Inner door handle not working - Honda Accord Forum : V6 Performance Accord Forums
Old December 6th, 2012, 05:17 PM   #1
So my driver door actuator went out a while ago. Bought a new one and swapped it out, but in the process snapped the plastic piece on the inner door cable where it connects on door. Bought a new inner door cable and swapped it out with the bad one. Currently I can only open my driver door from the outside. I checked the seating at the rods and all cables are in their respective plastic holders. There is no resistance at all when using the inner door handle, but I can hear it clicking at the handle and near connection at actuator housing. Any ideas? Thanks
handoverfist77 is offline   Reply With Quote Quick reply to this message
Old December 6th, 2012, 09:04 PM   #2
BLCKFLSH's Avatar
My guess is either the end of the cable has come loose, or the green plastic peice on the cable is not attached to the door panel. The clips break easily. There is a clip that rotates over the cable end, to hold it in place, and a bracket on the door panel to hold the green part. On my cable the green part was broken, but I was able to position it in the bracket, and carefully put the panel on, without the cable falling out. It has been there for quite a few years now, and hasn't come out yet. Good luck with yours.
BLCKFLSH is offline   Reply With Quote Quick reply to this message
Old December 6th, 2012, 09:16 PM   #3
if you replaced the white clip and its still not working check the green clip. I broke both of mine but I duct taped it back to the panel so that it it doesn't flex and it works perfectly again
thisaznboi88 is online now   Reply With Quote Quick reply to this message
