Need Help NOW!!! - Honda Accord Forum : V6 Performance Accord Forums
Old August 2nd, 2005, 11:04 AM   #1
Angry Need Help NOW!!!
Last night, i was driving my car. I recently purchased new brakes and got my rotors machined all around. So i was decided to test my new brakes. So on a empty back road, I sped up to 70. And just slammed on the brakes. It took me sooo long to stop. The brakes went to the FLOOR. The ABS didn't kick in, nor did the tires lock. The brakes just went to the floor and i kept rolling. is there a problem with my ABS? Why didn't the tires lock up? What would happen if i had to slam on brakes to stop from hitting someone?
mahdigga is offline   Reply With Quote Quick reply to this message
Old August 2nd, 2005, 11:19 AM   #2
thats when you hit the E brake and drift around the car.
RentsDidntBuyIt is offline   Reply With Quote Quick reply to this message
Old August 2nd, 2005, 11:21 AM   #3
Andrea's Avatar
first, new brakes have to be "broken in" first. no hard braking (unless necessary)
you need to bleed the brakes some more(frequent tap on the brake pedals). air bubbles might be present on the lines.
Andrea is offline   Reply With Quote Quick reply to this message
Old August 2nd, 2005, 11:22 AM   #4
But why didn't they lock up?? the ABS didn't kick in
Old August 2nd, 2005, 11:28 AM   #5
Andrea's Avatar
if you tested your brakes right after the you replaced them, then there is a possibility that air bubbles in the brake lines are not yet removed (bleed). tapping the brake pedal should take care of that unless the mechanic did a horrible job installing.
there is no pressure on the brake lines if bubbles are present because the brake fluid should "push" the brake discs. your brake pedal went all the way to the floor because of the air japs in the brake lines.
Old August 2nd, 2005, 11:29 AM   #6
Nothing special
blu6speed's Avatar
Well for starters, you have to give brakes break in time!!! or else your going to be getting them turned down again.
1. Check the brake fluid level. They may have bled the brakes and not replaced the correct amount of lost fluid.
2. With thinner rotors, your pedal is going to go further down, you have to push the pistons on the brakes out further for them to come in contact with the rotors.
3. Sit at a stop with the car running, press the brake. If the pedal stops, then slowly sinks, you have air in the lines and they need bled.
If its as bad as you say, take it back to where you had the work done and get them to fix whatever the problem may be.
Old August 2nd, 2005, 11:31 AM   #7
Raddy21's Avatar
how long do brakes take to break in? just curious b.c i recently installed new pads and they dont feel as good as they should yet imo.
thanks
Old August 2nd, 2005, 11:31 AM   #8
I'm stupid with cars
Showtime's Avatar
Send a message via ICQ to Showtime Send a message via AIM to Showtime
Showtime is offline   Reply With Quote Quick reply to this message
Old August 2nd, 2005, 12:21 PM   #9
I had my brakes for about a week. Isn't that enough break in time?
Old August 2nd, 2005, 01:19 PM   #10
constantly in pursuit
hammer03's Avatar
i think i heard a hundred miles or so? last time i had mine done. i think thats what they told me.
