V6P Grounding Kit trouble.. - Honda Accord Forum : V6 Performance Accord Forums
Old February 11th, 2005, 08:33 AM   #1
^ that's my name
Send a message via AIM to ll haC
I've searched everything that has had to deal with the grounding kit on 7th gen. All I could find was that some people had some length problems, but in the end found a solution. Well I'm currently stuck. The 3/4 wire (the longest one that reaches from 1 side of the manifold to the other ) will not reach to the grounding point that's specified in the instructions. If anyone could help me by showing me how they routed that wire, It'd be really appreciated. Thanks
ll haC is offline   Reply With Quote Quick reply to this message
Old February 11th, 2005, 10:55 AM   #2
Who are you!?
gme2001's Avatar
Send a message via AIM to gme2001
You shoud route the wire like this. The big yellow circles are where it ends bolt and the yellow "line" is the way the wire should be routed.
gme2001 is offline   Reply With Quote Quick reply to this message
Old February 12th, 2005, 04:40 PM   #3
Be patient with the connection under the battery.............remember the bolt goes in at a wierd angle.....I didnt tighten anything until all was connections where made then I went back to tighten all the bolts. When you go back to tighten bolts start at the one under the battery since that bolt is the hardest.
Rick
Old February 12th, 2005, 06:12 PM   #4
V6P Negotiator & Promoter
MrV6P's Avatar
Rick
The transmission connection under the battery is b#tch to work with on most of the cars Garrett R&D, compared to other connections. . . so take a break if you start getting a little frustrated or impatient.
Maurice
MrV6P is offline   Reply With Quote Quick reply to this message
Old February 12th, 2005, 08:58 PM   #5
Who are you!?
gme2001's Avatar
My fault I guess I cut the wire to short when I was putting this kit together. Again sorry about that.
-Garrett
Old April 13th, 2007, 09:36 AM   #6
girl powah!!
03aV6cpe's Avatar
-Garrett
ok, so i'm strongly debating on buying this grounding kit, but was wondering if the stated issue above has been resolved for the new batch??
thanks
Joyce
Official Slammed Club Member (Stage 3)
Featured Ride Of The Month (June-July 2010)
Old April 14th, 2007, 04:41 PM   #7
Who are you!?
gme2001's Avatar
thanks
We made a few hundered of these kits I believe only 1 person had a problem with one of the length that I know of, spent a few minutes talking to the guy about it and he tried again kit installed just fine.
-Garrett
