eBay V6 High Flow Cat a Joke? - Honda Accord Forum : V6 Performance Accord Forums
Old July 16th, 2004, 12:44 AM   #1
_
0430Steve's Avatar
Are the aftermarket chromed out and other so called Mugen high-flow cats anything worth buying for the I4 or the V6? They are only $35 or something and if they open up air flow with intake or exhaust wouldn't it be beneficial, especially for the price, or is this a piece of crap? Anyone "taken one for the team" here? Someone mentioned it, but if you have $0.02, let's hear it.
Old July 16th, 2004, 01:30 AM   #2
fonda my honda
Send a message via AIM to tx03coupe
the only $35 you can spend to make your car go faster is a tank of premium fuel.
www.crushkerry.com
tx03coupe is offline   Reply With Quote Quick reply to this message
Old July 16th, 2004, 02:08 AM   #3
it's a resonator that replaces your cat. probably the best way to spend $35 to make your car go faster.
even though the cats on the current accords flow very well, nothing flows as well as an empty pipe. write that down.
Old July 16th, 2004, 02:37 AM   #4
If you replace it with a resonator or straight pipe, you'll have to buy O2 sensor simulators.
Genius6Spd is offline   Reply With Quote Quick reply to this message
Old July 16th, 2004, 02:47 AM   #5
nah not really. the MIL that comes up is only an alert. it won't put your car into limp mode.
Old July 16th, 2004, 02:59 AM   #6
True (most of the time anyways) but you will always have a CEL light on. You will never know if the CEL light is on because of that O2 sensor or from another problem. So an O2 sensor simulator would be a wise investment .
Old July 16th, 2004, 03:30 AM   #7
not if you're awesome like me and have an OBD2 scanner hooked up to your palmpilot!
Old July 16th, 2004, 03:40 AM   #8
I am awesome like you because I have one as well hehe .
http://www.v6performance.net/forums/...ad.php?t=20711
http://www.v6performance.net/forums/...3&postcount=22
But even with that it's still annoying to always have to check for codes. An O2 simulator would be the best idea.
Old July 16th, 2004, 10:29 AM   #9
Member
AV6on19s's Avatar
Send a message via AIM to AV6on19s
Cant you just turn the CEL light off? Or will it keep coming back on?
Tom
2003 Honda Accord EX V6 6MT (SOLD)
2003 Honda Accord EX V6 AT (Sedan) (SOLD)
AV6on19s is offline   Reply With Quote Quick reply to this message
Old July 16th, 2004, 10:33 AM   #10
you gotta rub to dub!
relentless's Avatar
Ill jump in on this since I have done it. I have a straight pipe on my car since I got my magnaflow put in and it does not throw any CEL's. Our cars have 3 cats and I had the third one removed which is the one in the exhaust system. The other 2 are at the block which you cannot remove. The one on ebay is a pretty good buy since its bolt on. Mine was welded on since I had mine done before ebay offered any. So if you remove the 3rd cat, you will not throw any CEL's because there is no sensor after the first 2 cats.
Old July 16th, 2004, 10:42 AM   #11
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
So i3igpete says it'll throw a cel light, and relentless says it doesn't. Why does it throw it on some cars and not others?
Old July 16th, 2004, 11:49 AM   #12
Northcoast Tuner
Well i3igpete has a 4-cylinder, and Relentless has a V6. That could be the difference
http://members.cardomain.com/josephip
Old July 16th, 2004, 01:10 PM   #13
Member
AV6on19s's Avatar
Hey, did you happen to put on the straight pipe AFTER the magnaflow or all at once? Did you notice any increase in exhaust tone? I like my Borla exhaust but its actually a bit too quiet and a straight pipe for $35 might fix it!
Old July 16th, 2004, 11:05 PM   #14
There's no sensors after the 3rd cat on the V6s. go ahead and take it off!
cats are so restrictive....
*check your local emission rules before you do that *
CM817
Curry619 is offline   Reply With Quote Quick reply to this message
Old July 17th, 2004, 02:30 AM   #15
Tom
No, you can't just turn it completely off because it's there for a reason. You can clear the O2 code which will turn the CEL light off. But in this case it will come right back on since the problem is still there.
Thatís good to know for the 7th gen AV6 owners. 7th gen inline 4 owners will still need an O2 simulator though.
Old July 17th, 2004, 03:15 AM   #16
relentless's Avatar
I noticed an increase in exhaust tone when comparing other V6er's maganaflow. So yes, yours will be louder if you put on a straight pipe.
Old July 17th, 2004, 03:45 AM   #17
can always pull the blub
CM817
Old July 17th, 2004, 04:07 AM   #18
Yeah but then you will have trouble knowing if there is a problem with the engine.
And here's an example of what will happen if you do that.
You: My engine is acting funny.
Dealership: Ok well look at it.
10 minute later....
Dealership: We pulled 5 stored trouble codes but can't figure out why your CEL light isn't on.
You: I took it out.
Dealership: WTH did you take it out?
You: Because I took out the cat and was to lazy to get an O2 simulator.
hehe
