Limited Slip Diff- - Honda Accord Forum : V6 Performance Accord Forums
Old July 29th, 2005, 11:07 PM   #1
Limited Slip Diff-
I was wondering if anyone new of an aftermarket LSD available 6MT 2004. Would the CL-S LSD bolt on, does the TL have an LSD, if so anyone tried the install? I would appreciate all help here.
futureracer is offline   Reply With Quote Quick reply to this message
Old July 30th, 2005, 06:44 AM   #2
St. Louis!
Kingof3rdinput's Avatar
I've read here that the CLS will fit with lots of work. Its been discussed I know, just search it.
Old July 30th, 2005, 09:44 AM   #3
CL-S part will bolt on. Someone here has done it. Part = $800 Labor = $1000 IIRC
Honcho is offline   Reply With Quote Quick reply to this message
Old July 30th, 2005, 01:13 PM   #4
What would putting on the limited slip do?
distinctjay is offline   Reply With Quote Quick reply to this message
Old July 30th, 2005, 01:14 PM   #5
Your Mom Drives a Honda
smokin6speed's Avatar
the person that did it was also the person that went from auto to manual as well i believe.....but i recall hearing that it was a pain......IMO i don't really think with the limited possibilities our cars have that it would truley be worth it....
Old July 30th, 2005, 01:31 PM   #6
It's only going to make a noticeable difference if you road race the car like in SCCA.
Old July 30th, 2005, 07:09 PM   #7
jiggerman78 is offline   Reply With Quote Quick reply to this message
Old August 5th, 2005, 07:16 AM   #8
Thanks for the info. I understand that the limited slip will only truly shine if I took the accord out on the track. I will go ahead and search for the previously mentioned Cl-s conversion. I knew that the swap would be pretty time and cost consuming, but I just wanted to check to see if anyone had tried it before. Thanks again.
Old August 5th, 2005, 10:31 AM   #9
darkside / gen7accord.com
Blizzard's Avatar
Send a message via AIM to Blizzard
i'm planning on doing this in about a year =) let me know if you hear anything about it. Where is this thread about cl-s differentials? I can't find it ugh =X
Art
D a r k s i d e
Blizzard is offline   Reply With Quote Quick reply to this message
Old August 13th, 2005, 02:24 AM   #10
pch
1quick240
pch's Avatar
Send a message via MSN to pch Send a message via Yahoo to pch
to do this is just buying the differentila and installing it right?
pch is offline   Reply With Quote Quick reply to this message
Old August 13th, 2005, 10:22 PM   #11
Yeah but it requires removing the transmission, which is an all-day job. I've done it on a 4cyl Honda, but not the V6. A long, tough job without a lift. Or you can pay $1000 and have someone do it for you.
Old August 15th, 2005, 09:50 AM   #12
Jinx32's Avatar
I'd wait until you had to crack the tranny for a reason before doing it. Like if you had a bearing go bad. Then you gotta open it anyway, so that's the time to put the lsd in.
So lets say I have a bad bearing and the tranny needs to be torn apart, at this point, is the lsd just a drop in?
J
Jinx32 is offline   Reply With Quote Quick reply to this message
Old August 15th, 2005, 03:37 PM   #13
I believe so. IIRC the schematics posted in the older threads show an identical bolt pattern between parts. It looks like it will just drop in. An interesting question is how this would affect the TCS. For the CL-S, Acura developed the LSD as a better solution to the torque-steer, traction problems exhibited by high-power FWD systems.
With the lower-tech TCS, brake force is applied to the slipping wheel, forcing the diff to send power to the other wheel. With the LSD, power is mechanically distributed to the wheel with best traction, but without the de-stablizing use of brakes. Also, where TCS is either on or off, the LSD has a range of power to distribute- much smoother. This is why many of the car mags described the CL-S as one of the best handling FWD cars in the world.
But let's say you swap the LSD into your Accord. Now, you've got both TCS and the LSD trying to do the same thing at the same time. It sounds like a potential problem. Although I guess you could just drive with your TCS always off?
---Edit----
Good summary from an Evo site:
"Helical-type limited-slip differentials offer several advantages over the clutch-type or viscous LSDs. Viscous limited-slip units tend to wear out after extended use, as their oil is heated and reheated until it degrades, rendering the unit ineffective. Clutch-type differentials provide good off-the-line traction, but the 50/50 stability that's beneficial in a straight line is not so desirable when a vehicle is turning. The helical-type limited slip provides better durability and performance when it's needed most: while turning. Unlike an open differential, which shifts power to the wheel with less grip, the helical LSD constantly shifts the bias toward the wheel that has more traction.
Under straight-line acceleration, power remains evenly split between the front wheels. While cornering (e.g. accelerating out of a turn), the helical LSD directs power away from the inside wheel and toward the outside wheel, allowing the driver to begin accelerating earlier and exit the turn at a higher speed, without losing traction in the process.
Performance is also improved on slippery mud or snow that's often encountered on isolated dirt roads, where the Lancer Evolution series spent much of its development."
Old August 20th, 2005, 11:50 PM   #14
pch
1quick240
pch's Avatar
well, my tranny is already going to come out because of my swap. So i thought this might be a perfect time. http://www.v6performance.net/forums/...ad.php?t=58676
Old August 18th, 2006, 09:17 PM   #15
I know this thread is over a year old since the last post, but any updates on an LSD for the 7th gens? Thanks everybody!
dkubek is offline   Reply With Quote Quick reply to this message
Old August 18th, 2006, 10:54 PM   #16
I no Nintendo
gizmo2003's Avatar
you can ask 6-Speed Demon but I have not seen him in a long time. He was the guy getting a sc done. he made a thread but I think people got stupid and they closed it. after that I have not seen him, but what he told me was just to go with a TL LSD unlike the CL-S its more or less a plug and play... he had it done by a dealer it was about 1k i think or maybeee 2 lol
Old August 18th, 2006, 10:58 PM   #17
Appreciate it gizmo. I just can't keep the tire from breaking loose. All this power and no way to put/keep it to the ground! Thanks
Old August 23rd, 2006, 12:40 PM   #18
carlrx7's Avatar
what about for the autos? any of the acura autos have lsd?
carlrx7 is offline   Reply With Quote Quick reply to this message
Old August 23rd, 2006, 02:02 PM   #19
I no Nintendo
gizmo2003's Avatar
think so ill ask
Old August 24th, 2006, 07:00 AM   #20
GT35R Turbo'd 3.5L AV6
logonzojls's Avatar
You will thank me if you would spend only 200-250 (2 tires) for some really sticky tires damn near all your traction problems would be solved and you don't even need to open up your tranny! Michelin Pilot Sport PS2, I am serious this will solve your off the line acceleration problems. Best mod I ever did on my car... before the turbo..
L
logonzojls is offline   Reply With Quote Quick reply to this message
