Break cooler question... - Honda Accord Forum : V6 Performance Accord Forums
Old December 4th, 2004, 09:28 AM   #1
is it possible to run something like a tube/ pipe from near the grill through the wheel well at an angle that it would allow the brakes to stay cooler and thus not overheat/ fail?
thank you
alex
southordMPXE is offline   Reply With Quote Quick reply to this message
Old December 4th, 2004, 09:31 AM   #2
Formerly VTEC-v6!
N54TT's Avatar
Have you had this problem already?
Old December 4th, 2004, 02:20 PM   #3
well kinda i have never had complete failure but coming to a stop from high speeds can be a verry scarry experience in this car and i was hopping to reduce this problem with some bigger rotors and some sort of a custom system that would keep air on the rotors thus cooling them down (hopefully)
Old December 4th, 2004, 04:24 PM   #4
Formerly VTEC-v6!
N54TT's Avatar
Well honestly its not worth it.
1. Because the 6MT av6's already have brake cooling ducts
2. If your trying to slow down that fast where your having problems, you a. need to slow down, or b. get a real brake upgrade, like RB rotors + pads.
Old December 5th, 2004, 11:44 AM   #5
those are soon to come
ps thanks for the info
Old December 6th, 2004, 12:45 PM   #6
someone correct me if I'm wrong, but wouldn't heat be more of an issue with repeated breaking, compared to a single high-speed stop? I would think that the deal there would be rotor and piston strength. I think heat affects fade, which would make breaking a little less effective after like the 10th stop or something like that.
