? on Borla exhaust tip extension. - Honda Accord Forum : V6 Performance Accord Forums
Old May 18th, 2004, 02:00 PM   #1
I Jumped Off Da Bandwagon
Hongda's Avatar
Unhappy ? on Borla exhaust tip extension.
Did you guys have trouble finding a shop to do this? I went to 3 shops already and they said they couldn't do it. Whether they didn't have enough room to cut or they didn't have any stainless steel pipings and what not. I had the rear under spoiler installed yesterday and it needs to be extended. And if anyone from 408/510 area that had this done, which shop did you go to?
Old May 18th, 2004, 03:33 PM   #2
Hongda's Avatar
Well i guess i hafta go from shop to shop to see if someone is able to do this.
Old May 18th, 2004, 04:15 PM   #3
I still have to get mine extended too...
The place you go to needs to have a TIG welder...which is the only welder that can weld stainless steel...that may be the problem.
Also, have them weld it somewhere in between the actually Muffler and the tip...
AccordEXGirl is offline   Reply With Quote Quick reply to this message
Old May 18th, 2004, 05:20 PM   #4
Hongda's Avatar
Thanks for the info Nikki!
Old May 18th, 2004, 08:20 PM   #5
No problem! Also, like you said about the stainless steel piping...you can only weld stainless steel to stainless steel. You should be able to find a shop somewhere that can do that.
Old May 26th, 2004, 12:01 PM   #6
Not true. Steel and stainless can be welded together with no problem. Anyone that welds steel can weld stainless. There is no special equipment needed. Matter of fact, most welding wire (used on plain steel) is made of stainless steel.
2003 VTEC is offline   Reply With Quote Quick reply to this message
Old May 26th, 2004, 12:03 PM   #7
Ok well thats not what I was told by a shop....
Old July 16th, 2004, 04:14 PM   #8
Member
AV6on19s's Avatar
Send a message via AIM to AV6on19s
I have Borla exhaust but I have no rear lip, I was going to order it but I dont understand what the problem is? My stock exhaust was in the same exact place as the Borla. Is the problem that the lip extends OVER the tips, so the tips are just set back? If that's so it is not necessary the tips have to be extended correct? Thanks!
Tom
2003 Honda Accord EX V6 6MT (SOLD)
2003 Honda Accord EX V6 AT (Sedan) (SOLD)
AV6on19s is offline   Reply With Quote Quick reply to this message
Old July 16th, 2004, 04:50 PM   #9
I AM LOST....
brex's Avatar
The way it came from Borla fits car without rear lip perfectly.. it is only when someone have a body kit (ie, oem rear lip) then extension is needed...
Old July 17th, 2004, 01:59 AM   #10
Member
AV6on19s's Avatar
Ok, but does it actually not fit until the exhaust tips are extended or can you install the rear lip and then after fix the tips?
Old July 17th, 2004, 02:39 AM   #11
I AM LOST....
brex's Avatar
oh.. it is not the question about "fit' or not.. its only the look factor.. they will "fit" with or without lip.. but with lip.. the tip is all covered up unless you extend..
Old July 17th, 2004, 11:37 AM   #12
Member
AV6on19s's Avatar
Gotcha!
