aftermarket flywheel.. what you think? - Honda Accord Forum : V6 Performance Accord Forums
Old April 19th, 2004, 01:43 AM   #1
I AM LOST....
brex's Avatar
Alright.. some new aftermarket performance part out now.. its ACT ProLite forged flywheel..
http://www.atmotorsports.com/product...roducts_id=284
one of the key phrase -
Lightweight flywheels keep less inertia in storage but the lighter rotating mass provides significantly improved engine response and acceleration characteristics
so what does this mean.. in normal way of speaking!?
Old April 19th, 2004, 01:55 AM   #2
Re: aftermarket flywheel.. what you think?
Anything that is rotating within the powertrain is potentially power sucking. A lightened flywheel has a similar effect on power as pulleys, lighter and easier to spin. However, a lighter flywheel also makes it harder to drive the car and easier to bog.
That being said, I believe only manual cars have flywheels, so only they can use this mod.
outersquare is offline   Reply With Quote Quick reply to this message
Old April 19th, 2004, 02:05 AM   #3
vroom vroom
ctsport's Avatar
Is this the same brand that is famous for ACT clutches?
Thanks for the link brex! they also carry a lot of other Accord stuff!
like this one! http://www.atmotorsports.com/product...roducts_id=283
Iam going to buy these when I get my big brake kit
Old April 19th, 2004, 02:06 AM   #4
I AM LOST....
brex's Avatar
yes.....
Old April 19th, 2004, 07:18 AM   #5
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
I think automatics do have one.
Doesn't the torque converter bolt to the flywheel on autos? And doesn't the starter gear engage the teeth on the perimeter of the flywheel to turn the engine over when starting?
Old April 19th, 2004, 07:20 AM   #6
I AM LOST....
brex's Avatar
Oh.. yeah.. Hawk pad for 6MT had being out for awhile now.. so is axxis ultimate.. sigh...
but as for using them for bbk.. these are not designed for bbk.. these are designed to be used with stock caliper.. with bbk.. u gotta buy their pad.. nothing else..
Old April 19th, 2004, 10:47 AM   #7
yes they do. it's thin and light, no need for improvement.
S.A.M6 is offline   Reply With Quote Quick reply to this message
Old April 20th, 2004, 12:22 AM   #8
Originally posted by S.A.M6
yes they do.
No, they don't. They bolt to a flexplate when using an automatic, flywheel for manuals. The two do not interchange, and are built much differently.
You don't want this light weight flywheel. Not until your motor is a high rpm, high HP motor that isen't going to be used for light driving
Old April 21st, 2004, 12:21 AM   #9
Exactly, you wont need one of these until you most likely turbo/ supercharge it and or add a better throttle body.
TheRequiem is offline   Reply With Quote Quick reply to this message
Old April 21st, 2004, 01:58 AM   #10
I AM LOST....
brex's Avatar
thanks for all the info..
Old April 21st, 2004, 07:46 AM   #11
mishima8's Avatar
Send a message via AIM to mishima8
It's bogus anyway. Tracey pulled it after he found out his distributer was giving him incorrect info.
J.
2003 Accord 6 Speed
"sweetness is in the speed"
mishima8 is offline   Reply With Quote Quick reply to this message
