn around with me right now and I cannot uplaod the actaul dyno sheet, But I will tomorrow. For now I will give you the numbers
First run was prilimanary with the same hp as the second,
The second run yeilded [email protected] 6200rpm,
193.6ft/lb5200!
The third run is when I tried the method I decribed above with removing the flex tubing from the air filter box...
[email protected], 188ft/[email protected] what a difference.
The guy was saying that whne the air travels in a short path throught the intake it tis very turbulent and that' what causes the drop. Plus as you with see when i get the dyno posted you'll see how eratic the power curve is.
Too note for those who are scetical of results my un corrected hp would have been 219.5hp.....
Never mind computer coment here it is..
http://www.cardomain.com/memberpage/462100
Old March 30th, 2004, 08:43 PM   #15
Something Something Darkside
Doom's Avatar
Direct link:
V6P Senior Moderator
Old March 30th, 2004, 09:03 PM   #16
Thanks, those are pretty respectable rwhp numbers. Will be anxious to see the results of your mods. Particularly if you do a CAI, starting to rethink my position on CAI after this article in TOV,http://www.vtec.net/articles/view-ar...icle_id=214692
Dr. Honda is offline   Reply With Quote Quick reply to this message
Old March 30th, 2004, 09:04 PM   #17
Roadmaster's Avatar
So we are probably loosing power with induction systems!!!!!!!!!! Great stock numbers... Can you describe this piece that you removed any more? You say the flex tubing? You mean the actual tubing that went from the airbox to the throttle body? What did you use in its place? Were you just allowing air to enter the throttle body without any tubing?
Thanks
Dustin
Old March 30th, 2004, 09:07 PM   #18
I AM LOST....
brex's Avatar
Old March 30th, 2004, 09:08 PM   #19
I AM LOST....
brex's Avatar
Thanks
Dustin
Roadmaster, I doubt it..
I think the problem was the air were not "controlled" to be flowing in orderly and efficiently.. it all have to do with the design of the tube as well...
Old March 30th, 2004, 09:19 PM   #20
Roadmaster's Avatar
I understand... It does make sense, an open throttle body has no true control of the air. But I have still been rather suspicious of cold air inductions systems and whether or not they do provide gains or not. If I remember correclty our buddy "torquie" dynoed his car with an Injen induction system and produced the same numbers at the wheels as other stock cars (ie VTEC.net test car)
I know some cars are faster, others slower... I just hate to think I am potentially loosing power with the Injen intake. I remember a long time ago sending a letter to Injen. I recieved a reponce that my letter was being resent to a more appropriate source, but nothing else ever happened.
Dustin
Old March 30th, 2004, 09:21 PM   #21
I AM LOST....
brex's Avatar
Yeah.. I think that's why this Dyno is so important.. the actual first car that went thru these dyno and modding to give us unbias result...
Thanks ADAM...
Old March 30th, 2004, 09:24 PM   #22
you gotta rub to dub!
relentless's Avatar
Thanks ADAM...
Werd on the THANKS!!! Good stuff to know. Glad I made a decision to just get the drop in filter.
Old March 30th, 2004, 09:25 PM   #23
Doom's Avatar
rwhp?
Torquie is an auto and will dyno at a lower whp when stock. The intake showed that his car puts out as much as power as a stock 6spd.
Old March 30th, 2004, 09:30 PM   #24
Roadmaster's Avatar
Torques car made 196hp and likewise an automatic 2003 V6 sedan on VTEC.net produced the same numbers. If I remember correctly the stock 6-speed produced 212hp, almost exctly what SAM6's car produced.
Maybe its time to sell intake and go with a 6-speed intake
Dustin
Old March 30th, 2004, 09:34 PM   #25
Doom's Avatar
So your saying that Torquie dynoed as other stock 6spd Accords or autos. If you meant autos I stand corrected.
Oh and Torquie IS the guy on VTEC.net.
Old March 30th, 2004, 09:40 PM   #26
Roadmaster's Avatar
No, If I remember correctly Torqueaholic dynoed about 196 horsepower with his 2003 Automatic Coupe. His car, at the time was equiped with the Injen Intake System.
The Temple of VTEC car was a 2003 automatic Sedan, bone stock. That particular car produced 196hp at the wheels as well.
Now these were two different cars and two different dyno sessions... To be honest I don't know what to believe except that I know my car isn;t as strong as others (some stock) and I am beginning to reconsider my installation of the CAI
Dustin
Old March 30th, 2004, 10:10 PM   #27
Dustin
How come you think your car is not as strong as other?
S.A.M6 great dyno results! I will be doing my stock dyno in a month or two; I hope my results will be the same (if not better ).
Old March 30th, 2004, 10:29 PM   #28
Roadmaster's Avatar
[email protected] is the reason why I think my car is not as strong. The MPH just doesn't support the power. I always have blamed the track Indianapolis Raceway Park in Indianapolis... Which is notorious for poor times.
I need to get my car dynoed and see exactly what it is putting down to the ground. That will prove if my car is strong or not.
Old March 30th, 2004, 10:42 PM   #29
193.6ft/lb5200!
good numbers! your pretty much getting what Vtec.net got stock-5whp, not bad! torque numbers are spot on, yes. Did you dyno in 4th gear? I'm guessing yes. all in all good job!
well, I know for a fact that just a CAI, isn't going to produce the "20whp" on a 6spd, that some aftermarket companies have us believe. However, the reason, you "lost power", could just be that your engine got kindda hot! I have dynoed the most out of any member here, and let me tell you that the J series motor LOVES being cold! so, unless you were monitoring coolant temps, live TOV does, then Yes, after you dyno a while, its not odd to see the huge loss in power, because the ecu pulls timming due to heat soak. When we wait for like 20 mins, and then dyno again, BAM, the HP comes back!
Old March 30th, 2004, 10:45 PM   #30
yeah, I was kindda the first on here to discover that they are not doing anything, alone, on the car, but if you remember I got FLAMED big time for that post! This car will produce more power, but as russianrsx demonstrated: Not without exhaust+ecu.
