Brake Lines / Pad - Rotors - Honda Accord Forum : V6 Performance Accord Forums
Old May 30th, 2004, 07:43 PM   #1
Does anyone know if there are going to be any stainless steel brake lines available anytime soon? Or front brake pads with an agressive compound? I've searched and only seen rear pads and front/rear rotors. No luck finding any brake lines.
Blue2Jay20 is offline   Reply With Quote Quick reply to this message
Old May 30th, 2004, 08:46 PM   #2
I AM LOST....
brex's Avatar
who knows...
go get bbk..
Old June 1st, 2004, 07:39 PM   #3
If your looking into upgrading your front brakes look into upgrading to some Rotoras. Rotora has a big brake kit for our V6 Accord Coupes with I believe 12 or 13in slotted front rotors that come with aggressive street brake pads, two or four piston (not too sure) brake calipers and stainless steel brake lines. Cost of the kit... a wallet busting +$1600 I believe. Rotora does have rear rotors to match the fronts. Checkout www.rotora.com for more info.
D R E W is offline   Reply With Quote Quick reply to this message
Old June 1st, 2004, 07:43 PM   #4
Oh... you have the 4DR Sedan... uh your SOL. unless the Coupe and Sedan share the same brake components. The 6spd MT Accord Coupe has bigger rotors than the auto V6 Coupe/Sedan FYI.
Old June 1st, 2004, 08:11 PM   #5
vroom vroom
ctsport's Avatar
Thats pretty cheap for a full brake replacement.
The Spoon calipers alone cost more than that entire setup.
Old June 1st, 2004, 08:46 PM   #6
Still pricey... your baller status if you can afford Spoon Calipers at what... $2300? At Hot Import Nights in Seattle there was a 03' Accord Coupe V6 with Spoon Calipers and tasty bronze Advan Model 5s in 19s. I failed to take pics of the Spoon Calipers... I'm ashamed of myself.
Old June 1st, 2004, 10:09 PM   #7
Man... I would kill for some Spoon calipers. Very nice sig. I'm a big fan of big brake kits... mainly for the bling-bling factor tho. I'll be happy with AEM carbon-black slotted big brake kit but those fun-boys have yet to release it for the 7th Gen. Accord V6 Coupe because according to them they want to get rid of the current stock before releasing the carbon black rotors. AEM is notorious for sh*t like that.
Yeah a Pacific NW meet would be nice! We could even invite the guys up north. I'm from the Tacoma aroma area and I wouldn't mind socializing with some Seattle people if you guys aren't embarassed to be seen with a Tacoman..
Old June 1st, 2004, 10:23 PM   #8
Ahhh... here it is. 03' Accord V6 Coupe (Taffeta White) with bronze 19in Advan Model 5s, OEM kit, Spoon calipers, and probably the first in the PNW to have the Greddy Evo dual exhaust system. It's a 5spd Automatic (who cares) sponsored by Fast Lanes in Tacoma.
Old June 1st, 2004, 11:50 PM   #9
vroom vroom
ctsport's Avatar
Thanks for the pic Drew!
Anyways they look a bit small on the Accord. Is that car local?
PS. I think the Kruzuers is a much better choice.
PSS. Would you happen to have a link to his page? I don't seem to be able to find his car on cardomain. Thanks!
03 SBP J30A4 6MT
Old June 2nd, 2004, 04:11 AM   #10
vroom vroom
ctsport's Avatar
For those who don't know what we're talking about:
This brake upgrade can fit almost any Honda.
Oops sorry for going way off topic.
03 SBP J30A4 6MT
Old June 2nd, 2004, 04:37 AM   #11
I AM LOST....
brex's Avatar
look nice.. is that just caliper upgrade?
Old June 2nd, 2004, 05:00 AM   #12
vroom vroom
ctsport's Avatar
Yes and no, you can buy the entire kit which comes with Spoon 4 piston monoblock calipers, Spoon AP1 bracket, Spoon SS lines, Spoon drilled (cast) rotors, and Spoon Pads. Probably run you 3-4K USD since it also requires a bit of custom fitting.
03 SBP J30A4 6MT
Old June 2nd, 2004, 05:13 AM   #13
I AM LOST....
brex's Avatar
****.. cost hella much.. i am looking at a 6-pots system with 360mm x 30mm rotor.. for 2k installed.. both caliper and rotor are cast alluminum...
but then of course spoon is a much better name..
Old June 2nd, 2004, 07:46 PM   #14
The car is local (Tacoma) and sponsored by Fast Lanes on South Tacoma Way. The car had stock size rotors with the Spoon calipers. I used cardomain.com to host that one pic
Brex - It's just the calipers mated to some factory size rotors... most likely Brembo blank rotors. Have you looked into Rotora (www.rotora.com)? Cost is less than $2000 (about $1600) for everything (front kit only). Unless your pushing massive power thru the wheels the 6 piston caliper would kinda be over-kill on the Accord. A 4 piston caliper is more than enough and currently Rotora is the only company that has a big brake kit for our 7th gen. Accords.
AEM does have the big brake kit but the caliper, stain-less steel brake lines, and pads don't come with the kit.
Old June 2nd, 2004, 08:00 PM   #15
I AM LOST....
brex's Avatar
Yeah.. I have looked at Rotora and would have installed it since for a BBK, its not really expensive.. but i always shop around and found this deal.. so now weighting on the quality of the product.. i have heard some bad stories about rotora..
Old June 2nd, 2004, 08:03 PM   #16
mQike has the Rotora BBK installed on his 03' Accord Coupe. He has the inline-4 but you may want to ask him his opinions on the kit.
Old June 2nd, 2004, 08:07 PM   #17
I AM LOST....
brex's Avatar
Yeah.. so far I know Mike had said the installation was very hassle.. and need more parts than usual to get it working... perhaps it was just his old wheel that was causing the problem..
hmm...
Old June 2nd, 2004, 08:14 PM   #18
Yeah wheel offset does play a big part in having a big brake kit. He may of had a good wheel offset but sometimes the wheels spokes or mesh design sometimes doesn't clear the calipers.
mQike had RH Evolution C5 in 19s with a polished lip and a lot of wheels with lips will have caliper clearance problems. I believe his car was a testor for Rotora so that kinda answers a lot of questions when your a testor for a prototype aftermarket modification.
Overall, the kit looks very nice and if I had that kind of cash I would have gotten the kit myself.
Old June 2nd, 2004, 09:25 PM   #19
doesnt brembo make a bbk?
Redman6986 is offline   Reply With Quote Quick reply to this message
Old June 2nd, 2004, 11:17 PM   #20
Not for the 03' to 04' Accord V6 Coupe or Sedan.
Old June 3rd, 2004, 11:21 AM   #21
vroom vroom
ctsport's Avatar
The Brembo Evolution line does have a kit for the 98+ AV6/TL/CL. That might bolt up with our cars.
Its expensieve but it is a complete kit. Check it out on either Brembo's site or Comptech's site.
Also, what is special about Spoon Calipers is that they are designed with Honda specs in mind thus they can work with any pad that works with the original car (Monoblock= Accord V6, RSX, S2000) Maybe thats something you'd should consider when shopping for BBK
03 SBP J30A4 6MT
Old June 3rd, 2004, 03:35 PM   #22
I AM LOST....
brex's Avatar
Originally posted by ctsport on June 3rd, 2004 at 09:21 AM
Also, what is special about Spoon Calipers is that they are designed to Honda specs thus they can work with any pad that works with the original car (Monoblock= Accord V6, RSX, S2000, even stock pads work!) Maybe thats something you'd should consider when shopping for BBK
I heard Brembo usually take few months before it is delivered to you.. unless they have already have stock which I consider not possible for accord..
How much is this spoon caliper gonna run.. and how is it suppose to be better than oem when it is not a big brake kit?
Old June 3rd, 2004, 04:19 PM   #23
vroom vroom
ctsport's Avatar
Its a 4 pistion big brake kit.
03 SBP J30A4 6MT
Old June 3rd, 2004, 08:59 PM   #24
Who's yo daddy?
Mackdaddy's Avatar
Lightbulb TireRack shows a Brembo BBK for us!
Just an FYI.....
http://www.tirerack.com/brakes/resul...track&x=95&y=9
2010 PMM Accord EX-L V6 Navi Sedan
Mackdaddy is offline   Reply With Quote Quick reply to this message
Old June 3rd, 2004, 11:20 PM   #25
I AM LOST....
brex's Avatar
Re: TireRack shows a Brembo BBK for us!
Originally posted by Mackdaddy on June 3rd, 2004 at 06:59 PM
Just an FYI.....
Yeah.. its listed for a long time.. but notice "special order"? makes you wonder how long it will take you to get it..
Old June 12th, 2004, 12:48 AM   #26
pads/rotors
I have 03 Accord v6 Sedan with the following brake lineup:
Front Rotors: Brembo slotted and cross-drilled
Front Pads: EBC Redstuff
Rear Rotors: Powerslot slotted
Rear Pads: EBC Greenstuff
NO PROBLEMS STOPPING HERE!!!!!!!!!!
kavijanu0515 is offline   Reply With Quote Quick reply to this message
Old June 12th, 2004, 07:22 AM   #27
tirerack.com has a brembo 328mm front brake kit. It looks like it comes with rotors calipers pads and stainless lines.
http://www.tirerack.com/brakes/brake...+Big+Brake+Kit
this is the link for the brake kit
odie77k is offline   Reply With Quote Quick reply to this message
Old June 12th, 2004, 07:26 AM   #28
You guys should check out tirerack.com they have a lot of brake stuff different types of pads and rotors and lots of different brands too. they also have lighting and suspension stuff and obviously rims and tires.
Old June 12th, 2004, 07:34 AM   #29
sorry didn't see the earlier post about the tirerack but you guys should check it out anyway.
We use them all the time at my work and when something needs to be ordered it doesn't take as long as you think it would.
Old June 12th, 2004, 08:06 PM   #30
Brex, I am strongly considering the Rotora BBK for my sedan. Would you mind sharing some of the bad stories you heard? I appreciate the time.
AMV6 is offline   Reply With Quote Quick reply to this message
