V2 high pitched squeel driving me NUTS! - Honda Accord Forum : V6 Performance Accord Forums
Old August 14th, 2004, 06:35 AM   #1
Jinx32's Avatar
Between 2k and 3k rpm my V2 makes this high pitched squeeling noise. Sounds like brake squeel. It only does this when you tap the throttle to slowly resume speed. (which is like all the time when traveling with a pack of cars!) Does anyone/everyone elses do this or do I have to remove the whole thing to see if it goes away with the stock airbox.
J
Jinx32 is offline   Reply With Quote Quick reply to this message
Old August 14th, 2004, 07:30 AM   #2
I've heard what you describe also, and it seems to happen around the same rpm range to me as well, but only lasts briefly. I think it's the sound you hear before it reaches that critical resonance of the sound waves maybe .
Old August 14th, 2004, 09:29 AM   #3
Finally, someone else is experiencing this as well. This is very annoying, but I'm glad it's the V2 and not something else.
tcador is offline   Reply With Quote Quick reply to this message
Old August 14th, 2004, 10:25 AM   #4
you know, if you're ever unsatisfied, you could always give it to me. . yeah, but i think Ivtec is right about the resonance.
Old August 14th, 2004, 10:39 AM   #5
fonda my honda
Send a message via AIM to tx03coupe
my injen does this as well. very high squeel right around that rpm range. it's common with cai i think.
tx03coupe is offline   Reply With Quote Quick reply to this message
Old August 14th, 2004, 12:08 PM   #6
_
0430Steve's Avatar
My Injen does it too, right at 2500 rpm. Very annoying, makes my new car sound like it's been around the block, I wish I could get rid of it, but it is just a CAI thing.
Old August 14th, 2004, 02:54 PM   #7
Jinx32's Avatar
Thank you everyone. Saves me the trouble of messing around with it. I started thinking all sorts of badness, like slipping belts, broken/squeeky Butterfly actuator, etc. I'll leave it be and let it be the only hint it's been tweeked.
J
Old August 14th, 2004, 07:10 PM   #8
imo it sounds like a tiny lil blowoff valve lol
adamkim83 is offline   Reply With Quote Quick reply to this message
Old August 14th, 2004, 07:23 PM   #9
happens on my aem v1 too, its not loud though, can't even hear it if my music is on. It is annoying though
BConly is offline   Reply With Quote Quick reply to this message
Old August 14th, 2004, 07:36 PM   #10
I AM LOST....
brex's Avatar
what you guys don't keep the car above 3k rpm all the time??
j/k..
Old August 14th, 2004, 08:43 PM   #11
j/k..
problem solved
Old August 15th, 2004, 02:00 AM   #12
vroom vroom
ctsport's Avatar
j/k..
We 6speeds never have to rev that high
Old August 15th, 2004, 02:47 AM   #13
I AM LOST....
brex's Avatar
that only means u haven't really enjoy the good life above 3k rpm..
Old August 15th, 2004, 04:31 AM   #14
My G35 makes the same noise except at a different rev range. The AV6 does this all too often. Getting on my nerves too. IMO, it is the lack of a venturi ring that creates the whistling noise. Kinda like if you were to blow into a straw with the other end blocked off. Does anyone think adding a venturi ring will fix this noise issue?
I am thinking of adding a venturi ring just to experiment. If anyone knows of a reason why I shouldln't, I would appreciate if you let me know so I waste my time.
benjaminoh is offline   Reply With Quote Quick reply to this message
Old August 15th, 2004, 11:16 AM   #15
grrr. we don't talk to you. you have a g35. *jealous* grrrr. j/k. go for it. if it works more power to you.
Old August 16th, 2004, 02:30 AM   #16
I have a 04 AV6 also. My fiancee forbid me from modifying my G35
Old August 16th, 2004, 07:00 PM   #17
man, if your fiance is forbidding you from modifying your G35 with your money, you're going to have some serious issues when she's your wife. Good luck, bro
i4performance is offline   Reply With Quote Quick reply to this message
Old August 16th, 2004, 09:26 PM   #18
Yeah... funny as it sounds, she rather that I get a better car than get a cheap one and spend extra money on. I agreed because as soon as the GTR is out, I will jump on it without a second thought. She agreed.
Old August 17th, 2004, 09:02 PM   #19
I've got the same issue. I'll agree it can get a bit annoying, easy way to fix it as soon as I hear it stomp on the gas Heck it keeps the gas companies happy with me at least. And even at that the car drives much better over 3K rpm, at least the I feel like I'm moving somewhere then.
sweet03accord is offline   Reply With Quote Quick reply to this message
Old August 18th, 2004, 03:44 PM   #20
just had v2 installed. having the whistling sound right around 2500 rmp., it ll sound agian when the pointer drops down. very brief thou.
p.s. do i need to re-train the computer? what about driving behaviour(like a new break in?)? should i use the d3 instead of D while driving around in local?
jw80 is offline   Reply With Quote Quick reply to this message
Old August 18th, 2004, 04:03 PM   #21
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
I've never noticed it with my Injen CAI. I'll keep an ear out for it and see if it's there.
Old August 18th, 2004, 09:14 PM   #22
retrain the computer? didn't you guys have to remove the battery to remove the stock airbox? I removed mine so the the retrain computer was a given for me. I also ended up removing half the front bumper to reach all the screws properly.
Maybe I just did it the long way?
Old August 19th, 2004, 08:28 AM   #23
03LXV6Guy's Avatar
Listened for it..... and I don't have any type of squeel. None at all.
Old August 19th, 2004, 05:16 PM   #24
I guess that means that you don't have any power, none at all.. j/k
Old August 19th, 2004, 06:03 PM   #25
like the manual said, have to be very careful about the first 600 miles for a new car. So, since i reset the ecu, do i need to drive very carefully for some hundreds miles? although, i mashed the pedal a couple of times. Or just let the ecu adjust itself anyway like the other threads said.
for v6 couple, i think you need to pull the fuse #7(backup/ reinstall) to reset ecu. not just the bettery.
Old August 20th, 2004, 01:59 AM   #26
Pull the fuse?
Disconnecting the battery would have the same effect unless the fuse also shorted a circuit signaling the ECU to reset.
I know something was reset because my car got horrible gas mileage for the first 2 tanks of gas after I installed the intake. Things seem to be settling in now because because the gas mileage seems to be getting better. The same happened on my other cars whenever I disconnected the battery. It is like as if the ECU is slowly learning the engines optimum running parameters and adjusting itself to it.
Old August 20th, 2004, 09:05 PM   #27
i hear it alot in my car since i drive normally between 2k-3k rpm, sometimes its annoying and sometimes sounds like a small turbo, but i dont really mind.........
hpno7iq is offline   Reply With Quote Quick reply to this message
Old August 31st, 2004, 11:27 AM   #28
My car is still stock. I have sensitive hearing. Today I decided to listen to the car-windows up, xm off. I can hear that issue y'all are having with your CAIs. grrr, I can hear it at times.
7810_Accord04Co is offline   Reply With Quote Quick reply to this message
