Baseline dyno tomorrow, test air/fuel ratio? - Honda Accord Forum : V6 Performance Accord Forums
Old July 30th, 2004, 09:12 AM   #1
Jinx32's Avatar
Should I spring the extra 25 bucks to get the air/fuel ratio measured as well?
When I get home, I will reset the computer and put on my V2. Then I drive it around for a week and go back.
I believe that just throwing on an intake without driving it around for a tankfull of gas or so, won't allow the computer to recalibrate itself properly, so I will be taking it back a week later for more runs.
Runs will by on a Dynojet and SAE corrected graphs, rpm vs HP & Tq.
04 V6 6sp, 4300 miles, Amoco Premium fuel only and always. Bone stock except shocks (FP) and Comptech rear sway.
Jason
Jinx32 is offline   Reply With Quote Quick reply to this message
Old July 30th, 2004, 09:24 AM   #2
Would you also then (after the 2nd dyno with the V2), kindly switch to regular 87oct fuel and run another dyno? I guess you'll have to empty your tank first tho.
Then you shouldn't need to wait too long ... just drive the car around hard to kick down the timing.
Pleeeaaase ....
Old July 31st, 2004, 05:06 PM   #3
Jinx32's Avatar
I'm back. How do I post pics? I also video taped it and put it in an mpg. Have hard copy printouts right now but should receive emailed files on Monday.
All runs SAE
216.2 @ 6300
194.7 @ 5200
2nd run was about 1hp and 1lbft less
3rd run we pulled fuse 7 for a couple minutes to see if it would reset the ecu. You could see the curve was going to follow a lower path, then at 3500, the graph jumps up to match the others. Heat soak I guess resulted in a third run of
211.5 and 191.2
V2 is now installed, didn't drive it yet though.
Converted to STD the first run = 221.3 & 199.2
J
Old July 31st, 2004, 06:38 PM   #4
Something Something Darkside
Doom's Avatar
Post them into your gallery and I'll tell you how to link it here.
V6P Senior Moderator
Old August 4th, 2004, 06:17 PM   #5
Jinx32's Avatar
It won't let me post, throws all kinds of errors at me.
J
Old August 5th, 2004, 08:58 AM   #6
Doom's Avatar
Email me the pics and I'll post them. [email protected]
What happened exactly?
Old August 5th, 2004, 11:53 AM   #7
Jinx32's Avatar
Check yer email. Thanks.
J
Old August 5th, 2004, 09:06 PM   #8
Doom's Avatar
Old August 6th, 2004, 08:07 AM   #9
Jinx32's Avatar
I can post in the gallery now Thank you for your help. Here is the before and after runs.
I also have a 3 meg video of these two runs for comparison. Don't know where to post it though, and it needs a VP40 codec to play it.
J
Old August 6th, 2004, 08:45 AM   #10
"Certified Hybrid Killer"
SteVTEC's Avatar
wow, so somebody finally matched the VTEC.net 217hp/195tq stock dyno. nice.
Old August 6th, 2004, 09:14 AM   #11
Formerly VTEC-v6!
N54TT's Avatar
What kind of dyno was that on?
Btw, check out the dip where your vtec engagement is set at...you might need to push it back a little
Old August 6th, 2004, 09:39 AM   #12
Jinx32's Avatar
Dynojet 224. I thought that dip (4000rpm) was where the intake manifold switches over and VTEC engagement occurs at 4900rpm (see second little hump around this point). When measured in STD (instead of SAE) it was 233HP
"Hello, 350Z?" "I got yer number from a friend and was wondering if you can come out and play?"
J
Old August 6th, 2004, 09:45 AM   #13
raff is offline   Reply With Quote Quick reply to this message
Old August 6th, 2004, 10:03 AM   #14
woot woot
Old August 6th, 2004, 10:26 AM   #15
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
Nice numbers Jinx32.
There's very little dip where vtec engages, from my point of view. However, there is definately a dip where the dual stage intake switches over. Is that what you mean??
Old August 6th, 2004, 11:20 AM   #16
Formerly VTEC-v6!
N54TT's Avatar
I made a common dyno misconception
Old August 6th, 2004, 11:25 AM   #17
J
So with mod you're pushing 226(can't see clearly)?
herzzreh is offline   Reply With Quote Quick reply to this message
Old August 6th, 2004, 11:37 AM   #18
Jinx32's Avatar
228.2, 200.9 Made it larger up above, sorry.
J
Old August 6th, 2004, 11:54 AM   #19
damn thats a nice gain off the intake alone, 12hp/6ftlbs, i guess AEMS claim, although not accurate, wasnt TOTALLY crazy.
JPAccord is offline   Reply With Quote Quick reply to this message
Old August 6th, 2004, 02:23 PM   #20
Doom's Avatar
I can post in the gallery now Thank you for your help. Here is the before and after runs. J
Thank Francis. He fixed your gallery setup.
Old August 6th, 2004, 02:37 PM   #21
How does the v2 sound? Especially the loudness..
All runs SAE
216.2 @ 6300
194.7 @ 5200
211.5 and 191.2
J
Old August 6th, 2004, 03:22 PM   #22
Jinx32's Avatar
Like I mentioned above, I have a full video of both run 1 (best stock) and 4 (best AEMV2). It's 3 megs but will require the VP40 codec. I have the codec and mpeg zipped into a 4 meg file. Just need someone to post it. I can email it to anyone that can receive a 4 meg file as well.
J
Old August 6th, 2004, 08:15 PM   #23
J
Please send video my way thanks.
PM sent.
Old August 6th, 2004, 10:22 PM   #24
vroom vroom
ctsport's Avatar
Nice curves!
Old August 6th, 2004, 11:56 PM   #25
My AV6 is all gone...
6spdcoupe's Avatar
Send a message via AIM to 6spdcoupe
Nice runs...when I had my V1 and Tanabe CB I only resulted with 227.4/200.9. Im guessing wheel size/hot engine and humidity played somewhat of a part in that?
--Don
6spdcoupe is offline   Reply With Quote Quick reply to this message
Old August 7th, 2004, 10:03 AM   #26
nice run-228hp!. Definately beats my dyno V2 run. I definately have to go back on a better day.
S.A.M6 is offline   Reply With Quote Quick reply to this message
Old August 7th, 2004, 05:18 PM   #27
Nice gains, can't wait to get my (undamaged) V2
JoeySmallz is offline   Reply With Quote Quick reply to this message
