Brake Booster Hissing - Honda Accord Forum : V6 Performance Accord Forums
Old October 26th, 2012, 02:19 PM   #1
7th Gen 03 Accord Coupe
cheezalo's Avatar
I replaced my brake master cylinder over a year ago with no problems, now I'm hearing a hissing noise comming from the booster area. After investagation I noticed that the hissing is a vacume leak of sorts, where the master cylider bolts to the bake booster I can feel air releasing from the botom where the two meet. My question is it the booster that needs to be replaced or just the rod seal and has anyone else had this problem.
03 Accord V6 Auto
cheezalo is offline   Reply With Quote Quick reply to this message
Old October 26th, 2012, 03:39 PM   #2
Bobby Lane Racing
nighthawk04v6's Avatar
when you replaced the booster, did you make sure not to lose the seal between the master cylinder and the booster. Ther is a seal that goes onto the master cylinder and into the booster. It's a black seal and it is very common to be misplaced when the master cylinder is removed.
Old October 26th, 2012, 06:08 PM   #3
cheezalo's Avatar
I was reading about the seal in Honda Tech, went and bought a new rod seal(46185-SE0-003 part # $7.50) from Honda and bam, no more hissing, the old seal was cracked and torn, simple fix, took less than 10 mins to replace
