Grounding Kits - Honda Accord Forum : V6 Performance Accord Forums
Old October 24th, 2004, 04:55 PM   #1
_
0430Steve's Avatar
Grounding Kits
Got a lot of questions here, but I couldn't find any answers on the site or on the net.
What is included in the V6performance grouding kit? Anything besides the grounding wires? If not, does it come with the box like the Apex-i grounding system has, and what is that, what exactly does it do? Just power distribution, is it because its universal and not designed for specific models? Is that why the V6performance one doesn't need the box, our wires are of specific length? Also, what is a hyper voltage system, do they have it for our car, and how does it work in conjunction with the grounding system, can you get them together? Or do you even need them both?
Thanks for any help.
Old October 24th, 2004, 06:45 PM   #2
You might want to wait or PM 'slick6spd'. He's one of the few I know that has the Apexi unit.
2004 Honda Accord EX V6 6spd [email protected], [email protected](stock)
October 2004 - June 2005
cammyfive is offline   Reply With Quote Quick reply to this message
Old October 24th, 2004, 08:25 PM   #3
I AM LOST....
brex's Avatar
I believe it includes 4 gauge grounding wire in the color of your choice, and macine finished battery terminal.. the wires are cut to specific length for each car application.. installation also provides the best grounding point..
there was some other discussion on apexi.. and what exactly that little black box do.. apparently just some resistors..
Old October 29th, 2004, 03:51 PM   #4
Die-Hard Enthusiast!!
Sick6speed's Avatar
Send a message via AIM to Sick6speed Send a message via Yahoo to Sick6speed
I like resistors. Some resistors are better than none at all! I feel that the apexi kit has worked electrical wonders with my car! It is way more responsive and is smoother at idle and all rpm's! But all in all who really knows if it works. I would have loved to get a before and after dyno because that is the only way you could really tell!
Sick6speed is offline   Reply With Quote Quick reply to this message
Old October 29th, 2004, 04:25 PM   #5
Someone should send sick6speed a V6P grounding kit, so he can do a comparison between that and the apexi. I guess there's no questions that the apexi makes a difference over stock, but I'm curious what difference would be between two grounding kits.
Old October 29th, 2004, 04:33 PM   #6
Sick6speed's Avatar
Thank's Bro! I will be waiting patiently for that special someone to send me the V6P kit!
Old November 19th, 2004, 02:34 AM   #7
St. Louis!
Kingof3rdinput's Avatar
Would a cheapy ground kit ala ebay have the same affect?
Old November 19th, 2004, 01:04 PM   #8
Who are you!?
gme2001's Avatar
Send a message via AIM to gme2001
Order a kit and I will drop ship it to sick6speed.
gme2001 is offline   Reply With Quote Quick reply to this message
Old November 19th, 2004, 01:43 PM   #9
actually, I've been thinking of getting one for christmas. Sick6speed, wanna do some dynos?
Old November 21st, 2004, 03:07 PM   #10
Sorry for the retard question, but what makes this kit help the car to be better in performance terms?
Juank! is offline   Reply With Quote Quick reply to this message
Old November 21st, 2004, 03:49 PM   #11
Anyone know if this would effect hondacare warranty ? ? ?
Old November 21st, 2004, 05:15 PM   #12
Who are you!?
gme2001's Avatar
There are slight gains due to the fact that the car is able to run the way it should because the ECU and sensors are grounded allowing for a cleaner signal causing the car to run better.
Old November 21st, 2004, 05:16 PM   #13
Who are you!?
gme2001's Avatar
It doesnt at least the Honda dealership I went to didnt care.
Old December 19th, 2004, 05:12 PM   #14
original member!
Nittanys1's Avatar
i think i'm gonna get a voltage system but dont know what one to get. there are three different versions that "sun automoble" offers for different engine ranges....
Old December 20th, 2004, 01:10 PM   #15
wj4
wj4's Avatar
can someone explain what does the kit do? im kinda in the dark here
Old December 20th, 2004, 01:13 PM   #16
Who are you!?
gme2001's Avatar
Do a search on ground wire kits, there should be several threads on this.
Old December 20th, 2004, 09:56 PM   #17
the little box on the apexi unit actually contains capaitors which help store power and acts as a buffer. It also contains a noise filter, the resistors i beleive are for the l.e.d.
MGibbs007 is offline   Reply With Quote Quick reply to this message
Old December 22nd, 2004, 01:24 AM   #18
u can make yer own groundin kit for like 10 bucks lol
kwanzor is offline   Reply With Quote Quick reply to this message
Old December 22nd, 2004, 03:40 PM   #19
original member!
Nittanys1's Avatar
uuummm...................duuhh!
Old December 22nd, 2004, 03:55 PM   #20
well the capacitors and noise filters might put you at like 15
lol
Old December 22nd, 2004, 03:59 PM   #21
original member!
Nittanys1's Avatar
15 Volts?
Old December 22nd, 2004, 04:15 PM   #22
15 bucks
15 volts, I think you'd need more than capacitors.......lol
(disclaimer: I actually have no idea how much the equipment would be, but I'm guessing pretty cheap)
