Dyno Run Results Accord -04 - Honda Accord Forum : V6 Performance Accord Forums
Old November 24th, 2004, 03:35 PM   #1
Just got back from dyno my wifes car ,disappoint 190.1 HP & 169.5 Torque. Best run at track was 15.21 @ 93.85 60FT. 2.35 Compared to My acura CLS -01 Was Hp 194.27 & Torque 191.7 Big diffrence in torque, Best time 9/05/00 was [email protected] 60FT. 2.27 Note mph Greater on accord .
Lastest HP 241.1 & Torque 199.3 Best Run 14.10 @100.70MPH on accura CLS 3.2 It going to take a lot of money to get int 14.0s.
John52 is offline   Reply With Quote Quick reply to this message
Old November 24th, 2004, 04:01 PM   #2
"Certified Hybrid Killer"
SteVTEC's Avatar
I think you're probably mis-reading the torque on your CL-S dyno. The peak numbers were probably reading off of the hump from the torque converter at the low-end if you ran it in SS mode from low revs. If so, that's just the torque converter and not the engine.
Old November 24th, 2004, 06:46 PM   #3
The more and more dynos I see for auto and 6spd V6 Accords, the more convinced that the engines do put out different power numbers...not the generic 240hp. I think the autos may be 240hp (crank), but I think that the 6spds are more along the lines of 260 crank (with premium gas). The premium gas and variable intake seem to boost the numbers of 6spds quite a bit.
I think member 'stoner' did a dyno of his bone stock 6spd and with a 15% drivetrain loss he came out with roughly 259 crank hp.
2004 Honda Accord EX V6 6spd [email protected], [email protected](stock)
October 2004 - June 2005
cammyfive is offline   Reply With Quote Quick reply to this message
Old November 24th, 2004, 06:54 PM   #4
SteVTEC's Avatar
15% loss is what you'd expect on a RWD live-axle setup, like a Mustang GT or a Camaro. FWD and RWD independent suspensioned setups have more complex final drives and a little bit more parasitic loss. around 17% for a manual in most cases. Add about 5% to that for most automatics, although some are a lot worse (like the mazda 6s automatic, and some chryslers).
Another common error people make is that they take the highest and most optimistic dyno ever and then claim that to be the gold standard. in reality you should take the lowest and the highest and throw them out, and then average the rest to get the clear picture. And then there are different types of dynos... It goes on and on.
I think 250-255 is what the 6spd is putting out.
Old November 24th, 2004, 06:59 PM   #5
Well, maybe so. As I mentioned, 'stoner' did a dyno and used a more conservative 15% loss for his 6spd to come up with 259 crank. So 17% would make it somewhere between 260-265 crank...impressive.
Old November 24th, 2004, 07:13 PM   #6
SteVTEC's Avatar
Impressive yes. If it's legit and repeatable.
Old November 24th, 2004, 11:19 PM   #7
Stoner Boner
Well I'm not stock anymore. I'm going to be dynoing again soon with I/E (aem v2 cai and greddy evo 2).
Tonight's track runs were VERY disappointing with these new tires. I'll post it up in the 1/4 thread.
2004 Honda Accord EX V6 6 Speed
Mods: My mods were taken away by the mods.
Best To Date: [email protected] (CAI, Exhaust) 2.23 60'
Previous: [email protected] (CAI, Exhaust) 2.13 60'
stoner is offline   Reply With Quote Quick reply to this message
Old November 25th, 2004, 12:32 AM   #8
Oh, so the tires are new??? What kind are they? I'm now very suspicous of the Greedy.
Old November 25th, 2004, 01:31 PM   #9
Stoner Boner
BFGoodrich g-force t/a sport
225x45-17
Old November 26th, 2004, 02:21 AM   #10
vroom vroom
ctsport's Avatar
Those numbers look right to me
Old December 3rd, 2004, 10:18 AM   #11
Die-Hard Enthusiast!!
Sick6speed's Avatar
Send a message via AIM to Sick6speed Send a message via Yahoo to Sick6speed
818 Weekly Meet&mpt=[CACHEBUSTER]">
Sick6speed is offline   Reply With Quote Quick reply to this message
Old December 9th, 2004, 05:32 PM   #12
Hey guys, i had my car dynod awhile back, and I got 225Whp/200Wtq, the only mod i had installed at the time was the AEMv2.
adding 17% to that would = 263.25 hp @ the crank, and 234 TQatC.
So, with UR dropping soon and a comptech SC, im hoping for almost 400hp!!
then i'll be hunting for some sti's, evo's, and M3's!!
21InAz_04TSX is offline   Reply With Quote Quick reply to this message
Old December 9th, 2004, 11:46 PM   #13
Please post a dyno chart, I'd like to see where specifically the gains are at. Another member has a AEM CAI and Greedy Evo...he got 223 and 198, so yours is quite a bit higher for some reason.
Old December 10th, 2004, 09:36 AM   #14
Well the AEM V2 adds more power than the normal CAI and the Evo exhaust isn't going to do much if not lose a little power so that's about right...
Old December 10th, 2004, 11:32 AM   #15
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
From what SteVTEC said a while back, the variable intake does not increase the peak power of the motor..... it just fattens up the curve a little bit at lower rpms. At higher rpms (where peak power occurs), the intake manifolds are basically the same..... only at lower revs is the variable part of it affecting things. At least that's how I understand it works.
Old December 10th, 2004, 12:41 PM   #16
I will, i ahve a buddy that works at Kinkos so i will find the dyno and have him scan it for me.
i'll try to do it tomorow.
Old December 10th, 2004, 01:38 PM   #17
I had A stock dyno done awhile back and I put down 212.1whp and 194.6wtq on 91oct. So 250-255 Flywheel hp would be an apropriate claim.
S.A.M6 is offline   Reply With Quote Quick reply to this message
Old December 11th, 2004, 02:13 AM   #18
My thoughts exactly. I mean aftermarket exhausts sound nice and all but I'm unconvicned as to the fact of their performance gains.
Old December 11th, 2004, 02:13 AM   #19
Great, cant wait to see it!
