Spongy Clutch Release - Honda Accord Forum : V6 Performance Accord Forums
Old November 27th, 2012, 08:24 AM   #1
ER MER GERD!!!!
DMunny's Avatar
My clutch feels spongy when I let it out under higher rpm shifts and the car doesn't want to easily go into gear. It is an intermittent issue at the moment. I had it looked at when I dropped by my tire shop to have my tires rotated. They said they topped off the fluid but couldn't see any leaks. I'm thinking I just need to bleed the clutch or could it be the pressure plate going out? My AV6-6 has roughly 75000k on it and I'm sure this is the original clutch. I picked the car up two years ago with 39000 miles on it. Let me know if you think I'm on the right path here. Thanks
DMunny (Doug)
...V6 = VTEC AND TORQUE CAN CO-EXIST...
DMunny is offline   Reply With Quote Quick reply to this message
Old November 27th, 2012, 08:34 AM   #2
bleed the clutch fluid. If not your pressure plate is probably dying
Old November 27th, 2012, 08:40 AM   #3
ER MER GERD!!!!
DMunny's Avatar
That's what I was thinking. I just wanted to get other opinions. I'm not a mechanic by any stretch of the imagination. Thanks
Old November 29th, 2012, 08:55 PM   #4
05J30VTEC's Avatar
i have to make 10 posts to create a thread.
05J30VTEC is offline   Reply With Quote Quick reply to this message
Old December 2nd, 2012, 07:16 PM   #5
Mine is starting to do this ... at 110k miles :-(
Old January 14th, 2013, 12:02 PM   #6
ER MER GERD!!!!
DMunny's Avatar
Yeah im just dealing with it at the moment....sucks.
Sent from my XT897 using Tapatalk 2
Old January 17th, 2013, 10:39 PM   #7
T1Invince's Avatar
It can be the clutch master cylinder. I greased mine with white lithium grease and it takes that spongy and creaky feel away for a while. Or you can get a new cylinder for about 50 shipped off of eBay.
T1Invince is offline   Reply With Quote Quick reply to this message
Old January 18th, 2013, 02:54 AM   #8
Randomhero's Avatar
This. If you really wana have fun, remove your CDV from the slave cylinder.
Current:
08' BMW E90 335i 6MT ~420whp
Old January 21st, 2013, 10:17 AM   #9
07AV6's Avatar
This issue started on mine around 5k miles ago. I now have 82k miles. I've had the creaky clutch pedal for 20k+ miles, though.
I was about to just buy the clutch online, but I'd hate to pay the labor cost if it's something else causing the problem.
Any way to troubleshoot to isolate the problem?
07AV6 is offline   Reply With Quote Quick reply to this message
Old January 24th, 2013, 08:12 PM   #10
if its spongy and feels almost like its slipping at high rpm's, remove the check valve from slave cylinder. Believe me, night and day difference, free, and easy to to do. Do a search on it. Guarantee that fixes your problem base off what you described
cbrjenkins is offline   Reply With Quote Quick reply to this message
Old January 24th, 2013, 08:14 PM   #11
07av6, if your clutch pedal is squeaky and lube doesn't work, replace your master cylinder. Honda has a TSB on this issue and has cured every car Ive worked on with this complaint
