intake install questions - Honda Accord Forum : V6 Performance Accord Forums
Old April 10th, 2004, 01:24 AM   #1
hey, i hope this is not a repeat
I wanna install my V2 intake and my problem is i dont want to take my stock intake out wrong. Does anyone know where i can find instructions to remove the stock system? Also, does anyone know a trick to take it out. If anyone can get back to me, i would grealy appreciate it.
Akash
datecmaster is offline   Reply With Quote Quick reply to this message
Old April 10th, 2004, 04:04 PM   #2
Just jank it out. It's all common sence. Take a risk for once and f0ck the instructions!
vsmack is offline   Reply With Quote Quick reply to this message
Old April 10th, 2004, 06:41 PM   #3
yeah just yank out the screws holding it
unrealcpu is offline   Reply With Quote Quick reply to this message
Old April 11th, 2004, 03:29 AM   #4
The thing that will scare would probably be the bumper removal. It's very easy. When u pop the hood u'll see some weird black plastic clips. Get a really flat screwdriver and lift it up(dont scratch em remember). Then when the thing goes up, pull it with ur hand. Do em with the rest connected to the bumper. U'll also need to remove the screw on the bumper by the fender and some in the bottom. There are a bunch of clips in the bottom as well so take em out. After u take em all out, remove the bumper starting from any side. Pull it with some force, but don't be an animal.
After u remove the bumper, remove the battery since it's gonna make it easier to work with the removal of the factory intake box. Take the box where the battery hangs out, and then remove the screws holding the intake and the tube that's connected to the intake close to the throttle. U'll notice it's gonna be tricky to remove the resonator box at the bottom. Just seperate them from the bottom and then pull the one on the left upwards if ur looking towards the engine bay after u remove the one from right by pulling it down. After that just install the intake like the instructions tell u too and ur set. Then install the bumper back, and make sure the clips are in securely. U have to make sure they're stuck there good. U don't want to bumper falling off or the plastic covers in the bottom. Just remember how tight it was at the beggining and make sure it's that tight after the installation.
I hope this helps. I didn't use any manual or anything. I just looked and removed whatever had to be removed. If ur intimidated, get a friend to help you. Don't let some juppy charge 2million bucks for such a fun simple install.
Old April 11th, 2004, 09:23 AM   #5
i didnt have to remove the bumper and it took 2 hours to do the CAI.
I wouldnt risk takeing the bumper off and breaking clips. No need. All you have to do is jack up the car and take off the drivers sside tire and remove the fender linning under the tire well.
Its stupid to take off the bumper
Old April 11th, 2004, 02:43 PM   #6
Something Something Darkside
Doom's Avatar
Check my sig.
V6P Senior Moderator
Old April 11th, 2004, 03:56 PM   #7
No it's not. It's actually easier than jacking up the whole car and removing the tire and the fender lining. With the bumper out of the way, it makes really easy to take out the resonator box. The clips aren't gonna break either so I would say removing the bumper is the way to go. It only takes like 8 min to take out.
Old April 11th, 2004, 04:51 PM   #8
Doom's Avatar
I think it depends if you car is lowered too. I cant take off my bumper without jacking up the car.
Old April 11th, 2004, 07:11 PM   #9
id rather take off the wheel liner than the bumper due to it might scratch or something might not be put on right again. But its all up to its your 2004 accord not mine
IMO
