help with CAI - Honda Accord Forum : V6 Performance Accord Forums
Old June 5th, 2005, 06:08 PM   #1
i<3 my P.O.S.
04accordcoupe's Avatar
Send a message via AIM to 04accordcoupe
help with CAI
hi can someone take a picture of how they installed there V2 i got mine used so there was no instruction thx very much All i need to now is where the screw go in and where the thin hose go into thats all....sorry i am not a mechanic
04accordcoupe is offline   Reply With Quote Quick reply to this message
Old June 5th, 2005, 08:30 PM   #2
what screw are u talkin about? the big screw head thing goes into the old opening for the maf sensor. I think the thin hose is for the coolant line.
blkcoupe is offline   Reply With Quote Quick reply to this message
Old June 6th, 2005, 03:45 PM   #3
i<3 my P.O.S.
is this correct the way i installed it help me out plssssss
all i had left was a thin tubing i don't know where that goes into
Old June 6th, 2005, 06:15 PM   #4
St. Louis!
Kingof3rdinput's Avatar
Hope it wasnt your coolant line Take a pic of the pvc behind the tubing. Let me see what you did there.
Old June 6th, 2005, 06:55 PM   #5
i<3 my P.O.S.
Coolant line is still there stuck to teh metal tubing haven't touched that....i guees the extra tubing is so we can take out the metal tubing i think but not sure
Old June 6th, 2005, 09:02 PM   #6
From J30A to 4g63
0Tolerance's Avatar
Send a message via AIM to 0Tolerance Send a message via MSN to 0Tolerance Send a message via Yahoo to 0Tolerance Send a message via Skype™ to 0Tolerance
Also make sure you flex wrap the rest of the line to the IAT sensor.
0Tolerance is offline   Reply With Quote Quick reply to this message
Old June 6th, 2005, 09:22 PM   #7
i<3 my P.O.S.
so i guess teh extra hose is for the coolant line right?
Old June 6th, 2005, 09:55 PM   #8
St. Louis!
If you dont have any line attached, then yes. If its dangling loose, it is something else. As long as your coolant line and the line that goes directly to the intake are in tact, then you are good as gold.
Old June 10th, 2005, 12:19 PM   #9
hope this helps
[IMG][/IMG]
Old June 10th, 2005, 04:44 PM   #10
u need to remove all that metal tubing behind the intake, and replace it w/those blk rubber tubes that it came with.
