6MT Front brakes on Sedan - Honda Accord Forum : V6 Performance Accord Forums
Old May 28th, 2004, 02:07 PM   #1
AKKV603's Avatar
I was wondering if anyone has swapped the front brakes out of a 6 speed to a sedan. I have cross drilled rotors and 04 pads on my 03 and I am still not getting smooth braking. SO I want to upgrade. Anyone know what I would need to buy or if any parts are interchangeable.
THANKS
2003 Redondo Red EX V6 Sedan
AEM V2
CL S rear sway bar
Powerstop front rotors
oem lip spoiler
AKKV603 is offline   Reply With Quote Quick reply to this message
Old May 28th, 2004, 05:28 PM   #2
you should get rid of the cross drilled rotors and replace them with quality OE brembo blanks.
that should not only improve the bite, but also smooth out your braking.
Old May 28th, 2004, 08:40 PM   #3
Who's yo daddy?
Mackdaddy's Avatar
6MT calipers. Both use the same knuckles. 11.8" rotors & pads from the 6MT as well.
This will take you from 11.1" to 11.8" Not only that, but Hawk has pads readily available for this setup. That in itself would help tremendously.
I've been contemplating doing this for some time. The only problem is the calipers are ~ $167 each from Majestic Honda. I don't know if it will give me the braking I'm looking for, so needless to say I haven't done it yet.
2010 PMM Accord EX-L V6 Navi Sedan
Mackdaddy is offline   Reply With Quote Quick reply to this message
Old May 29th, 2004, 01:51 AM   #4
vroom vroom
ctsport's Avatar
I've driven my co-worker's auto coupe many times and you can definately feel the difference. For 400 dollars + cost of Hawk pads I think its definately worth it if you DIY imo. Also it looks a lot bigger/better when comparing side by side.
Old May 29th, 2004, 07:02 AM   #5
Who's yo daddy?
Mackdaddy's Avatar
Just what I wanted to hear. Words of encouragement.
Thanks!
Old May 29th, 2004, 08:10 AM   #6
V6Sedan04's Avatar
the AV6MT front discs/calipers would be good on my sedan.
the 04TL6MT brembo calipers/discs would be VERY good. somebody is going to figure out what it takes to fit them up one day.
V6Sedan04 is offline   Reply With Quote Quick reply to this message
Old May 29th, 2004, 08:14 AM   #7
Who's yo daddy?
Mackdaddy's Avatar
I tried to figure that one out early on... I think it'll work with TL knuckles (although still not sure.)
Old May 29th, 2004, 12:20 PM   #8
AKKV603's Avatar
What about caliper brackets? Or do they come with the caliper assembly on hondas? Any probs with clearance on stock 16" wheel??
Old May 29th, 2004, 01:33 PM   #9
04 TL 6MT Brembo calipers and discs combo is what I'm waiting for. I already got the Brembo blanks with ceramic pads.
Blue03 is offline   Reply With Quote Quick reply to this message
Old May 29th, 2004, 10:44 PM   #10
Who's yo daddy?
Mackdaddy's Avatar
Accord coupe 6-spd manual 11.8" rotors & calipers will fit behind 16" wheels, this I know. Otherwise, I wouldn't do it (I'll have to use my stock 16's for winter driving.)
Old May 30th, 2004, 03:01 AM   #11
I don't know about the 7th gens, but on my 6th gen I put the TPM rotors on from stock blanks and noticed a large increase is braking bite, which is exactly what the 6th gen needs. I don't see it going any different on the new models.
Old May 30th, 2004, 03:03 AM   #12
So, have you done it? How's the different compare to stock?
bigjason is offline   Reply With Quote Quick reply to this message
Old May 30th, 2004, 07:33 AM   #13
Who's yo daddy?
Mackdaddy's Avatar
It didn't. My new slotted & dimpled rotors on all 4 corners (with OEM Honda pads) made an improvement in braking bite as well. No oversize rotor, stock diameter.
I want to try Hawk pads with these before jumping into the 6MT ($$$) caliper / rotor game.
