1/4 mile @ Cali Speedway time suck!!! NEED HELP!!~ - Honda Accord Forum : V6 Performance Accord Forums
Old August 22nd, 2004, 04:04 PM   #1
Ursus's Avatar
Send a message via AIM to Ursus
Well guys.. yesterday was my first time @ a 1/4 mile track and I was hoping to run 14s w/ my Injen and Tanabe setup, but it turned out bad... here are my runs..
91 Octane tank 1/4 full
Car was push-staged
TSC OFF
Run 1 (no brake torquing, no tire chirping)
R/T .759
60' 2.415
330 6.566
1/8 9.937
MPH 72.14
1000 12.882
1/4 15.357
MPH 91.16
Run 2 (brake torquing, no tire chirping)
R/T .538
60' 2.446
330 6.612
1/8 9.981
MPH 73.11
1000 12.905
1/4 15.365
MPH 91.90
Run 3 (no brake torquing, tires chirped)
R/T .655
60' 2.435
330 6.609
1/8 9.981
MPH 73.49
1000 12.920
1/4 15.382
MPH 91.71
Is the main reason my R/T times?I should've gun it at the 3rd yellow but i'm always afraid to get fault start, cause I'm a noob.
Is it my stock Turanza tires?
It wasn't really all that hot but it was kinda hazy and humid.
I don't know what's wrong
Ursus is offline   Reply With Quote Quick reply to this message
Old August 22nd, 2004, 04:40 PM   #2
I'm Rick James B*tch
albaughrsx's Avatar
are you automatic or 6 speed. i have a vid of a automatic hitting 14.5s and a 6 speed hitting 14 flat. Both had aem V2 intakes and lowered with some nice rims and street tires. Always go on green.
albaughrsx is offline   Reply With Quote Quick reply to this message
Old August 22nd, 2004, 04:41 PM   #3
albaughrsx's Avatar
what did u run against? or maybe i don't even wanna know?
Old August 22nd, 2004, 04:56 PM   #4
R/T times don't affect ET.
tcador is offline   Reply With Quote Quick reply to this message
Old August 22nd, 2004, 05:45 PM   #5
Ursus's Avatar
yea dude if you can post that video it'll be awesome. Do they have any exhaust system? I have AT. Maybe I should switch Injen to V2? shxt.. wtf is going on.
Old August 22nd, 2004, 05:55 PM   #6
Bizzy Bone
R/T has nothing to do with it. It doesnt affect times at all. Look at your 60' times. Get the 60' time down by getting better tires or lowering psi just a little. Then you'll be fine.
Panther X is offline   Reply With Quote Quick reply to this message
Old August 22nd, 2004, 06:53 PM   #7
Roadmaster's Avatar
I am running 14.80's and 90's with my Automatic w/ an Injen CAI and Shell 93. I honestly had the hardest time getting into the 14's as well and eventually ended up manually shifting the car to get a few extra RPM out of the motor before it shifted. Typically the ecu auto shifts the car at 6,500rpm instead of at the cars indicated redline of 6,800. The extra revs put me back into VTEC and I was able to eak out about .2 of a second and a MPH.
No the stock tires are fine for mear bolt on's. I've have hit a few 2.25's and 2.28's on the stock tires. Honestly the car just doesn't have the torque off the line to really be traction limited on anything but the coldest days.
Keep trying and you will eventually hit the 14's. I am usually running in mid 70 degree weather and if it gets better I may click off a tenth.
Dustin
Roadmaster is offline   Reply With Quote Quick reply to this message
Old August 22nd, 2004, 07:09 PM   #8
VTECRACING87
dmxarnold's Avatar
Send a message via AIM to dmxarnold
yea your times are pretty slow for a 7th gen v6 coupe were you flooring it when you launched?
dmxarnold is offline   Reply With Quote Quick reply to this message
Old August 22nd, 2004, 07:11 PM   #9
Roadmaster's Avatar
Doesn't really matter that much. 03LXV6guy is beating my time with a sedan running 14.50's
It really comes more down to track and weather.
Dustin
Old August 22nd, 2004, 07:30 PM   #10
"Certified Hybrid Killer"
SteVTEC's Avatar
Cali speedway is at 1100 ft. NHRA correction tables for altitude don't start until 1200 ft, but running up there will make about a two-tenths and 1 mph difference. 2.4 60' times aren't the greatest either. Work on your launch and get down to the low-2.3 range and that'll be good for another two tenths. If it wasn't too hot then that's not too bad, but humidity can have an effect also. And as per the other guys, manually shifting to get every last RPM out of the motor will give you another 1-2 tenths also. So that's the difference between you and Larry (03LXV6guy) who ran 14.5 with an auto intake only.
Old August 22nd, 2004, 10:00 PM   #11
Ursus's Avatar
Wow.. those are some good advices. I will try shifting manually next time. damn a sedan running 14.5s... thats tight.
Old August 25th, 2004, 03:49 PM   #12
ALWAYS go on last yellow.
solomon is offline   Reply With Quote Quick reply to this message
Old August 27th, 2004, 02:33 PM   #13
What does that have to do with the price of tea in china. Don't worry about the reaction time, just go for a good ET!
Turbo20VJetta is offline   Reply With Quote Quick reply to this message
Old August 27th, 2004, 04:18 PM   #14
Roadmaster's Avatar
You should always go for a good reaction time. Remember you are also racing the person next to you. It is possible to have a slightly slower car and still beat the guy down the track by merely jumping out of the hole much quicker.
Dustin
Old August 30th, 2004, 12:53 AM   #15
Back to boost...
nc00max's Avatar
Send a message via AIM to nc00max
I would most definitely like to see vids of an N/A 6spd with an intake hitting a 14.0, and I'm sure others would as well since that'd be a record on at least this board. Please post them, and if you need to host it, email it to me.
'00 Maxima-A thing here and there
'00 Grand Prix GTP-my new canvas. [email protected] with FWI in 80* weather, now to start modding...
nc00max is offline   Reply With Quote Quick reply to this message
Old August 30th, 2004, 06:41 AM   #16
Dustin
This guy was trying to get a good ET. It didn't sound like he was trying to beat the guy next to him. If you are going for a good ET, then it is best to not worry about reaction time as you are more likely to get a good launch.
