87 vs 91 or higher for v6 final proof! - Honda Accord Forum : V6 Performance Accord Forums
Old May 29th, 2005, 05:55 AM   #1
OK, I'm new but I searched here and all over the web and might call honda after the holiday weekend. question is about all i have read about the 10 hp/10ft lbs increase in the accord v6 when using 91 or higher over the recomended 87 that a Honda engineer was suppossed to have stated. i have also read that if you use 91 or higher in a car that recomends 87, if it dosen't need it it will produce more carbon buildup. So my main question is, Does any one have proof of this statement from the honda engineer? and is it true about the performance gains, I don't want to spend the extra, get no performance benefits and more carbon buildup. so let's all put our heads together, do some research and settle this rumor for good, thanks. 87 or 93 that is thy question
wicked400ex is offline   Reply With Quote Quick reply to this message
Old May 29th, 2005, 07:48 AM   #2
Originally Posted by 2fast4u99
ok let us no when you do 2 dyno runs one on 87 octain and the other on 93. Also make sure you reset your ecu before the dyno to get the best map. Also make sure you have no 87 octain in your tank when using 93.
LOL
LOL? what's so funny? I'm not dynoing it, I just want to know if a honda engineer stated this or not and proof. I'm running 87 since that's what is says in the manual, but if a honda engineer did in fact state that the car will get 10hp/10ft lbs than i will run 93. and maybe everyone should to get the most from the car. i don't really believe this, but if a honda engineer did indeed state this than I'll have to belive it and give it a try. Don't waste time and make this thread 9 miles long with jokes and stuff not pertaing to the main question.
Old May 29th, 2005, 07:59 AM   #3
I don't think he is making a joke.. The only way to get proof is to dyno it....Seems logical to me, I wouldn't believe any of the engineers, they do everything on a computer, not real world...
just my .02
ocwill1 is offline   Reply With Quote Quick reply to this message
Old May 29th, 2005, 09:11 AM   #4
just my .02
I believe that since honda made the car, if a honda engineer stated it than it's true but i want proof that he/honda stated this. some guy was supposed to dyno in another thread but i don't think he ever did.
Old May 29th, 2005, 10:39 AM   #5
i do kinda feel some HP increase when using 93 octain. I would say its like 2-4 HP increase instead of 10HP and there is no way in hell that we see a 10lb torque increase, more like 2lb torque lol
that's cool, but did a engineer for honda or honda itself actually state it? I need proof not heresay before i switch to 93. thanks
Old May 29th, 2005, 11:21 AM   #6
GT35R Turbo'd 3.5L AV6
logonzojls's Avatar
i asked the tech at local honda dealership and he said that the accord does not benifit from using 93. He did say that some other honda models do but not the 7gen AV6. I also heard a lot of he-say-she-say on this forum and nobody ever got any real proof.
logonzojls is offline   Reply With Quote Quick reply to this message
Old May 29th, 2005, 02:40 PM   #7
From J30A to 4g63
0Tolerance's Avatar
Send a message via AIM to 0Tolerance Send a message via MSN to 0Tolerance Send a message via Yahoo to 0Tolerance Send a message via Skype™ to 0Tolerance
Now see i heard the total opposite, a tech told me the higher octane responds to the 7th gen only and not the other models. So i used 91 octane all the time, but as far as in gains, not there.....and you aint seeing 10hp or 10tq with the kind of gas, maybe putting in a CAI ill believe those gains. Theres been threads about this before, so to close this subject, and find out what 91-93 gas really does, Dyno it!
0Tolerance is offline   Reply With Quote Quick reply to this message
Old May 29th, 2005, 03:28 PM   #8
just use 87...gas prices these days are ridiculous
adamkim83 is offline   Reply With Quote Quick reply to this message
Old May 29th, 2005, 04:07 PM   #9
ya i know, gas prices suck! how much you guy's payin over on the west coast, ours just went down to $1.99 for the (not so) cheap stuff
Old May 29th, 2005, 04:28 PM   #10
Why try?
u guys are so lucky the cheapest around here is $2.29
BlackAccord03 is offline   Reply With Quote Quick reply to this message
Old May 29th, 2005, 04:37 PM   #11
Import driving azzhole
murphman331's Avatar
Send a message via AIM to murphman331
Here is proof that the comment was made by a Honda engineer. V-6 engineer Asaki was the person that made the 10hp/10tq comment.
Look under the Powertrain section about half way down the page. There's also a statement under Engines in the green box titled Accord vs Camry.
http://www.usatoday.com/money/autos/...1-accord_x.htm
Still, the only way to prove this is to do a before and after dyno using 87 and 91+ octane.
murphman331 is offline   Reply With Quote Quick reply to this message
Old May 29th, 2005, 05:44 PM   #12
Formerly VTEC-v6!
N54TT's Avatar
Get an ODBII scanner and monitor ignition advance under load, and make some freeway runs
Old May 29th, 2005, 06:14 PM   #13
yeah its around $2.30 cents a gallon....its actually going down little by little but i have a feeling its gonna jump again
Old May 29th, 2005, 06:39 PM   #14
indoctidiscant
OwAce's Avatar
you dont need to have a feeling. all you have to do is monitor oil prices. the shock is felt 2 weeks later at the gas pump. as of friday oil was over 51 a barrel.
Old May 29th, 2005, 07:22 PM   #15
From what I remember the engine has a knock sensor on it allowing it to be tuned for 91 octane gas but putting lower octane gas will change the timing allowing it to be safe. Maybe honda marketed it as a regular fuel 240hp engine to get the more mainstream buyers, especially with the gasoline prices going up.
I used premium for a while then switched to regular because of the gas prices and my car felt like it was slow/lagging. When I put a tank of premium in the other day it felt more responsive. I think I'll spend the extra $1.40 to $2.00 for a full tank of premium.
Old May 29th, 2005, 08:16 PM   #16
My Third Accord!
acb384's Avatar
Send a message via AIM to acb384 Send a message via MSN to acb384
i have not noticed a tangable performance difference between regular and premium. i have noticed better mileage with higher octanes though...enough to make it worth the extra octane on road trips...makes it easy to get 400-450+ miles on a tank. when prices go down below $2 for reg. I will sometimes put in premium for a couple tanks...paid 2.01 for premium today (reg 1.87). i dont notice a mileage difference in regular day to day driving because i tend to drive harder... on the highway though its definetly worth it.
acb384 is offline   Reply With Quote Quick reply to this message
Old May 29th, 2005, 09:06 PM   #17
thanks guy's you really came through, murphman331 you got what I wanted, an actual copy of the usa today paper where it stated a honda engineer said we'd gain 10hp & 10+tq with premium. we'll i'm sold on premium maybe we should all use it, since we blow all kind of money on the car and every other mod anyway! see ya guys around, thanks again for being polite and helpfull!, later, John
Old May 30th, 2005, 08:56 AM   #18
As stated before many times, it takes 1+ tanks for the computer to adjust to the premium fuel...
dozorca is offline   Reply With Quote Quick reply to this message
Old May 31st, 2005, 11:00 PM   #19
Zipy
If using premium bumps up the timing we should see a corresponding rise in our MPG. Can any one testify to getting better mileage on a regular basis using premium? I know acb384 said he got better MPG. How much more would you say you have gotten?
Zipy is offline   Reply With Quote Quick reply to this message
Old May 31st, 2005, 11:28 PM   #20
I have the OBD II scanner, but no 7th gen AV6 test subject .
You can feel a 2-4 HP increase? That's one sensitive butt dyno my friend .
Old May 31st, 2005, 11:52 PM   #21
St. Louis!
Kingof3rdinput's Avatar
i only noticed a .5-1.3 hp increase from what i could feel.
Old May 31st, 2005, 11:56 PM   #22
Formerly VTEC-v6!
N54TT's Avatar
Old June 1st, 2005, 12:00 AM   #23
Old June 1st, 2005, 12:09 AM   #24
I have an OBD II scanner and 7th gen, but I don't care about this enough to test it
I would still use regular.
willshire is offline   Reply With Quote Quick reply to this message
Old June 1st, 2005, 12:16 AM   #25
Just to note, you have the power to finally put this topic to sleep!
Old June 1st, 2005, 07:54 AM   #26
Yes... if not for us, do it for the innocent n00bs with their countless threads!!!
Old June 1st, 2005, 07:56 AM   #27
This topic is finished, murphman331 put a link to where all this talk started about the gains, which is all I wanted (PROOF) the link to a usa today article where the honda ENGINEER of the v6 (the guy that would know the most about it, because i think honda would test the crap out of an engine a million different ways before releasing it) said it was marketed for 87 but get the 10hp & 10+ft lbs tq when using premium (91-93) so psss on the dyno and what we feel, the man that made the motor said this, iknow i know, sometimes people say stuff to sell something, but come on its a honda, i don't think they have to BS people to sell cars. check out my time slip, that was 87 3/4 tank, i'm almost empty gonna refill 93 wait till empty & go back to the track. my 60 footer's suck!, hard clutch to get used to, did it take any one else awhile to get used to it? where do you guy's shift 6800? that's where i was, i'm gonna try 6300 when i go back since power flatens out ther then drops off anyway. (gotta get to mid 14's before i buy any aftermarket stuff)
Old June 1st, 2005, 09:31 AM   #28
EX V6 Slusher's Avatar
Also if you take a look at the latest Car and Driver (Last Month) in the letters section up front the second question is"I have a 2003 Honda Accord V6 and have heard it gains 10hp and 10tq with premium gas is this true?' The answer from Car and Driver is YES. So there you go the Engineer that designed the engine and Car and Driver. If you don't beleive it don't buy premium but don't expect someone else to pay for the dyno to justify it for you.
EX V6 Slusher is offline   Reply With Quote Quick reply to this message
Old June 1st, 2005, 12:27 PM   #29
Well I just hit the E line so I filled up with15 gal exxon 93, when it hits E again i'm goin to the track, last time 3/4 tank like an idiot, this time EMPTY! (w/93) watch me run out half way down the track! I wonder if my roadside assistance would come hook a brother up! I'm new and I keep hearing about an intake what is it? Sike! hda a 95 probe gt greddy cat back, hot shot CAI test pipe, magnecore wires, rear strut bar, (4 12's, red undercar neon amp cap & cd) later, John
Old June 1st, 2005, 02:36 PM   #30
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
What were your 60 foots?
You're going to need to get 2.2x's ..... low 2.3x's at worst..... in order to run in the 14's, imo.
I've got a slushy, but still, it's the same engine up at the top of the rev range. (Fyi, the variable intake only makes a difference below about 3000 or 4000 rpm, and even then it's only good for about a tenth or so in the 1/4 mile.) And I disagree with your "power flattens out" statement..... the engine continues to make power all the way up to redline, so your best times are going to come by running up to or as close as possible to redline. That also puts the car in a much better position in the power band in the next gear, versus shifting at 6300 rpm, where it'd be out of vtec range when it gets in the next gear.
Many people have hit mid 14's with their stock 6-speeds..... with a couple of people hitting 14.2 to 14.3's...... stock!
Nobody knows absolutely for sure, but people say it takes either a tankful of gas or 300 miles of driving for the ecu to fully adjust for the higher octane.
